Question about Sony Ericsson Walkman W810i Cellular Phone
Internet connectivity phone can't connect to the internet
  • katie82 Dec 26, 2007
    my phone will not let me connect to the internet on my phone
    Problem Solver:
  • 4 Answers
I had that problem when I first bought phone. I called AT&T (my provider) and they walked me right through it, didn't take too long, but I would have never been able to do it on my own!
Posted on Dec 26, 2007
How do i use my samsung c5212 as a modem to pc and to connect to internet.
Follow the below mentioned steps : 1. Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
2 Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
3 Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
4 Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5 Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
May 14, 2011 | Cell Phones
I need to use this phone as a modem for internet. How?
  • Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
  • Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
  • Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
  • Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
  • Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Feb 04, 2011 | Samsung SGHE250i Cell Phone
How to connect sgh j700 mobile internet to pc
install samsung pc studio
after that connect your phone through pc in samsung pc studio mode
after phone gets connected open pc studio-toolbox-internet connector
click on internet connector
your pc will be automatically get connected to internet.
thanks enjoy
Jun 10, 2010 | Samsung J700 Cellular Phone
Pl give step wise procedure to connect 6030 to internet via Dial
1. You need a means of connection from your cell phone to your computer or laptop (inferred,bluetooth or data cable), a dialup connection, your proxey settings
steps to connect internet with mobile phone to PC.
Step 1:Take your gprs enabled cell phone and connect it to your computer or laptop using either buletooth,infered or a usb cable.
Step 2:Create a dial up connection.Go into yor control panel,then into internet options.Then go to connections and add.Create a dial up connection and when it asks for a phone number type in *99#
Step 3:On your new dialup connection add the same proxy address you have on your gprs in your cell phone.
Step 4:Now on your cpanel there should be something called modem options here you must change the APN to whatever your APN is on yor gprs in your phone.
Step 5:Go to start menu and connect,then connect to your dial up (make sure your cell phone is connected to your computer or laptop)
Step 6:Start your browser (internet exploxer,opera etc) and start surfing the net.
Mar 09, 2010 | Nokia 6030 Cellular Phone
I want to connect internet in my pc from my LG GM200
There are two things that you need. 1. A GPRS connection. For this you go to the helpline of AirCel on your phone and have it activated. 2. The CD that must have accompanied the phone. It will have all the drivers that you need. Install them. 3. If the SW that came with the Phone does not create a network connection to connect to the internet, then create an internet connection after connecting the phone thru USB cable. 4. Configure the internet connection and connect.
Jul 28, 2009 | Cell Phones
How can i use my motorola z3 to connect with the internet
If you mean "how can I connect my computer to the internet using my phone as a modem," then this is possible. Just set up an internet connection from your computer to go through your phone (works wirelessly, I've never tried with USB), and make sure you have a Data Plan on your phone. Connect to the internet with your phone and then use it like Wi-Fi. Keep in mind this will be much slower than using an internet card or any other sort of wireless connection to the internet.
As for getting internet on your phone through your computer, I'm pretty sure you can't do this. It doesn't make sense to even try. It's redundant. Just download what you need using your computer. Then sync the phone to the computer via bluetooth or USB and transfer whatever files you desire to your phone. There's no need to get the phone directly connected to the internet if you have a computer that can get on the internet.
Jan 26, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Connect to internet using pc internet connection
connect your phone with your computer using Data Cable (DKU-2). Activate GPRS..request for user name, password and dial up number from your service provider..and try to connect
Sep 08, 2008 | Nokia N70 Cellular Phone
Mobile internet access via laptop
yes its possible. first install motorola phone tools on your computer. then configure the phone setting/connection/data/fax connection. then connect the phone with usb cable. then click default profile-ok. it detects your phone. when the phone appears in the right down side of your pc,then click connect to the internet button. cofigure the connection according to your service provider and continue the process. any further infomation contact with me at 008801714731453.
Jul 20, 2008 | Motorola Mobility RAZR V3i Cellular Phone
How to connect to internet
To get internet connection in mobile! first you want to get GPRS connection or MOBILE OFFICE connection in your mobile! then you can connect internet in your mobile by bluetooth or by mini USB!
Jul 06, 2008 | Motorola Mobility E770 Cellular Phone
How to connect Motorola L7 mobile phone to internet using BSNL prepaid connection
Hai friends,
   U can use motorola l7 mobile phone use USB data cable and connect the gprs connection
Jun 17, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
79 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
