Question about Canon LaserClass 9000L Plain Paper Fax
Canon model 9000L supply rec.paper error message. the tray had plenty of paper. we have unplugged and restarted.
  • 56 Answers
Make sure your side casette has paper as well.
Good luck.
Posted on Oct 13, 2009
Supply rec. paper tray:ltr
1) unplug machine from power supply.
2) Under printer properties, select custom paper size and set it on A4 if you use A4.
3) Power on the machine and then try to print.
Hope that helped
Jun 29, 2010 | Canon imageCLASS D320 Digital Copier
Error message saying "supply rec. paper"
There is a small side tray on the right side of the machine,check if there are paper loaded in.
Jun 30, 2009 | Canon LaserClass 9000L Plain Paper Fax
Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Jun 03, 2009 | Canon MF8180C Color Laser MFC Printer
Supply Rec. Paper tray will not clear even with a whole ****
Ok try this - switch the machine off at the mains, empty the paper tray. Push the paper tray back in and switch on the machine with no paper in it. When it's finished warming up it should tell you the tray is empty. Then put paper in. This will usually clear it.
Jan 24, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
"Supply Rec. Paper Tray : LTR"
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Printer will not print: Canon imageCLASS D320
The paper size selected in the menu system must match the paper size in the rec. (recording) paper tray. If you have 'letter' size paper in the tray and the menu system is set for 'A4' paper you will get this message. Either put A4 size paper in the tray, or change the paper size in the menu system to 'letter'.
Oct 15, 2008 | Canon imageCLASS D320 All-In-One Laser...
Not working
Pull out the tray with paper.
You should find a moving plastic "tongue" near the middle of width in the area where your paper tray should go. It's a contact based flag for the device to consider how much paper is in the tray. Check if it's not broken or stuck in odd position. Move it back and forth several times, with no force, it goes very easily. When you lift the flag up, see message and blinking led stop appearing. Try to pull paper tray back in, add paper if error appears again. Enjoy!
Sep 15, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Canon Imageclass D320 supply rec. paper malfunction
My problem was that I was trying to print from a PDF file. I found out that the file was legal size and that the setting for the printer to "choose paper source by PDF size" was checked. I unchecked it so that it would print on letter size paper. Hope this helps
Jun 05, 2008 | Canon imageCLASS D320 Digital Copier
and PLEASE HELP
Make sure you check both paper sources, the side tray going empty will cause your alarm to go on
Apr 25, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Canon LaserClass 9000L Plain Paper Fax Logo
536 people viewed this question
old marine
old marine
