Question about Garden
Yard brush trimmer 6.0hp. stalls under load. Runs smooth while idle. As soon as it hits the grass it stalls out.
  • michael buchanan Oct 07, 2009
    This wasn't my posted issue. You may have responded to the wrong post. My issue is that my machine runs smoothly at idle and starts easily. it is when a load is applied such as when the trimmer is pushed into grass that it stalls. take note that this is a 6.0hp 4stoke push type brush string trimmer. not the typical shaft grass trimmer.
5 Suggested Answers
bbreton
  • 437 Answers
SOURCE: will not idle
May be time to get the carburetor rebuilt. Sounds like the diaphragms are not working properly to pump fuel. You may need some lubrication on the throttle cable too. A little lubrication on the throttle arm would not hurt.
Good Day.
Posted on Oct 14, 2009
SOURCE: My Homelite grass trimmer idles fine but when I
Give it 10 seconds run on middle choke turn it to run and dab the throttle on and off as quick as you can until it runs normally. Helpful in the cold too .
Posted on Jul 29, 2010
  • 2239 Answers
SOURCE: echo trimmer srm230 runs but will not rev to cut grass
Check the spark arrester in the muffler out let is no blocked with carbon, remove the muffler and check the exhaust port itself is not carboned up.
Posted on Jun 04, 2012
  • 6468 Answers
SOURCE: troybilt trimmer misfires under load, runs smooth with no load
try mixing a new batch of fuel/oil mix gas is only good for 30 days in small engines
Posted on Aug 11, 2012
Setting the rpm
To identify the idle screw adjustment push in and and out with the gas throttle handle and look at the carburetor for a little finger that moves in unison with your movements. That finger comes to rest against a tapered screw - the latter is the idle adjustment. Clockwise increases the speed and vice versa. Adjust so unit runs smoothly at low speed - too slow and it will stall. Experiment.
Nov 22, 2013 | Craftsman 25cc Gas Line Trimmer
It starts and runs for a bit but as soon as it hits thicker grass it dies
Joe Hi there. Sadly your trimmer will struggle on thick grass as it's not made for it. You could try moving the trimmer like a scythe. This will aid it as your cutting bit by bit.
Sep 27, 2013 | Husqvarna 28cc Gas Line Trimmer
Toro parts
Probably your carb needs adjustment.There are usually 2 jets on those carbs, one for the start and idle, the other for the power load. Use your manual to find the power jet adjustment screw, then follow directions to turn the adjustment screw in 1/4 turn increments until it doesn't stall under load. If you don't have the manual go to: www.shoptoro.com
Find the manual download for your model.
Wish you the best!
Sep 21, 2013 | Heavy Machinery
Troybilt trimmer misfires under load, runs smooth with no load
Jul 15, 2012 | Garden
1990 1500 runs good when cold but when it warms up rough idle then stalls
Remove the EGR you have carbon,that is keeping the pintle open,if there is no carbon and the pintle is open replace it.
Mar 10, 2012 | 1990 Chevrolet K1500
CLEAND CARB NEED TO KNOW HOW TO ADJUST CARB
Most carbs have the adjustment removed (EPA) but if yours still has the adjusting screws here are the seat of the pants methods:
One Screw Carb: Turn it all the way in and then back out 3-1/2 turns, start the engine and make slight turns in or out until the motor runs smooth from idle to wide open, do not get it too lean, turn in until max RPM is reached then turn out 1/8 turn and go from there.
Two Screw Carb: You adjust the one to remedy either the low or high, high is adjusted until the motor runs smoothly under load at high RPM and the low is adjusted until idle and off idle is smooth.
Feb 27, 2010 | Troy Bilt Tb70ss Gas Trimmer
HC-1500 hedge trimmer runs at high speed,but not at low
The first thing to do, is to clean the air filter, and remove the plug, and clean with a wire brush, if neccesary.
You should also bear in mind, that the timing may well, be in need of retarding, ever so slightly.
If problem still persists, you known where we are.
Jul 25, 2009 | Garden
Weed eater GTI 17 won't run on high speed
A couple of things may work...
Make sure you have the correct Oil / Fuel mixture, if it is incorrect the motor may have problems running.
Also take off the bottom where the cord is wound up, make sure there hasn't been any grass get wound up inside it, this will cause it to stall out on high RPM.
May 19, 2009 | Poulan Genuine Weedeater Part # 36006-128
Only runs ruff during park and idle.
Your EGR valve shouldn't open up during idle or the engine will run rough and may even stall. Remove it and clean the plunger and port with a wire brush and some carb cleaner. Test the diaphragm with a vacuum pump. If it doesn't work after cleaning, or the diaphragm is bad, buy a new EGR valve.
Feb 06, 2009 | 2001 Mercury Cougar
Garden Logo
35 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
