Question about Refrigerators
Sears side by side door jamb hot - Refrigerators
    Novelist:
  • 121 Answers
Dirty condenser coils or the condenser motor is not working, clean the coils with a vacuumm and brush and make sure the condenser fan motor behind the ref. is working. their is a access panel behind the ref. remove the access panel in rear and look for a motor, the blade should be spinning if the ref is running. be careful blade is sharpe dont touch blade if turning. motor runs around 29.99-89.99. and labor 75-125.00 depending on who u use and were u live . sometimes we find objects, pests caught in the blades. check all that before u call for servive . hope this helps.
Posted on Oct 07, 2009
Door sticks terribly...
First check to make sure that the hinges are securely fastened to the door jamb. Gently try to tighten all screws but be careful not to over-tighten or strip the screw heads. It's possible loose screws could be causing the door to hang slightly making it fit improperly into the door jamb.
It's also possible that the door frame isn't 100% "true" and it could be causing the storm door to get caught along the top or bottom edge. You can check with a level to make sure that both sides of the door are plumb (perfect 90 degree angle). You can also use a carpenter's square to check that all of the interior angles in the door jamb are 90 degrees respective to each other.
If everything is square then it could be that the hinges on the storm door are not aligned properly. With the storm door slightly ajar use a level on the vertical edge both at the top and the bottom. It should, ideally, be the same as the door jamb. If it's slightly off you could try shimming either the top or bottom hinge as necessary to even the storm door until it is aligned with the door jamb.
If you find that your door jamb is not "true" then you may need to consult with a carpenter or storm door installation expert to find a way to trim your storm door or refit it for easy opening and closing. Many older homes settle over time and sometimes door jambs slip out of alignment. The door itself may still open and close as usual but it may have sufficient gaps on all sides to prevent it from getting stuck. The newer storm door may be too tight a fit and catching on a door jamb that has settled out of true.
Feb 27, 2015 | EMCO Door. Forever 36 in. White Composite...
Door jamb switch
check at the bottom of the pillar just inside where the sealing rubber is on the door or check on the front door pillar near the bottom door hinge.
Mar 02, 2014 | 1992 Buick Century
I am installing a new closet with double doors. Can I put a GS-SK SPST Switch Kit in both the left and right jambs, or must I use only one kit in one jamb? Thanks.
You can use a switch in both jams, just wire them in parallel. For example, if your light outlet box contains the supply (hot) cable, you would run a cable from _each_ door switch to that same box. The hot would then be connected to the line side of both switches (pick a wire from each switch), and the load side (the remaining 2 wires) of both switches would be connected to the light. That way either switch will operate the light, and the light will shut off as long as both doors are closed.
Feb 05, 2011 | Gardner Bender #GSW-SK Door Switch
I have a chamberlain 5580 operator it sounds like motors jambed
If the motor is stuck in the open position the trolley may be jammed against a bolt just in front of the motor unit. If so, loosen the chain enough that the tension is taken off the trolley and then run the opener until the door closes. While the door is closed locate the 'up limit' control on the side of the motor unit. Turn this control in the opposite direction of the arrow printed on the cover and then tighten the chain.
If the door is not in the open position you may have a bad start capacitor.
Jun 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Replacing a Craftsman wired garage entry keypad.
Yep it a snap in piece. Look closely for a why to remove.
Dec 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Doors seif locking all the time wont stay unlocked
Get to the bottom of this, the next step is a circuit hot when you do not want it.
Most of these issues happen in the door jamb. Are all of the switches looking non damaged? disconnect the switches one by one to eliminate them.
Move the bundle in the door jamb and see if you can affect the issue. There are no successul repairs in this area, replace at least the entire run throught the jamb, but ideally the whole loom that you have to get to replace the jamb portion.
Sep 13, 2009 | 1992 Subaru Legacy
The jamb between the freezer & frig is very
It is common to be warm to the touch. If it is excessively hot then your door heater may be going out. Have a technician check it out. If this fails the doors will begin to sweat and drip onto the floor. Hope this helps. Good luck.
Aug 15, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Subzero 630 hot door jamb
If the door jambs are hot, that is either a dirty condensor or a dead condensor fan motor. Make sure the condensor is vacuumed and check to see if the condensor fan is spinning. It should be running anytime either compressor is on. You can clear the service light by holdint the "alarm: button for 15 seconds or turning the unit off and then on again.
Jun 21, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
