Question about Whirlpool LER4634J Electric Dryer
Push the button nothing happens
I tested the thermal fuse. i took the wiresoff the fuse touched them together the dryer started. igot a new fuse now nothing happens with or without the fuse in place.
  • houle329 Oct 10, 2009
    I did that still nothing
    Problem Solver:
  • 12 Answers
It looks to me is your start switch is going bad just ohm your switch just in case you shuold infinity in normal position and continuity when you turn the switch on.
Posted on Feb 16, 2010
    President:
  • 1,304 Answers
Check the wires again
you just might have a bad fuse
odd but it does happen
Posted on Oct 08, 2009
  • milten1
    milten1 Oct 10, 2009
    recheck your voltage
    make sure the door switch is engaged
    we will fix this dont worry
Kenmore 80 series electric dryer. does not start. hold the start button in and the only thing that happens is the timer makes a sound like an electric clock running. happened suddenly. one load ran...
it sounds like the thermal fuse is bad...The back cover needs to come off, but first UNPLUG
If you have a multi-meter set to ohms and test the little bullet shaped fuse in lower area on rear back. It sets alittle left above and up from rear vent it should have two wires going to a small bullit shaped fuse being held on with one screw.. check with meter and if bad you can touch wires together and this will start dryer..it stops dryer if it senses lack of air flow..they usually go bad if your vent is somewhat blocked , or totally blocked...usually before this happens..you might have to put your clothes in twice to dry them.. The wires can be insulated together so they do not touch metal..this will allow machine to run, but , you want to figure out why and correct this problem as welll ....sometimes, they just go bad.
Jan 30, 2011 | Kenmore 84052 Dryer
Dryer will not start
Check the door switch. It acts as a safety and will not allow the machine to start. The Thermal fuse just keeps the heat form coming on.
Sep 19, 2009 | Dryers
Push the start button but nothing happens
check thermal fuse inside back of dryer usually little white fuse unplug and ohm out should ge a reading if good
Aug 09, 2009 | Whirlpool Dryers
When i push the start button it doesnt work
You need to check the thermal fuse. It is located just inside the rear of the dryer and is usually mounted on the exhaust duct. It is about one inch long and can be tested for continuity with an ohm meter or multimeter. If it doesn't have continuity, then it is defective and must be replaced. Hope this helped and best wishes.
Aug 02, 2009 | Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Apr 02, 2009 | Whirlpool LGV4634JQ Gas Dryer
Kenmore gas dryer will not start
Try connecting the wires going to the start button to each other, see if it starts then. You checked the door switch the same way? Thermal fuse or in line resistor?
Mar 13, 2008 | Dryers
WHIRLPOOL DRYER WON'T START
It may be as simple as a thermal fuse. Some Whirlpool dryers have power for the motor going through the theraml fuse.
Mar 08, 2008 | Whirlpool LEQ9858P Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
163 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
