Question about Linksys Wireless-G WRT54G Router
I need to know how to set up security - Linksys Wireless-G WRT54G Router
    Sergeant:
  • 310 Answers
Here is a pdf document that gives you a security checklist
http://downloads.linksysbycisco.com/downloads/WRT54G2_V10_UG_C%20web.pdf
If this helps, please check back and give me a good rating
Posted on Oct 07, 2009
How do i set up my dlink to work with my new laptop.currently it is conected to my desktop computer. trying to manually add my wireless conection. Need to know my Network Name(1-32case sensitive...
Your laptop should be able to automatically find the network name and security type. (You would have set up all of this, by the way.)
You should then type in your security key/password (you should have set this up when setting up router for first time, also) and then you should be connected to the internet.
Your laptop might not have wireless capabilities, so you might have to buy a wireless network adapter.
May 19, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Forgot my security code and am trying to set up a new laptop with my belkin wireless router
If you've forgotten the security code, you'll have to go in and set up a new security code. If you need instructions, let me know. Thanks.
Jan 31, 2011 | Belkin (F5D7230-4) Router (587009)
I am trying to get internet on my dsi
I assume you have a wireless router - you need to make sure your security is set to the security type WEP as the DSI cannot connect to WPA routers.
if you need details on how to set the security please let me know the make and model of the router.
Dec 19, 2010 | Computers & Internet
Can not connect to internet thorough my dlink 614 router It tells me the internet security key is incorrect even though i know it is not
Please access the web interface of the router and confirm the security key. Also, you can try to change the security key. It can be a possibility that your computer is not synchronizing properly with the current security settings.
If you find that you are putting the right security key then please change the security type to wep 64 bit or wep 128 bit and configure a new key. Also, change the SSID or the network name and try to connect.
In case of any issues please let me know which windows you are running and the security settings on the router.
Thanks,
Rashish
Aug 09, 2010 | D-Link AirPlus DI-614+ Wireless Router
Get stuck changing net settings, ie ssid...
if your home is set up with wireless modem or router and your computers are connected wirelessly its pretty simple to set up. more likely you or someone who set it up probably set it up securely meaning with security key and password. So you do have to know few things about your home network. like what is the name of your home network (SSID). the security setting of your home network. and finally the password of your network. if you don't know these things about your home network you will not be able to get connected wirelessly. but if you do have these info on hand read along....
JUST MAKE SURE YOU DO HAVE A WIRELESS HOME NETWORK... it definitely wont work if you don't have a wireless setup and u are trying to connect wirelessly. people overlook this no brainer.
1) go to Settings
2) Network Settings
3) Internet Connection Setting. confirm on "O.K."
4) easy *it may or may not give you a message reading "checking network configuration2_bing.gif"
5) wireless
from this point on you need to know few things about your network.....
6) scan -- once scanned it'll give you other wirelss access point for you home network and some other near your home along with few information such as SSID (which is what you set your network to be -- i.e. "the jones" or "linksys" or "summer home" or "my connection" etc etc) SECURITY (this is the password you set up your network with) SIGNAL STRENGHT (usually your network will be the strongest among your neighbors since you are closer to your router)
7) highlight your network and press x . (you should know what it is) selecting on the other network will probably not do you any good since it'll probably be all locked with password and such and so should yours be.
8) SSID which means service set identifier basically mean the name of your network. if your home network is set up with security and password your home network will not show up under SSID (this is one of the things you need to know about your home network. if you don't know ask the person who set up your home network)
9) on WLAN SECURITY SETTING2_bing.gif page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password yours may be different so choose the one that you used.
10) WPA KEY - which basically means password. input the password you used to set up your home network (this is another thing you should know about your home network or ask the person who set it up)
**it'll give you "checking network configuration"
11) if you input all the correct info you should get the "setting list" screen
12) press "X" to save the setting
13) do the connection test and if all things were entered correctly you should have success.
all this seems complicated just reading but if you follow it step by step its easy. you just need to know the name of your home network, the home network security setting, and the password of your home network.
on the other hand if you are setting up a wired connection it makes it a whole lot simpler. you don't need to know your network name, security key, and password.
make sure you have the ethernet cable plugged in to your ps3 and to your modem or router
1) go to Settings
2) Network Settings
5) wired
6) auto-detect
7) automatic -- for the IP address setting
8) do not set
8) automatic -- DNS setting
9) automatic -- MTU
10) do not set -- PROXY SERVER
11) ENABLE -- UPNP
save connection setting
test connection
if your home network is set up and u got the ps3 connected it should work
May 19, 2010 | Sony Playstation 3 (PS3) Console
I need password to be able to lock my internet
You can find everything you need to know from here:
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G
You basically setup your own security. If this is a pre-configured router and you do not know the access information, then you may need to reset the router back to factory and then configure it from scratch. While you are at it, download the latest firmware and update your router for best performance.
Apr 14, 2010 | Linksys Wireless-G WRT54G Router
I want to know d code
Dear
1) *#7780# followed by security code
2) Menu - settings - Restore factory settings - security code
Above two step to format phone, u need to enter ur phone security code if have changed or default code is 12345
Regards
Please let me know ur comment or rate solution
Mar 02, 2009 | Nokia 6300 Cellular Phone
HP IPAQ HX2495 won't connect to WIFI
check your security settings. Disable the security then try to connect again, if it connects then you will need to tweak your security.
Dec 31, 2008 | HP iPAQ hx2495
Security settings
you need to check in the router wht its selected. wpa is wifi protected access , its the more secure and u need to set the changes in the router first the same key in ur computer
Nov 02, 2008 | Sony PlayStation Portable (PSP) Console
Security of wireless network
You can directly connect your computer to the router thorugh the routers "internet" port and then re-run setup. OR you can type the IP address of the router into your address bar (the default is tipically 192.168.1.1 or 192.168.0.1) and then enter the router username and password (I believe the Belkin default is username:"Admin" password:"Password") in the admin control planel look for a "wireless security" tab. You can then define your wirelss security settings there. Just remember to configre the same settings on all devices that will connect to the router.
Feb 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Linksys Wireless-G WRT54G Router Logo
46 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
