Question about Water Heaters
Control in lockout - Water Heaters
    Problem Solver:
  • 10 Answers
Unplug the water heater. wait a few minutes.
While you wait, if you have the manual check it for something called error codes if not don't worry.
plug the water heater back in for normal operation. Let it cycle and try to light. When it fails to light you shuld see a the lights on the control blinking in a distinct pattern, or depending on the unit, some other type displyed error code. look for this code in your manual. If it is not in the manuel or you don't have it you will have to call the manufactuers techinal support for the explanation of the code and a possible solution make sure you have the serial and model numbers. Or look for the installation manual online. Or come back here and post your findings with all relevant info as to make, model, year etc.
Please keep in mind that a lot of things can cause this to happen. Like, for instance, many newer water heaters have a moisture sensor somewhere near the bottom that will lock it out if moisture is detected. This usaualy requires a code to be entered into the control box to re-set the unit. This is just one example.
Posted on Oct 08, 2009
How do i reset the lockout
Push and hold the button for 60 seconds. It is in customer lockout because it was pressed more then 3 times.
Apr 25, 2014 | Honeywell R7184A1026 Electric Oil Primary...
Pr sw failed to close
Troubleshoot by type of gas control valve
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Repeated 3 flash on power vented honeywell gas control thermostat means system in lockout.
Repeated 3 flash on atmospheric-vent Honeywell gas control valve means temperature sensor failure.
Take apart gas control, and buy temperature sensor if sold separately at AO Smith dealer.
http://waterheatertimer.org/How-to-replace-Honeywell-gas-control-valve.html
Add a comment with more information
Mar 23, 2013 | Rheem 40 Gallon FVR NATGAS Low WATER...
Richmond powervent model 6G40PV-40F Lockout 4-2 blink. What's wrong. What do I replace to fix?
1) Rheem-Richmond does not post service manuals:
Copy following link to identify service manual by type of gas control valve:
2) For lockout, the air intake might be clogged or combustion parts dirty, causing overheating which will break TRD glass vial. Gas control may need to be replaced. Reset gas control by rotating knob to lowest temp for at least 6 seconds.
3) Call Rheem or local service tech.
Mar 10, 2013 | Water Heaters
Rheem Intelli-vent intermittently goes in lockout mode
Rheem does not post service manuals.
However AO Smith has posted relevant service manual:
Have you cleaned the air intake located under combustion chamber, and inspected for broken glass vial?
Rheem FVIR system uses glass vial that breaks if combustion air is slowed, and resulting combustion causes slow-moving venting of hot gasses, causing overheating that breaks glass vial.
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
Check gas pressure.
Replace gas control valve:
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Oct 09, 2012 | Water Heaters
Pilot light will not stay lit on GE 40 gal. gas water heater tank
You have tank-type gas water heater:
Gas water heaters need working thermocouple, adequate incoming fresh combustion air with no trace amounts of chemical, open vent to outside that drafts poison combustion product upward, clean burner tubes and combustion parts, correct gas pressure with no air in line, working gas control valve thermostat, no lockout condition such as tripped ECO caused by runaway heating and dirty combustion parts, and no lockout condition such as exposure to flammable vapors.
Open following links for troubleshoot resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
Jul 30, 2011 | General Electric Water Heaters
When restarting my water heater the burner goes out when I turn the heat up. I have replaced the thermalcouple. According to the manual the next option could be a Combustion shutoff system was tripped. ...
The FV lockout varies by brand of heater... some require simple cleaning, while Rheem requires part
Following link has rundown for various models:
http://waterheatertimer.org/troubleshoot-flammable-vapor-on-gas-water-heater.html
Burner going out could be FV lockout, low gas pressure, or gas control valve thermostat:
Following link has troubleshoot for pressure and various models of gas control:
http://waterheatertimer.org/troubleshoot-gas-water-heater-thermostat.html
Oct 23, 2017 | Rheem Water Heaters
Water Heaters Logo
75 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
