Question about Sharp 55R-WP4H 55" Rear Projection Television
View timer blinking and TV will not turn on - Sharp 55R-WP4H 55" Rear Projection Television
  • kc4km Oct 07, 2009
    cancel, CANCEL CANCEL
    do NOT charge my card !
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The power supply of your sharp TV might have failed. It could be due to swollen/bulged capacitors on the power board. It can also be due to the Flyback transformer, which generates the high voltages(part of high voltage circuit). If you have disassembled the TV before then you can check for the swollen cap.s and also for any loose connector cables from power board to other boards.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Posted on Oct 07, 2009
View timer blinking. Can;t turn on TV. Unpluged TV for 24 hrs. Still bli nks when pluged in again.
hi you may a power supply fault, capacitors are the usual cause, but the mainboard can also cause the fault, failed firmware, thanks
shaun
Mar 02, 2017 | Televison & Video
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
How to get marantz tv sllep timer of so tv comes on
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 30, 2014 | Marantz PV-6070 TV
View timer light blinks.. I turn the tv on it starts to power up but then stops and the view timer light starts blinking. I can not turn it off or anything. Can only unplug it to get it to stop. And way i...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 18, 2017 | Sharp 55R WP5H 55" Rear Projection...
View timer keeps blinking..tv wont turn on.nobody set view timer..is there a reset button? tried to unplug but no luck
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons need to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterward!)
Apr 14, 2010 | Sharp 55R-WP4H 55" Rear Projection...
JVC TV AV-32870 will not turn on. blinking timer light
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Oct 17, 2008 | JVC AV-32820 32" TV
Stand by timer
stand by timer is blinking green tv will not come on
Aug 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
View timer only lights
TV WILL NOT NOT TURN ON RED VIEW TIMER LIGHT FLASHES AND THEN I CAN'T TURN OFF TV
Mar 29, 2008 | Sharp 61RWP4H 61" Rear Projection...
VIEW TIMER
Try unplugging the B+ to the convergence circuit and see if it will power up.. If so replace the convergence amps, two STK392-040 and check all the low ohm resistors.
Bill
Dec 13, 2007 | Sharp 55R-WP4H 55" Rear Projection...
View timer is stuck on
take your set to a tech your problem is more a technical problem that sounds as you are having a chip problem that controls the timer
Feb 16, 2007 | Sharp 55R-WP4H 55" Rear Projection...
Sharp 55R-WP4H 55" Rear Projection Television Logo
257 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
