I think my dryer is busted. When I press in the dial it makes sounds as if the drier is starting, but the drum doesn't seem to be spinning and the button won't stay pressed in unless I hold it.
Comments:
Oct 07, 2009
- Yes, it think it does.
Oct 07, 2009
- Thanks. Do you think I could take it apart myself and fix it?
Sounds like your problem may be a broken belt. If you have to replace your drum belt and if you have a front loading machine. First you will need to unplug your dryer from the electric. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Replace the broken belt. While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil.
This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
You may also need to replace your starting switch. Good luck, I hope this helps
at first we noticed the dryer wasnt drying! then we saw that the knob was not turning as time went...
(More)
at first we noticed the dryer wasnt drying! then we saw that the knob was not turning as time went by. we took it apart and started it up and saw a glow from the heating element so figured the problem was the main control switch. we got a new one and now the timer will move but the flame goes on then off on then off you can see the glow of the flame while having the back off the dryer. whats next? dryer part# 3977941....roper gas dryer
Dryer seems to work ok for about 10 min then seems to cool down. I have to run the cycle 2 more...
(More)
Dryer seems to work ok for about 10 min then seems to cool down. I have to run the cycle 2 more times to get the cloths dry. I checked the pep hole and everything seems to be working ok. does anyone have any suggestions?
