Question about Garden
Runs poorly at low rpms, won't idle
Eager ****** 3.7ci won't idle and runs very poorly at anything but very high rpms.
  • 82 Answers
SOURCE: 1989 honda prelude enigne idles high then low irratic
I had the same problem on a Rover. There was a leak in inlet manifold that was caussing the problem.
To verify, spray some sealant to temporarily seal the inlet manifold .and the eratic idling should disappear for some time.
If it does, you know there is leak in inlet manifold which you can take of and refit with a new gasket.
Posted on Oct 27, 2008
SOURCE: Low idle speed problem!
You probably disturbed the timing between the crankshaft and the camshaft if you loosened the timing belt.
Posted on Apr 18, 2009
  • 31 Answers
SOURCE: spits and sputters only at low rpms
electrical issus. have you ever replaced the spark plugs and wires? distributer cap and rotor? might be time to do this routine maintenence.
Posted on Apr 29, 2009
  • 14036 Answers
SOURCE: running roug at low idle, smooths out at 2500 rpms
change plug and wire if its been a while most cars have 90000 miles platinum plugs in them.but the wires wear before plugs.so change plugs and wires.+clean fuel injectors .change fuel filter and air filter.if car still run rough your idling to low.have idling check .
Posted on Jun 06, 2009
SOURCE: 2004 northstar low idle after warm up.
I FIXED IT BY NUMBER 1 : IGNORING YOUR CLAIMS OF" I CAN FIX IT"
NUMBER 2 : LOOKING FOR A VACUUM LEAK " THAT YOU NEVER SUGGESTED.
Posted on Jun 11, 2009
Ryobi 725r trimmer carburetor adjustment
Turn both low and high adjustment screws carefully clockwise all the way in - do not overtighten.. Then back out each two full turns. Set the idle speed control for highest setting. Prime and start and let it run and warm up for about 15 seconds - then lower the rpms a tad and then adjust the low end screw for highest rpm. Then reset the idle to lower reasonable level. You may have to go back and forth with those two adjustments till it runs fine at low idle speed..
Then accelerate to highest speed and set the high adjustment for highest rpm. Then go from idle to high speed. If not smooth a small adjustment on the high speed screw is in order. Keep doing that until you get a nice smooth transition form low speed to high speed.
Mar 11, 2017 | Ryobi Garden
Why are all these codes being thrown in my Dodge w250?
What year is it? Your symtoms suggest oil contamination from bad fuel pressure regulator.
Sep 02, 2014 | Cars & Trucks
98 escort high idle
check for vaccuum leaks.. try spraying brake cleaner around the lines and see if it changes anything with the idle spped.. if it sucks in some it will chug while you spray it.. That helps locate a leak..
Apr 22, 2013 | 1998 Ford Escort
High idle, and engine misses
could be a spark plug or plug boot, depending on the last time they were replace i would recommend replacing them all.
Nov 19, 2012 | 1994 Toyota Pickup
Buell blast won't start without using starting fluid
Hi, Anonymous and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Leaking accelerator pump.
4. Loose low-speed jet.
5. Plugged low-speed jet.
6. Contaminated or plugged low-speed circuit.
7. Enrichner valve is not seated or leaking.
For more information about your issue and free downloads that you will need please visit the websites below and for specific information or questions you can reach me at xlch@mail.com. Good luck and have nice a day.
http://www.badweatherbikers.com/buell/messages/20164/737306.html?1398696120
Thread Bike won start without starter fluid while cold
Buell Service Manuals PDF Download
TWIN Motorcycles Buell parts
2001 Buell Blast Owners Operators Owner Manual Factory 2001 eBay
Jun 21, 2012 | 2003 Buell Blast
Cobalt not running at low rpm.......
All are possibilities but EGR valve makes the most sense. It's famous for causing poor idling and/or stalling at low RPMS. Best of luck.
Greg
Jun 18, 2009 | 2006 Chevrolet Cobalt
Husqvarna chainsaw carburetor adjustment
Find the 2 screws. There will be a (h) high and (L) low. These are for hig rpms and low rpms. First tighten the screws. Then unscrew them about 1-1/4 turns. Then start the saw and let it warm up. Start with the high rpms first pull the trigger all the way then adjust the screw in 1/8 turns either way until it is running good at high rpms. Then work on the L rpms. Get the saw to idle then pull the trigger, there should not be any hesitation when going from L to H rpms. Just adjust the low same as the High. They have to work together so if the high is good and the low is not just right turn the h a small amount. If you have any more questions let me know
Jun 11, 2009 | Husqvarna Forest & Garden No.967012396 345...
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
