Question about Cisco 7941G-GE IP Phone
I have a 7941 and the receiver has no dial tone. The speaker worker, which is the only way I have to cimmunicate. Are there any troble shooting tips available?
There's no dial tone -- what do I do to fix this?
It's possible the "tip" and "ring" are reversed, sometimes that'll block dial-tone. Try another jumper between your wall jack and the phone. You should also try a different phone plugged into that jack to make sure it's ok.
Nov 14, 2014 | Lands Phones
How do i set my fax machine to recieve and send faxes
Dear
Connect the telephone line to the LINE socket of the fax machine and a telephone receiver unit to the EXT socket of the fax machine.
To send a fax, put the document on the platen glass (face downward) or face upward in case of ADF.
press on hook dial, (here the dial tone on machines speaker)
dial the fax no. ( wait for call connection and here the fax Rx. tone)
press START.
To receive a fax two procedure can made, manual- lift a hand set of telephone receiver on incoming ring, here the TX tone(periodical beep tone) press * 9 * of the telephone receiver. In auto mode go to fax setup select ans. to ring or auto fax etc. to activate atuo reveive of fax.
Hope this may helpful.
Thanks.
Aug 11, 2014 | Samsung SCX 4521F All-In-One Laser Printer
M7310 Non-Stop Dial Tone
Intercom button/s provide dial tone when they are pressed. They are required to call other phones on your system.
Sounds like your button is stuck or issue with the motherboard.
Dec 17, 2012 | NorStar Meridian M7310 Phone
I'm experiencing a problem with cisco 7941 IP phone. here is the current condition of the phone: it has no dial tone, the programmable button is alternately blinking, the headset button has a steady...
can you explain me how is your phone connect to internet.
best on your Question its seems to me you cant hear a dial tone because of following one or more factors might apply
  1. you must log into the Extension Mobility service
  2. you must enter a client matter code (CMC) or forced authorization code (FAC) after dialing a number
  3. your phone has time -of-day restrictions that prevent you from using some features during certain hours of the day
Sep 21, 2011 | Cisco 7940 IP Phone
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
Change from pulse dial to tone dial.
You will find a small switch on side of phone that says Pulse - Tone, choose Tone..
Jan 26, 2010 | Lucent 9110 Single Line Telephone
When I hit hook to send a fax I hear a click but I get no dial tone and the same on receiving a fax MP830
You only hit hook to hear the dial tone or use the machine like a speaker phone. To send a fax you press fax start. If you can't hear a dial tone when you press hook, there is something wrong with the phone line connection, or it's plugged in to the wrong plug on the machine. The phone line goes into the one marked with an L, the other with the pic. of a phone is for an additional telephone.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
No dial tone on receiver only on voice
make shure handset cord is Not pluged in to the Headset jack on the bottom, needs to be in the handset jack (look at the icons)
Jan 29, 2009 | NorStar Meridian M7310 Phone
No dial tone unless on speaker
Suggest you check battery in non working handset is connected and charged. If this is ok, suggest you check this handset is registered with the base station, as out of the box they arent always set to the same channels
Jan 25, 2008 | Lands Phones
Cisco 7941G-GE IP Phone Logo
567 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
