Question about Pedals Cycling
How can i take my pedals off - Pedals Cycling
  • 530 Answers
Since you did not indicate the the pedals were actually clips or special to your specific bike I can only assume they are standard pedals.
If you look where the pedal and crank arm meet you will see what looks like a metal pin. If you look closely you will notice this pin has two flats opposite each other. This is nothing more the a six sided bolt but with only two sides. Normally you would use a pedal wrench however a wrench of the appropriate size with a thin head will also work. Using a 2x4 about 4 feet long, place it against the pedal on the side opposite the side of the one your removing. Depending on whether you are loosening or tightening the pedal use the 2x4 as leverage against either the front or back side of the other pedal.
This will vary depending on the type of pedal you wish to remove. For instance some pedals use an allen head bolts that is threaded in from the inside of the crank arm.
Hope this helps.
Posted on Oct 07, 2009
Suggest a good delay pedal to buy for guitar.
According to many musicians rating, top three best delay pedals are:
? Donner Yellow Fall Vintage Pure Analog Delay Guitar Effect Pedal
? Behringer Vintage Delay VD400
? TC Electronic Flashback Delay and Looper Guitar Delay Effect Pedal
All these delay pedals are best in different conditions, you can choose any of them.
Tho check their reviews, you can visit this link:
Best Volume Pedal Top 5 Best Volume Pedals Reviewed by Musical Study
Feb 22, 2017 | Cameras
Tip
Installing a Pedal Strap onto a Bike Pedal
Video about How to Install a Pedal Strap onto a Bike Pedal
  • This procedure will demonstrate how to attach a pedal strap onto a pedal
    • This is even easier when the pedal is attached to the bike but we did not have a bike available so we are showing how it is done with the pedalremoved from the bike
      • Tip: Soaking the pedal straps in hot water can make the strap installation even easier as the hot water will soften the rubber making it more pliable
  • Start on the inside of the pedal (nearest the pedal shaft) by placing the slotted hole in the strap at the bottom of the tab and pulling the strap up and into place as seen in the video
  • Then with the tab on the outside of the pedal, start at the bottom and push the strap up and around the tab into place
  • This is all that is required to install a pedal strap onto a bike pedal
  • That completes the procedure
Installing Pedal Strap onto Stationary Bike Pedal Video
on Apr 28, 2014 | Exercise & Fitness
Tip
95Xi Crosstrainer Pedal Replacement
Video about How to Replace the Pedal on a 95Xi Crosstrainer by LifeFitness
  • This video is about how to replace the pedal on a 95Xi LifeFitness crosstrainer
  • Tools necessary:
    • T40 Torx Driver
  • Remove the (4) torx bolts securing the pedal to the pedal lever assembly
  • Install the new pedal in reverse order
  • This completes the replacement of a pedal on the LifeFitness 95Xi
Life Fitness Crosstrainer 95Xi Video Pedal Replacement
My clavanova cvp-96 sustains all the time, pedal up or down. Pedals have normal mechanical action. It started intermitant but now all the time.
You could try this ( some pianos determine polarity when turned on if pedal is plugged in )
1.Remove the pedal from the keyboard. Turn on without inserting pedal. Plug in pedal whilst turned on. If it works you're done.
If it is still backwards go to step 2.
2. Remove the pedal. Plug in the pedal. Turn on. Try it. If it works you're done.
If not go to step 3.
3. Buy a genuine Yamaha product or a switchable pedal.
Nov 14, 2014 | Music
Yo I have a 1990 honda prelude si ,I have an issue with clutch pedal, my clutch pedal seems to stick when depressed it still has good pump pressure but I have to lift it up. Now I live in Idaho and it
The pedal return spring should be checked. Also the pedal bushings where pedal connects to the pedal support up under dash may be worn and not allowing free pedal movement. Work the pedal with your hand and watch the upper mounting of the pedal to see if you can see the problem. I would expect the bushings need replaced. You might try a little light oil where the clutch pedal attaches.
Jan 15, 2013 | 2000 Honda Prelude
The sustain pedal is broken on my PX-700 and I would like to know if there are any replacement pedals on the market that are compatible?
Getting back to the Casio PX-700 - yes it is possible to use a new £14.30 (EBAY) metal pedal which is more durable than the original.
The original pedal has two internal switches (semi-sustain, full sustain) depending on pedal position.
The replacement single-switch pedal is switcheable (normally open or closed) - for this mod, it should be set to 'normally OPEN'.
There are now 2 choices:
i) Are you just interested in Sustain only?
ii) Do you need the other 2 pedals working (mid/left hand)?
For choice i)
Turn off power. You can now cut the old cable where it enters the pedal assembly & remove the pedal bar (held by 2 large screws).
Discard the pedal bar & old pedals.
Open new pedal base & desolder the screened cable (note the screen connection pad position).
a) Run the black cable wire to the new pedal screen pad & solder in place.
b) Join the grey & brown wires & solder to the other pad.
Insulate the unused (yellow/red) wires.
Replace pedal base - JOB DONE!
For choice ii)
a) Dismantle pedal assembly
b) Without removing any wires, solder the two pedal wires to the existing coloured wires as described above - OK to join grey & brown wires.
Problem. The above pedal is 9" overall, so may be placed sideways, so as not to be too far forward.
OR use a smaller guitar-type footswitch (non-latching, normally open).
Jun 13, 2011 | Casio Portable Keyboard Touch Sensitive...
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
Brake and gas pedals
The vehicle has a optional adjustable brake to increase driver comfort. The brake pedal position is changed in phase with the accelerator pedal. The system is adjusted by pressing the dash-mounted switch that powers the driver motor mounted on the accelerator pedal assembly. The two-way motor operates backward (away from the driver) or forward (toward the driver) to adjust the accelerator pedal directly and the brake pedal through the drive cable attached to the brake pedal assembly.
  • Adjustable brake pedal inoperative
  • Switch.
  • Circuit.
  • Motor.
  • Cable.
  • Obstructions
PINPOINT TEST D: ADJUSTABLE BRAKE PEDAL INOPERATIVE Test Step Result / Action to Take D1 CHECK MOTOR SOUND
  • Allow two minutes for the thermal overload to reset.
  • Operate the adjustable pedal control switch.
  • Can the adjustable pedal motor be heard to operate?
Yes
GO to D2 .
No
GO to D7 . D2 CHECK MOTOR INSTALLATION
  • Check adjustable pedal motor for correct installation.
  • Is the motor installation OK?
Yes
GO to D3 .
No
CORRECT the motor installation. TEST the system for normal operation. D3 CHECK ADJUSTABLE ACCELERATOR PEDAL SYSTEM
  • Disconnect the brake pedal-to-accelerator pedal cable.
  • Does the adjustable brake pedal operate now?
Yes
INSTALL a new adjustable brake pedal assembly. REFER to Section 206-06 . TEST the system for normal operation.
No
GO to D4 . D4 INSPECT FOR FOREIGN MATERIAL
  • Inspect the adjustable accelerator pedal assembly for foreign material causing a binding condition.
  • Was any foreign material found?
Yes
REMOVE the foreign material. RETEST for normal operation.
No
GO to D5 . D5 CHECK CABLE
  • Detach the adjustable pedal motor cable.
  • Inspect the ends of the brake pedal motor cable for wear or damage.
  • Are the cable ends OK?
Yes
GO to D6 .
No
INSTALL a new accelerator pedal assembly. REFER to Section 310-02 . TEST the system for normal operation. D6 CHECK CIRCUITS FOR SHORT TO BATTERY
  • Key in OFF position. Adjustable Pedal Switch C290
  • Disconnect the adjustable pedal switch C290.
  • Measure voltage at C290-1 and C290-7.
  • Is the voltage greater than 0 V at either pin?
Yes
REPAIR the short to battery. TEST the system for normal operation.
No
GO to D7 . D7 CHECK POWER TO SWITCH
  • Measure the voltage at C290-2 circuit 490 (RD).
  • Is the voltage greater than 10 V?
Yes
GO to D8 .
No
REPAIR circuit 490 (RD). TEST the system for normal operation. D8 CHECK GROUND TO SWITCH
  • Measure resistance to ground at C290-3 circuit 57 (BK) and C290-6 circuit 57 (BK).
  • Is the resistance less than 5 ohms at both pins?
Yes
GO to D9 .
No
REPAIR the open circuit. TEST the system for normal operation. D9 TEST SWITCH
  • Connect fused jumpers between C290-1 and -2 and between C270-7 and -3.
  • Does the adjustable pedal motor run in both directions?
Yes
INSTALL a new adjustable pedal switch. TEST the system for normal operation.
No
GO to D10 . D10 CHECK SWITCH-TO-MOTOR CIRCUITS CONTINUITY
  • Connect: Adjustable Pedal Switch C290.
  • Disconnect: Adjustable Pedal Motor C2001.
  • Measure resistance to ground at both pins of the adjustable pedal motor connector, circuits 1494 (RD) and 1495 (WH).
Apr 24, 2009 | 2003 Mercury Grand Marquis
Cycling Logo
139 people viewed this question
Top Pedals Cycling Experts
ray gallant
Donald Ayers-Marsh
Are you a Pedals Cycling Expert? Answer questions, earn points and help others
