Question about AOpen F50PS (Black) 15 in. Flat Panel LCD Monitor
Disconnected monitor toclean computer reconnected and shows no signal
    Sergeant:
  • 310 Answers
Your connection from the computer is lost. Check cable connections.
If this helps, check back and give me a good rating
Posted on Oct 07, 2009
My dell 470 wont boot up every thing seems to be working but when i turn on i get a blank screen and no signal displayed Edward
This means that your monitor is not receiving a signal from your graphics card.
Here are the things that you can try:
-Disconnect and reconnect your monitor from your computer.
-Try using a different cable to connect your monitor to your computer.
-Try connecting your monitor to another computer, if it works there it means that there's a problem with your graphics card and it may require a replacement. If your monitor is still saying no signal even if it has been connected to another computer that works fine then the problem is with the monitor.
Apr 22, 2011 | Dell Precision Workstation 470 (204816690)...
No Display
Check if the monitor is ok.
Disconnect it from PC. Power on the monitor.
Does it say "No Input Signal" or something like that ?
If it does, means monitor is good.
Reconnect it to PC.
Restart the PC. When its booting up, tap the specified key to go to BIOS.
(bios key varies with different motherboards. check the manual. usually its F1, F2, F10, F11 or Ctrl+Alt+Del).
If even the bios page doesnt show up, means some issue with motherboard.
Open the chassis.
Disconnect power & data cables going to motherboard.
Reconnect them the same way.
See if it helps. Otherwise get the mobo checked by a professional for repair.
amrish2jan@gmail.com
Oct 21, 2010 | Computers & Internet
Screen will not stay on, getting message no input signal
The message input signal means no signal is being feed to the monitor.
Check the cable use to connect the monitor to the video card.. fix and secure the connection.
If the computer is reading and you know its working, check the video card.
Turn off the CPU disconnect the video card from the motherboard and reconnect.
Try to open your CPU and see if it reacts with your monitor. If nothing happens replace your video card
May 18, 2010 | HP Vs17 17" LCD Flat Panel Monitor
GRAY BOX SAYS NO SIGNAL AND IT GOES ON AND OFF
The monitor is not getting a video signal from the computer (if it is connected to a computer)
Try the following steps first:
1 Turn off power and disconnect power cables from the computer
2 Press and hold the power button for 30 seconds
3 Reconnect power cables and try to turn it on.
If everything remains same, the next step will be to re-seat memory modules.
Mar 07, 2010 | Acer V193w LCD Monitor
Monitor says no input signal going in sleep mode
TRY UNPLUGGING COMPUTER AND MONITOR AND DISCONNECTING MONITOR FROM THE BACK OF THE COMPUTER. BE SURE TO UNPLUG AND NOT TURN OFF. WAIT ONE MINUTE THEN PLUG COMPUTER BACK IN . RECONNECT MONITOR TO THE BACK OF THE COMPUTER AND PLUG IN. IF THIS WORKS, WAIT FOR NEW HARDWARE RECOGNIZED TO COME ON. FOLLOW INSTRUCTIONS, IF ANY. RESTART COMPUTER.
Feb 08, 2010 | HP vs15 15"LCD Flat Panel Monitor
LCD monitor (viewsonic va720) "No signal"
You will need to disconnect the VGA cord that is connecting the monitor to the hard drive. Once you have that disconnected, try attaching another cord to determine if the cord is the issue. If you dont have another cord to test, then you will have to purchase another one from your local computer parts store and attach to determine if that is the issue you are having.
If the cord does not work, then you will have to take your monitor into a repair shop as there maybe an issue with the receiving port on the monitor.
I hope this was helpful and thanks for asking the experts.
Jan 05, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
"Check signal cable" appears on the screen. I have disconnected
The cable that connects the MONITOR to the COMPUTER is loose or disconnected. Check the monitor cable at both ends. (not the wireless switch, router or modem).
Nov 13, 2009 | Samsung SyncMaster 205BW LCD Monitor
Why do I get a "No Signal" on my Acer x193w monitor?
sounds like a video card issue.  Check the screen on another computer.  If it is doing the same thing, it is the monitor.  If it doesn't, then you have a video card issue
Feb 24, 2009 | Acer X193W LCD Monitor
AOpen F50PS (Black) 15 in. Flat Panel LCD Monitor Logo
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
