Question about Dell Inspiron 6000 Notebook
Deleted Sonic DLA because of crashes and now computer won't recognize unformatted disc in drive
  • VegasMartin Oct 09, 2009
    Tried it but it's still no good. I get the message "D:\ is not accessible. Incorrect function." when I insert an unformatted disc and try to open it.
    Scholar:
  • 98 Answers
Go to the registry and delete the lower and "upperfilters"for the CD/DVD drive option. you can access it by going to this option. REGEDIT >> HKEY Local Machine >> System >> CurrentControlSet >> Control >> Class >> Select for the option which is the first {4D36.....}. After deleting the upper/lowerfilters, close the Registry Editor and restart the laptop. Then there try inserting a blank disc or any disc. Thank you.
Posted on Oct 09, 2009
How do you format a cd
For windows 7:
1.Insert a disc into your computer's CD or DVD drive.
2.In the dialog box that appears, click Burn files to disc.
3.In the Burn a disc dialog box, type a name for your new disc.
4.Click Show formatting options, and then click one of the following formatting options:
-Live File System
-Mastered
5.Click Next to prepare the disc.
and for CD-RW:
1 Insert a disc into your recorder drive.
2 In My Computer, right-click your recorder drive.
The 'Use with DLA' option in the popup menu should have a check mark beside it. If this option is not selected, click on the HELP button and follow the steps in "Using DLA With Your Recorder Drive" before proceeding.
3 Click Format.
DLA's Format dialog box appears. The options available to you will depend on the type of recorder drive you have.
4 Set the options in the Format dialog box.
a ) Type a name for your disc in the Volume label text box.
b ) Select either Quick or Full Format by clicking beside the option you prefer. DLA can perform either a Quick or Full format of your discs.
c ) If you have an EasyWrite CD-RW drive, you will have the option to create an EasyWrite disc by placing a check mark beside Enable EasyWrite. (See Using DLA with EasyWrite Drives for more information.)
5 Click Start.
If you selected Quick Format or you selected Full Format and your drive supports background formatting, you will be able to use your disc within minutes. If not, you must wait until formatting is complete before you can write files to your disc.
I hope this will help you
Jul 30, 2011 | Computers & Internet
New Xbox console unformatted
I would suggest giving Microsoft a call and have them help you. If the hard drive is indeed faulty, they should be able to replace it for you at no charge.
Dec 26, 2009 | Microsoft Xbox 360 Console
Sonic Digita Mdeia Plus V7 not recognizing disc drive
You could try another program to burn discs, try ImgBurn from http://www.imgburn.com/
Sep 18, 2009 | HP dc7600 Convertible Minitower PC Desktop
HP Pavillion 1540n cd burner doesn't recognize discs
Your drive is most likely dead - sorry. DVD burners are not the hardiest of technologies and frequently die with enough use. Thankfully they are usually only $30 to $50 to replace with an non-hp OEM drive. These can be found at smaller computer stores, rather than places like BestBuy
However, most of these drives won't have lightscribe, so you will lose that functionality.
Of course, you can replace the drive with another lightscribe drive from HP, but that will cost you a lot more usually.
Good Luck!
Aug 06, 2009 | HP Computers & Internet
After CD burning process nearly done write error ruins CD-R disc
I think u can identify this problem by checking step by step. At first change ur cd brande. If probelm still
then setup windows.. then try to write.
May 09, 2009 | Toshiba Satellite A105 Notebook
I keep getting a message from Sonic saying, Installation package for the product SONIC DLAcannot be found. Try the installation again using a valid copy of the installation package. It says that ...
Article Details ID Number: 000131CR Products: Easy Media Creator 9
Easy Media Creator 9 Deluxe
Easy Media Creator 9 Trial Version
WinOnCD 9
WinOnCD 9 Trial Version (Not available publicly)
Easy CD & DVD Burning ("Vista Compatible" labeled boxes only)
RecordNow 9 Music Lab Premier
OS:
Cause: Through a clerical error, a driver is incorrectly being blocked as incompatible with Windows Vista®. If you do not have one of the above applications, you will need to upgrade to a Windows Vista® compatible version of the software. For Dell Customers
The patch is not intended for a customer base other than Dell. If you do not own a Dell system, it is being offered "as is" and to be used at your own risk.
To download and install the Roxio DLA Update:
  1. Click here for the DLA patch. When the file Download window appears, click Run. Note: If a Security Warning window appears, Click Run.
  2. Follow the installer's on-screen instructions.
  3. When prompted to restart your computer, click Yes.
  4. The computer restarts, and the update is complete
Pleae post here again when you have more issues and ill assist you as long as it takes.
Oct 15, 2008 | Computers & Internet
Sd card reader does not work
you might need to remove upper and lower filtrs with filtercheck 4.6
then repair sonic dla (if it has sonic burning software you use)
www.cdr-zone.com/forum/about4719.html&highlight=filtercheck
Aug 19, 2008 | Dell Inspiron 1501 Notebook
Vista Sonic Solutions DLA Blocking
I installed Roxio and my computer says driver not compatable
Apr 24, 2008 | Computers & Internet
Computer will not recognize the Seagate FreeAgent Pro 500 GB
If the hard drive is new and still unformatted, you will need to format it. Confirm that it is recognized in disk management (start>control panel>administrative tools>computer management) Go to the list on the left and expand "storage." Then click disk management. You should see your drives listed. Find your seagate 500GB drive, right click on it and then click format. It will take awhile for a 500 GB drive but once it is done, the drive should be usable.
WARNING: this will delete any files on the drive, meaning that if it is not new and you have files on it already, then they will be deleted.
Apr 11, 2008 | Computers & Internet
Mini-DVD playback
You can use Windows media and this has worked for me.
Aug 19, 2007 | Canon DC210 DVD Camcorder
Dell Inspiron 6000 Notebook Logo
102 people viewed this question
Alun Cox
