Question about EuroTech EDV278 Extra Large Dryer
DRYER EDV 278 EL noise when drum turns sounding like the squeak of a slipping belt. Dryer drum has difficulty getting started with a medium load.
  • prefonr Oct 07, 2009
    will know once I try it.
    solution proposed was a generic answer probably valid for most dryers. However, the Eurotech EDV 278 EL does not have an idler pulley. The 3/4 inch (approximately) belt is just tight on the drum and driven by the motor shaft, it is so small that there does not appear to be a pulley, just a groved shaft.
    I checked the back center support for the drum and it appears fine with still some grease on it.
    I now suspect that the sound is more of a rubbing one that could be caused by the drum supports at the front of the drum.
    My question is how do I get to those supports? If I was able to download or obtain a parts manual with the maintenance procedures I may be able to identify and rectify the problem without taking the dryer to a repair shop.
  • 6,784 Answers
Hi. i recommend inspecting the idler pulley. This will likely be the culprit.
Access to the idler pulley varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
When reaching into the dryer be careful of sharp edges on the cabinet and interior supports. Reach in to the belt and give it tug. It should be taught and have only a little give. The belt should go under the idler pulley and over the motor pulley. Lift the idler pulley toward the motor to relieve tension on the belt and remove it from the motor pulley.
Turn the idler pulley wheel, it should turn smoothly, quietly and without any wobble. Inspect it for cracks or uneven wear. If the idler pulley does not maintain proper tension or is damaged it should be replaced. Depending upon your model, the entire assembly or just the wheel or bearing may be replaced.
Posted on Oct 07, 2009
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer has started a squeak, squeak, squeak noise as the drum is turning. What could it be?
Hi kitchen nich...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers are in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Aug 06, 2011 | Dryers
Dryer squeaking badly during cycle. drys fine but noise is loud.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
When you put a load in to dry,and turn it on.it starts to make a high pitched squeaking noise when the drum is turning.
If you have a front loading machine.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical consol with stay with the lid.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Sep 18, 2010 | Dryers
The dryer was making a horrible squeaking sound, the drum stopped turning, so i took it apart, but the belt was not broken and the wheels seemed to be ok, so i put it back together and the drum still...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections.
Remove the lint filter screws and filter.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Aug 25, 2010 | Maytag MDE9206 Dryer
My GE Dryer Model # dx4500ee1ww makes a load squeaking noise?
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.Also remove the screws holding the lint filter in place.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Aug 10, 2010 | GE DBXR463EDWW Electric Dryer
My clothes dryer squeaks when it runs. If I dry
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Thank you
May 19, 2010 | General Electric DCVH640GJ Gas Dryer
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
My Maytaag dryer has a loud intermittent squeal. It will often work for 10-15 minutes with a quiet squieak or no noise, then the loud squeak starts up. I can turn the dryer off, but the squeal immidately...
I think the drum drive belt is slipping because it occurs more with a large load. Other possibilities are: A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Sep 21, 2009 | Dryers
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
EuroTech EDV278 Extra Large Dryer Logo
Top EuroTech Dryers Experts
Tim Whalen
Colin Stickland
Colin Stickland
Are you an EuroTech Dryer Expert? Answer questions, earn points and help others
