Question about Sony PlayStation® 3 (60 GB) Console
I have the same problem
The PS3 randomly switched itself during FIFA10, then flashed a red light. I have had this happen before and thought it would be the YLOD as before. However it turned back on, the XMB loaded, then after about 15 secs it started "lagging" gradually become slower and slower til it turned itswelf off. Again and again. It seems to be a fan problem as I put my ear near the PS3 and noticed as the fan slows, the PS3 slows and when the fan goes off, the PS3 goes off. I rang Sony, they wanted 150 for a replacement lol. I told them to go **** themselves as it was already a replacement they had sent me before for free though. But still.
Anyways, I decided to sell it on ebay, to fund a new slim PS3. Which is much more stable, uses less energy and has a 66% supirior ventilation system and is alot quieter with a bigger HDD. Cool
  • 30 Answers
Before you sell or send it in either try formatting the hdd to fix any bad sectors in your system, and get yourself a can of CO2 pc internal spray that stuff is high powered and used to clean inside systems so it will take all the dust away from the fan to stop it from clogging up
Posted on Jul 31, 2010
My playstation 3 randomly switched itself off during a movie. it made three beeps and turned off. there is a red light flashing on the on/off button
Its called "yellow light of death". Here is a link to my step-by-step instructions on how to fix it.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Mar 14, 2011 | Sony Playstation 3 (PS3) Console
My ps3 turned off during a game, when you try and turn it on the light on the power switch goes green for about 3 seconds then switches off again and has a red flashing light
Your PS3's problems are actually being caused by a connection error between the hard drive and motherboard. Without a correctly working hard drive connection your PS3 is unable to function and goes into shutdown mode, with the flashing red light warning.
So in order to fix the blinking red light on your PS3 you will need to repair the connection between the HDD and the motherboard.There is actually a rather simple way that you can do this yourself; while your PS3 console is switched off, locate the hard drive enclosure on the end of your console. Remove the plastic cover plate, then using a screwdriver unscrew the hard drive itself from its socket. Carefully remove it completely, then put it back in again. Tighten the holding screw, then restart your PS3
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
I was playing a game and the ps3 just randomly shut off then the red light starts flashing and every time I turn it on it shuts off right away
If the system turns on but then turns itself off, beeps at you and flashes it's lights at you then you have over heated the system. The GPU chip has probly pulled itself away from the board. This will require you to diassemble the PS3...
better u download repair guide....
click here to download repair guide
Dec 17, 2010 | Sony Playstation 3 (PS3) Console
Ps3 turns off beeps twice but there is no yellow light only red!
The yellow light is also know as the yellow light of death casued by a hardware failure. It can be casued ny over heating a bluray drive failure, a hard drive failure or even a powersupply failure. You know you have it when you power up the yellow light flashes then you hear some beeps then the red llight flashes. I would suggest returning it if you have that option or getting it fixed somewhere else as a last option.
Jul 16, 2009 | Sony PlayStation® 3 (60 GB) Console
Controller not working
I had the same problem, so I called customer service and had me do this:
1) with the USB cable plugged into the controller, power down the ps3 and turn the on/off switch in the back to "off".
2) hold your thumb down on the front button (where you normally can turn it on) while turning the switch on the back to "on" again. keep your thumb or finger on the front switch.
3) You will hear the normal "beep" that you usually hear when the PS3 boots up, but after a few seconds later, you will hear a secondary beep. Remove your thumb or finger after this second beep and the PS3 will reset itself after a few seconds. I have a projector connected to it, so I had to set the display screen back to HDMI afterwards, but when I disconnected the USB cable the controller worked wirelessly again. The customer service rep said that this allowed the controller to pair with the PS3 again. Note: You probably do not have to have the controller plugged into the USB cable at all while doing this. I just happened to have it plugged in. Hope this helps.
Mar 29, 2009 | Sony Wireless Controller for PS3
Red flashing light on ps3
When the light flashes red and you ALSO see the green light on too this indicates that the system is getting hot and you need to switch off and let it cool down.
if you switch on get the beeps see yellow light briefly then flashing red only this indicates failure.
The system has shut itself off to stop further damage ..... supposedly caused by getting hot .. maybe fan failed .... only thing that can be done is to contact Sony for repair or replacement.
I know this post is old but thought the info could help others ...... I hope you returned your PS3.
Sep 27, 2008 | Sony Playstation 3 (PS3) Console
Wont turn on
.........same problem.....
only my new hard disk worked...
Aug 06, 2008 | Sony Playstation 3 (PS3) Console
20 g japanese ps3, its turning itself off during startup and red light is flashing.
this could be down to the need of more power from your plug as when i use my power convertor it needs to be on high rather then low otherwise teh console doesnt power up
Jan 14, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
63 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
