Question about Cameras
What is the maximum size SD card i can use with the vq815s camera.
SOURCE: Olympus C450 Zoom
watch out, c450 support only up to 512Mb xd cards
Posted on Jun 09, 2008
SOURCE: Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
Posted on Aug 13, 2008
SOURCE: Kodak c310 camera won't format new SD 2GB card old card same size
Older C310s won't take that large a card. Try to exchange it for a 1 GB or smaller. I had the same problem - a PNY 1 GB works fine
Posted on Apr 15, 2009
leepania
  • 1099 Answers
SOURCE: Can't format 8 GB SD memory card
The camera doesn't support this memory card.
Memory card support : SD/MMC up to 2 Gigabyte only.
Sorry you will have to downsize.... :)
If helpful pls. rate me and/or recommend me TXS
Posted on Dec 03, 2009
  • 102366 Answers
SOURCE: what is the maximum size sd card for a Pentax
The A10 accepts SD cards, which max out at 2Gb. The 4Gb card is actually an SDHC (Secure Digital High Capacity) card, not an SD card, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
Posted on Jan 07, 2010
Whats the maximum size sd card can my camera take
That depends on the make and model of the camera.
SD cards max out at 2GB. If your camera can take SDHC cards as well, you can go to 32GB. If your camera also can take SDXC cards, you can potentially go to 4TB, though no one actually makes SDXC cards that big yet.
Sep 22, 2014 | Cameras
What is the maximum size of a SD memory card that the Philips digital photo display model 9ff2 can support?
The maximum size of an SD card is 2GB, and the 9FF2 will support SD cards of that size. The 9FF2 will not support SDHC cards, which start at 4GB and go up.
Mar 29, 2012 | Cameras
What is the maximum size of an SD card that can be used in a Canon PowerShot A510?
You can use any size SD card. Just keep in mind that SD cards max out at 2GB; any larger cards are actually SDHC cards and will not work in the A510.
Feb 05, 2011 | Canon PowerShot A510 Digital Camera
I want to know maximum card (SD and SDHC) that can be used with Canon Power A550 Camera.
The maximum size of SD cards you can use is 2GB since SD cards max out there. SDHC cards max out at 32GB. The camera itself does not impose any limits on those two types. In short, you can use any SD/SDHC card.
Oct 18, 2010 | Cameras
What ext. max size of memory for cd14
According to Kodak, your camera will support the use of SDHC cards up to a maximum capacity of 32GB. It will also accept any capacity of SD card up to the maximum SD format size of 4GB.
Please take a moment to rate my answer.
Sep 16, 2010 | Kodak Cameras
What is the maximum SD size that will work with the DSC-4500Z camera?
The manufacturer of your camera specifies SD card compatibility without providing a specific number. This is not uncommon however, as the maximum size for SD cards is 2 GB. Cards that have a larger capacity than 2 GB in the "SD" format are "SDHC". Read the label of these cards (that have a larger capacity than 2 GB) that *look* identical to SD cards, and you'll see that they are in fact SDHC types. The SDHC card can have a capacity of up to 32 GB. A device that is compatible with the SDHC specification should be able to read any SDHC card *and* any SD card as well; because the standard requires "backward compatibility" to the older SD standard. A device that accepts SD cards should be able to read any SD card, *but* if an SDHC card be introduced to it, it may provide unreliable results (from being able to access only 2 GB of the capacity or not recognizing the card at all). Make sure your pictures are safe and don't get lost; use only SD cards in this camera.
I hope this helps!
Jun 08, 2010 | Apex Digital Digitrex DSC-4500Z Digital...
What is the maximum size to use for an sd card for lumix dmc tz3
The maximum size SD card you can use is 2GB because that is the maximum size SD card you can buy. Cards bigger than that are SDHC (Secure Digital High Capacity) cards. Fortunately the TZ3 is capable of using SDHC cards of 4GB and larger.
Apr 13, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
What is the maximum SD memory card size that a Canon 510 and 520 Powershot can use?
Recommended by factory is up to 512 MB, that will work for sure.
It should support up to 2GB card, supporting cards thet have SHDC technology.
Before buying a 2 GB card, I would go to the shop and test it on the camera, so that you are sure it works.
See the forum here :
PowerShot A510 maximum SD card size - Digital Camera Forums
Sep 29, 2008 | Canon Cameras
May 17, 2008 | Pentax Optio S5n Digital Camera
Cameras Logo
42 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
