Question about Canon EOS-20D Digital Camera
Auto flash function not working in "P" mode...
In full-auto mode (green rectangle) the flash automatically opens when needed and works fine. In "P" mode a long shutter speed is chosen, and the flash isn't chosen. I can make it pop up manually, but the camera still uses a long shutter speed. It makes for crummy pictures!
    Problem Solver:
  • 7 Answers
I found the same problem, I am a memeber of a group and have just asked them. Should have an answer soon.
Posted on Dec 29, 2007
  • Barry Mung
    Barry Mung Dec 30, 2007
    The camera thinks you know what you are doing and thinks you want a slow shutter speed (on a tripod) for low light shots...
    Just try setting the camera to TV mode and set the shutter speed to 60 and manually pop up the flash.
    Should work just fine.
Canon flash won't pop up
Flash will not pop up automatically if you're in manual mode. Try putting it in the green auto mode, then try again. Still not working? See if the little flash symbol button is on OFF. If so, put it to ON or auto. Should work.
Jul 08, 2014 | Canon EOS 40D Digital SLR Camera Digital...
The biult in flash does not open,it's just the small one that is working
If you are shooting in any other mode that full auto (the green symbol on the wheel) your flash probably wont pop up on it's own? If your in manual mode you need to push the little flash button yourself to pop it up. And one mode on the dial is no flash mode where the flash won't pop up at all.
Apr 21, 2014 | Nikon D3200 24.2 MP CMOS Digital SLR with...
How do I disable the flash on a D 70s so I can take natural light photos?
The flash is automatic when the camera senses low light while in the full automatic mode and many of the preset modes. If you want full control over the flash and the "look" of the pictures you need to move into the "creative zones" Unlike the little icons these will be marked with "M" for Manual, "AV" for Aperture Value, "TV" for Time Value or "P" for program. you are most likely shooting in full auto which is a little green rectangular box.
Dec 11, 2010 | Nikon D70s Digital Camera with 18-200mm...
What is setting for continues flash, regardless of lighting.
You should be able to take the camera off of the FULL AUTO mode (the green square) and put it on "P" mode (program mode), which is full auto except for flash. Then if you keep the flash open it should always use it.
Nov 21, 2010 | Nikon N55 35mm SLR Camera
I have a canon digital rebel xt with a speedlite 200e flash. The flash is not working in full auto mode, although the built in flash is. I have replaced the batteries in the flash and the ready light comes...
In auto mode, the flash works only if it is necessary. You are saying that the flsah doesn't work in auto mode, and I assume that in other modes it's working properly. That means there is nothing wrong with the flash. So don't worry about the flash, it will fire in necessary, in full auto mode.
Dec 20, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Auto flash won't pop up
With the Canon XSi, the flash should automatically pop up in FULL AUTO mode when it thinks it needs to. In modes like Manual Mode, you need to pop it up yourself. There is a button on the front next to the lens that looks like a lightning bolt, that's the flash activator. Try popping your camera into Manual Mode and press that button. If it doesn't work then there might be a problem with the mechanism and needs repairs.
May 24, 2009 | Canon EOS Rebel XSi Digital Camera
Flash will not atomatically flash/can't change flash setting
Do you see any flash error code on lcd screen? if no then...
Flash will work when camera will set on auto mode ( green mark on jog dial) and you will see flash icon on lcd screen.
Dec 12, 2008 | Cameras
Shutter speed and apiture priority
The green rectangle is full automatic. You can use the P mode for the same function. In the P mode, you can change settings, in the green rectangle, you cannot.
Feb 14, 2008 | Canon EOS Rebel XS 35mm SLR Camera
Auto Function Failed
It could be a communication error between the flash and the camera. Check the shoe foot for any damage or stuck pins. All of them must make proper contact with the hot shoe on the camera to get full auto/TTL, same for the shoe of the camera, bent? dirty contacts?
Dec 31, 2007 | Nikon SB-28DX TTL Flash
How to switch on Auto Flash in Auto mode
Put the camera in "P" and press the flash button above the lens release. If the flash pops, than you probably just have too much light to need it when you are in auto. The flash button is not active in auto so if the xti doesn't want the flash in auto, u can't make it fire. If the flash button does not make the flash pop in "P", search this site for another post about flash not working and u will find that this could be the flash deactivation button in the hot shoe sticking. Not likely though with a new camera unless u have had a speedlite mounted alot.--
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Dec 26, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EOS-20D Digital Camera Logo
93 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
