Question about Invacare Supply Group Health & Beauty
Clicking, first noticed on carpeted surfaces. Sounds like it is coming from rear end. Scooter has been used outdoors mostly over some rough terrain. No leaks visable. Was recently purchased used from a medical store. Was a rental. Looked in good shape and was quiet at the time of purchase.
  • 175 Answers
Clicking from the tires is usally due to one of two things. First, check to see that the nuts holding the wheel onto the axle are tight by removing the plastic cover and tightening them as hard as you can. Drive and see if it quit clicking. If not, check the air in the tires; they should be kept at the stated range on the tire. If they are foam-filled, flat-free tires, these can often click when the tire chages against the wheel. It doesn't affect the safety of the scooter but can be annoying. Spraying some WD-40 around the rims inside and out will often clear it up. If not, you'll need to pull the tire and tighten the 4 bolts that hold the split-rims together.
Posted on Oct 09, 2009
Go Go Ultra X Scooter is randomly beeping while in use. The scooter seems to be working fine, so I don't think beep codes would apply. It just beeps 1-4 times at random while we are using it.
Pride Mobility Products Sounds like the motor is getting too hot. Several reasons for that. The brushes in the motor can be worn, too much weight on the scooter, rider + whats in the basket or is being carried by the scooter. Rough terrain, grade too much. Never ignore the beeps. They tell you the health of the scooters systems.
Sep 09, 2016 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
I replaced the seal in the rear ended but it is still leaking what's next
Leaking seal could mean the yoke surface that the seal rubs on is rough, or that yoke is moving because of diff wear or misadjustment.
Sep 06, 2016 | 2009 Dodge Dakota Extended
My 2007 Chevrolet Impala has some rear suspension problem. First noticed on snowy/icy road conditions traveling at 50 mph, the car was swaying, fish tailing with no traction. Later noticed when driving...
Replace rear shock absorbers.
Their function is to maintain contact between tires and floor. When they are worn the wheels spend too much time in the air without any traction.
Nov 13, 2013 | 2004 Chevrolet Impala
Yamaha warrior bogs when i go over rough terrain and back fires
When the bike is on rough ground the engine is under more strain so this may be a sign that the spark plug, lead or coil is failing.
Feb 04, 2013 | Motorcycles
Brakes shudder at low speed on rough terrain
Might not help but check the Tyre sizes/tread wear are the same all round
I had to fit slightly different size tyres on the Rear and my traction control/ABS system went haywire...
Hope it helps, if not rules out 1 more thing.
Sep 28, 2012 | 2009 Chevrolet Aveo
Mobility scooter goes slow
driving range of 20 to 38 miles per charge depending on unit. Check out our E Wheels electric power bikes, and mopeds that goes 20 plus mph. Want a fast outdoor mobility scooter, check out the EW - 36 that goes 15 mph. This deluxe outdoor power scooter has a driving range of about 25 miles per charge, depending on the terrain and the weight of the user.
Jan 21, 2012 | Health & Beauty
EV Rider Royale 4 power problem
Have the battery or batteries tested they are most likely damaged.
Mar 17, 2017 | Electric Mobility 4 Wheel Power Electric...
Sundancer Scooter is fully charged and turned on but does not move when used as usual.
Hi there! There may be a blown fuse. Check under the seat and check for that, also, while there, look for the kill switch. The unit should not move unless there is pressure on the seat, like when someone is actually sitting down on it. These little clips come off all the time, especially if there is rough terrain that you go over. Take care.. Guy
Sep 09, 2010 | Health & Beauty
Removing carpet to clean it
Im not sure on this exact scooter (I have not come across one like yours in the UK) but most are simply attached to the scooter floor with velcro!
Feb 16, 2010 | Golden Technologies Companion II Travel...
My jeep is making a clicking noise or popping noise when the jeep drives over rough terrain. It sounds like it is coming from the rear shocks or springs? I asked a friend who has a jeep and he said it is...
check for ANYTHING that may be hitting the frame or body. --muffler --tire carier also check the shock-mount bushings(these ALWAYS fall apart from use and age)
and it just may be a bad shock(shocks do NOT "release" pressure!!)
-check ALL rubber bushings under the jeep,body mounts too!!
Dec 27, 2008 | Jeep Wrangler Cars & Trucks
Health & Beauty Logo
122 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
