Question about Garden
There appears to be a transmission leak between the body and where the tiller attachment joins. Looking at the manual it appears these two sections come apart. What could be causing the leak?
  • 718 Answers
Check your seals my friend!
Posted on Oct 09, 2009
Camry csi 2000 oil leak between engine and transmission
Lots of Camrys do this.
The oil will typically leak from the rear main bearing seal between engine and transmission, but that will appear at the bottom of the joint line, and will not reach the exhaust. This leak is expensive to fix and is usually left as is.
A leak from the cam cover gasket can drip into the exhaust.
The other typical leak is from the distributor shaft o-ring seal. This appears at the top of the join line between engine and trans, and can blow back onto the exhaust.
Jan 03, 2014 | Toyota Cars & Trucks
In the manuel it says in section four to attach pulleys and cables,follow arrows. My wife and i are looking for the arrows to follow. Guess what? No arrows. What is this?
moz-screenshot.pngmoz-screenshot-1.pnghttp://www.bodysolid.com/Files/Manual/Manual_EXM1500S.pdf
see if this helps... o arrows to chase on this manual.
cheers... PK write back if still u need help
Jan 15, 2011 | Body Solid Body-Solid EXM 1500 Home Gym
Manual for Homelite model#ut60526
Not sure exactly what you need out of the manual, but if you are looking for schematics/parts list here is a .pdf document online that has the tiller broken down. Hope it helps.
http://www.ereplacementparts.com/images/homelite/UT-60526.pdf
Apr 23, 2010 | Homelite Consumer Products Tiller...
Im leaking transmission fluid from what appears to
Make sure you don not run low on transmission fluid in your transmission. Low transmission fluid will cost you a new transmission. You have the transmission line that connects to the upper passenger side or the radiator and the lower passenger side of the radiator. Determine which line has gone bad and you can buy a rubber transmission line hose at most Auto Parts store like Parts Source. Cut off out the section with a pipe cutter that has corroded through and replace with the transmission hose. Make sure you tell them it's a transmission line hose your looking for and don't use any other hose and double clamp with a compression clamps at ether end. If it's the connection at the radiator that has gone bad, replace that end and do that same as you would to sectioning off the the corroded line and try not to have more then 3 inches of repaired section. What ever you do, do not add any stop leak, this will create problems with the shift solenoids and check valves in your valve body in the transmission causing a transmission replacement soon after adding. Good luck and keep me posted.
Jan 05, 2010 | 1993 Chevrolet Lumina APV
My Husqvarna DRT900 did not come with a product manual. Does a tiller need transmission fuel? Or just oil and gas.
Try looking on this page of the Husqvarna website.
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=drt900&types=O,I
Jun 24, 2009 | Husqvarna Garden
Rototiller transmission
I am having transmission problem (loud noises). I am looking for a repair manuel for a roper rear tine tiller. Model RT150GR chain drive.
Mar 27, 2009 | Craftsman Garden
Craftsman front tine tiller 917.299011 parts
If you are looking for repair parts diagrams and part numbers they are located pages 38 through 45 of the Owner's Manual.
Hope this helps.
Mar 17, 2009 | Craftsman Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
