Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
My book not recognizaed my windows
Unplug it from the crowded power strip and plug it into one that does not have any thing plug with it and it will work!
  • Anonymous Feb 09, 2008
    unplugged it from the power strip, plugged directly into wall & it now works.
I am still pity amazed but it did work must be sumthing to to with the interchangeable powered connectors ?
Posted on Jul 22, 2008
Konica Minolta biz.C-253 intermitent power shut off
what is a crowded power source????? a machine like that should have its own surge protector and proper plug connections
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 25, 2014 | Konica Minolta bizhub Office Equipment &...
We had a power outage, now pixma Mx410 won't come on, any ideas?
Is pinter plugged into a power strip? Try plugging directly into wall. Make sure wall outlet is working correctly, try another item in plug in. Does printer have a power module or brick that is plugged into printer? That power module is there to protect your printer during a power surge, it may need to be reset. Is there a light on that brick or power module? If so, does it light up? If not, could be a bad power module. There is no such thing as "reset" button, so don't look there...It will have to be reset in a series of ways for an "external" module.
  1. Disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet, power strip, or surge protector.
  3. If the printer uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. If the printer uses a power module with a detachable power cord, reconnect the power cord to the power module.
  6. Reconnect the power cord to the rear of the printer.
  7. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  8. Check to see if the power module or the power cord has an indicator light and if it is on
For an internal module:
  3. Wait 15 seconds.
  4. Reconnect the power cord to the rear of the printer.
  5. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  6. Check to see if the power module has an indicator light.
Not sure if this will help you..but worth a try.....
Jun 15, 2014 | Canon Pixma MX410 All-In-One Printer
My kenmore window unit keeps blowing reset button what could be problem. its not the plug to house i already checked it
It's the reset button on the plug itself.
Those things are the worst invention ever.
Cut that thing off and attach a normal plug.
Then buy a cheap power strip with automatic reset switch and plug to that.
Mar 11, 2010 | Kenmore 75050 Wall/Window Air Conditioner
My wii console wont turn on, its plugged and everything, we had a power outage earlier but now no red light comes on. Please help!
Unplug the wii power cord from the wall and the wii for 5 mins. to reset the brick on the power cord.
Nov 22, 2009 | Nintendo Wii Console
Acer aspire 5920 wont start. light in AC chrger
This is a sample of what you can try to do to diagnose a non-starting computer, If these don’t work, realize that most likely a system board (motherboard) has failed or the actual power trim strip above the keyboard has failed.
  1. Unplug the computer, then take the battery out, push the power button and hold it for about 30 seconds. Plug the system back in (leave battery out) and push the power button. If it starts, Great! If not unplug go to the next step.
  2. You should still have the battery out and the power unplugged. Now turn the laptop over. Take off all the covers and pull out the hard drive and ram and wireless card. Find the screw that has a symbol kind of like this its the CD rom drive screw. Now pull the drive out. Pick one stick of ram and put it back in the computer. Flip it over open it plug it in and hit the power button. If it does not fire up then unplug it and switch the ram. Plug it back in and hit the power button again. If it doesn't start up, unplug the computer and go to the last step.
  3. Pull the memory out and find the screws that hold the keyboard on. There are symbols in the plastic there should be 2 screws holding it in. Now in the battery compartment, there are several screw at the back edge of the computer take them out and also the ones in the battery in the center strip. Some are silver and some are black. Once you have the screws out of the battery area flip the computer over and open the lid. The strip just below the LCD with the power button and controls will now be able to be lifted up. You will probably have to lightly get an edge started before it will come up. There should be several little cables hooked to it. Flip the control panel over and look for some screws holding the keyboard in. I think there's 2. Lift up the keyboard. Making sure there's nothing touching anything important and then plug the computer in. Carefully hit the power button and see if the computer tries to start. If it does try it will probably beep at you. Unplug it and put a stick of ram in it. Plug it in and try to start it again. If not, unplug the computer and Go to the next step.
  4. Carefully put the keyboard and control strip in place. Flip the computer over and loosen all the screws that hold the computer together. Flip the computer over again and pull the keyboard and control strip up again. Flex the inner aluminum plate that was under the keyboard lightly. Plug in the computer and then hit the power button. If it tries to start, Great! put it together again in the reverse process.
If it does not, there are 2 possible things I would suspect the Control strip or the mainboard. If you don't get the computer to start back up please put it back together so you remember where all the screws go. Even if you plan to get another mainboard put it back together.
Oct 12, 2009 | Acer Aspire 5920-6727 Notebook
My T61 won't power on
Sep 25, 2009 | Lenovo ThinkPad T61 Notebook
On WGN HD, watching the Cubs game, the white color in the crowd and mortar in the brick walls pulsate. Very distracting.
just try to reset your LCD TV if reset button available there if not. The you unplug power cord for 4 hours then plug it again.
Good luck:
Regards:
VOTIT
Jul 08, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Using Windows Vista Suddenly can't see WD MyBook 500G
I had a problem with MY Book and I found out that if you plug the drive into a power strip it doesn't receive enough power, so it doesn't show up on Vista, but if you turn everything off and then plug the My Book directly into a wall socket, Vista will see it and put an icon in the My Computer area.
Jun 04, 2009 | Western Digital 500GB My Book World...
Computer keeps restarting...
it sounds like your hard drive is bad. You can buy a new hard drive or you can try SpinRite I love this program and has fixed so many issues.
you can find SpinRite here http://www.grc.com/sr/spinrite.htm
Apr 23, 2009 | HP Pavilion 520N PC Desktop
My book not recognized by windows
I had a similar problem that I just fixed. The drive was not being recognized at all - I unplugged, rebooted, switched to different computer, used different usb cable, plugged into wall outlet, NADA!
Then I tried something else - I just bought 2 more external hard drives and I switched the power port from the new one to the old one and the hard drive was recognized. I plugged the old outlet into the new hard drive and that worked, too. PHEW!
I had almost 100Gbs of music on there!
Dec 24, 2007 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
69 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
