Does not want to drain. If I push the cancel/drain button several times eventually most of the water will drain out.
1st i would remove the hose that goes from the dishwasher to the sink.(the drain hose) hooks up to your disposer or your plumbing under sink. remove that hose and clean out both ends could be something clogged their. i see that every day. if both ends r clear then id say your pump is bad or your pump is clogged up.hope this helps
