Question about NetGear FS105 5x10/100 Mbps Networking Switch
Netgear FS105 Switch is not fowarding ports properly.
I used to have a Dlink router/switch that i had disabled DHCP service on and was working fine.. a friend of mine needed a router for his network at home. I traded him my router/switch for his netgear that did not let him share internet over his Cable modem. I have it set up now but I'm not aware how to go into the switch and set it's gateway and primary settings to match the setup in my network
  • Anonymous Apr 12, 2009
    if connect it all up, with an ethernet cable from my modem to the netgear FS105, then i plug another ethernet cable from the modem into my computer and it will connect, but then i put another ethernet cable into my other pc and it wont connect. but if i take the one out that was working and restart the modem the otherone will work
  • 78 Answers
Does your modem have a built in router or do you have a router in your network. The switch needs no changes that's all it is a switch it will allow computers to talk and share fine, if you want to use it for internet you will need to connect it to a router first or use one of your computers as the router and let it share the connection. since you disabled DHCP on your router I am assuming you have a router. all you need is to connect the switch to the router, the connect the computers to the switch and all should work.
Posted on Dec 26, 2007
I have a Netgear DG834G v4. Wireless connection is fine, ISP is fine and Internet via wireless is perfect. Nothing via the LAn ports seems to work. Both XP and Win 7 machines see Lan as an undefined...
DHCP SERVER in Router and DHCP server in Wireless Conflicting - Set WI Fi DHCP router leases to say 192.168.0.10 to 192.168.0.100 and default gateway as 192.168.0.1 and on the router set the router's ip address to 192.168.0.1 make the Wi Fi router address 192,168.0.2 . Set in the router the DHCP address leases to 192.168.0.101 - 192.168.0.254 and default gateway 192.168.0.1 or deactivate one of the dhcp servers and rely on one dhcp server like the routers and then deactivate the wi fi's dhcp server.
Jul 28, 2017 | NetGear DG834G 54 Mbps 802.11g Wireless...
I am trying to install a Netgear router after my switch. I end up having no internet on some of the computers connected to the hub and none on the router. If I configure the router as a dhcp client...
You'll want to configure your router as a dhcp server. Connect the switch to your router's lan port. Connect the remaining devices to a port on the switch. Your wireless access point should have it's dhcp server disabled. You can only have one dhcp server per network. The wireless can get it's address from the router's dhcp and the wireless client devices will get their ip address from the router, as well. If your wireless access point is a router with a wan/broadband port and some switch ports you will want to make sure that you are connecting to your Asus switch via one of the switch ports.
Be sure that your client devices are configured to get their ip address via dhcp and you should be surfing the interweb in no time flat.
Oct 21, 2010 | ASUS GX1008B 10100Mbps Desktop Unmanaged...
How to connect netgear fs108 to cable modem
leeb..... switches cannot be connected to the Cable modem.... because NAT will not be enabled in cable modem....so there wont be any DHCP server present in the cable modem....
Nat will be enabled only in DSL modem like AT&T verizon etc....So DHCP server will be present inside DSL modem...that is the reason why switches can be connected only to the DSL modem....
With NAT enabled modem, switch will work as a switch.... With NAT disabled modem, switch will work as a hub.... This is the difference....
Any doubts further ? please clarify with me.... I am ready to help you....
May 09, 2010 | NetGear FS108 8-Port Ethernet Switch
How fix wireless drop. why does my netgear wireless router seem to drop or just no connection to my laptop? I'm currently using this model NETGEAR- RangeMax Dual-Band Wireless-N Router with 4-Port...
Try turn OFF DHCP, START>>RUN>>service,msc enter, scroll down to DHCP, set to OFF & Disabled, also further down Windows Zero configuration, again OFF & Disabled.. reboot,try that.
Feb 28, 2010 | NetGear RangeMax WPN824 Router
How do I set my Netgear FVL328 to be a switch for my network? I have a Dlink DIR-655 connected to my cable modem. But I don't have enough ports for all of my devices. So I connected the Netgear FVL328...
If I understand, the D-link is a switch but you don't have enough ports so you want to use the Netgear to get additional ports.
The way to do it is to use one of the Netgear Lan ports to connect to one of the D-link ports, then use the remaining Netgear ports for your stuff, leaving the WAN port disconnected.
Personally I would use the Netgear as a firewall and connect the D-link to get the additional ports.
Also, Apparently the Netgear and the cable modem or D-link are both running DHCP servers to assign IP addresses to connected devices that need one assigned. You should turn the DHCP server off in whatever unit is being used in a slave fashion. This is done in the netgear by opening a browser and typing in the IP address for the netgear, which is probably 192.168.1.1, and logging in using username 'admin' and password 'password' unless you changed them.
Mar 15, 2009 | NetGear FVL328 and FA311...
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
No connection
the printer needs an IP address from dhcp server or in other words, the router. the switch just acts as a kind of repeater on network segment.
Jul 08, 2008 | NetGear FS105 5x10/100 Mbps Networking...
Dlink dgs 2208 switch
pls check your connection between the switch and the router,dsl,access point.
2.make sure the gateway router is receiving good signals
Apr 12, 2008 | D-Link DGS-2208 8-Port Gigabit Ethernet...
Wireless access point connecting to router...
The question is how do you want to cable the netgear and what do you want to do with it.
If you cable a lan port of the DLink to the Netgear WAN port you will have two subnets that must be addressed differently. Opening up and forwarding the ports for XBox could be difficult.
I believe cabling the Netgear as an access point makes more sense. CONFIGURE THE NETGEAR BEFORE CABLING. This is achieved by wiring a lan port on the DLINK to a lan port on the netgear and ignoring the wan port on the netgear. This will involve configuring several router items that should be completed before the devices are cabled together. You will need to remember the Netgear's new network address and probably use a static IP address from a computer to configure it back into being a router after these changes, if required. Or reset the configuration to factory default following the users guide.
First the Netgear needs DHCP turned off as it will be part of the DLink's network and not a separate subnet - the DLink will perform the DHCP services.
Second the LAN side of the Netgear will need a static IP address in the DLink's network. This is where it may get tricky for you. Verify the DLink has an IP Address like 192.168.0.1 and a subnet mask like 255.255.255.0. That means all IP Addresses in your network start 192.168.0.??? where ??? is unique for your network. Verify your DLink router has a set of addresses reserved in the DHCP setup for dynamic address assignment these addresses like 192.168.0.100 to 192.168.0.199. If the above is true or with the information you extract from you DLink router you need to determine where you can create static IP addresses -- in the above case 192.168.0.2 to 192.168.0.99 are available. You need to assign one of those like 192.168.0.2 to the LAN side of the NetGear Router. You will probably want to assign another to the XBox == like 192.168.0.20. You will probably need to deal with opening ports or placing the XBox into the DMZ of the DLINK router which will require a static IP Address.
Now cable the devices
When considering the XBox Configuration below the DLink is the router that must be configured to allow the open ports or DMZ access to the Xbox == the netgear is not functioning as a router in this configuration.
Check out the following links on XBox Configuration if required.
The second link may be the best to start with.
The generic connection and configuration document
http://www.microsoft.com/windowsxp/using/networking/setup/xbox.mspx
This is a good description of possible router2.gif options.
http://www.ianarchbold.com/xboxlive/index.html
If you need assistance setting this up in your environment leave a comment on this problem and I will respond.
Dec 27, 2007 | NetGear MR314 (MR314NA) Wireless Router
LAN Switch Ports
Try this website to start. http://member.dnsstuff.com/pages/tools.php
Oct 06, 2007 | Linksys 5-Port Ethernet Switch (SD205-UK)
NetGear FS105 5x10/100 Mbps Networking Switch Logo
916 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
