Question about Peg Perego John Deere Gator HPX Ride on Toy
Having trouble with gears staying in the right spot and will not run at all at times. Also this was handed down. It is about 3 years old. Battery still charges but should we buy a new battery? Also possibly could need new tires. Main trouble is with the gears. Will not run at all right now.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
You can order a new shifter switch here www.powerwheelsoutlet.com
Posted on Jun 13, 2012
  • 156 Answers
SOURCE: Peg Perego 800 Twin ATV - Only runs for 10 - 15 minutes at a time
Go ahead and charge it for 24 hrs. If it still does not run contact the repair department at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.htmlthese guys (and gals) help me out all the time.
Posted on Jun 03, 2009
riceski
  • 1851 Answers
SOURCE: 2004 model won't run. Brand new battery. I need
Try this one - -
http://www.pegperego.com/pegcatalogue/toys/downloads/JD%20Gator_FI000901G24.pdf
Posted on Apr 01, 2010
SOURCE: Ranger on a full charge stops working within 5
I have the same problem. My son rides his on high and when he stops, it sometimes does not want to work again for a few minutes. When he pushes the pedal, it makes a clicking sound in the gear-box area (like an electric switching sound).
Posted on Aug 05, 2010
  • 670 Answers
SOURCE: After charging, will only go
It's unlikely the problem would be caused by a faulty gear shift switch. When you have a switch problem, it usually does not go or it runs intermittently. A new battery should fix your problem especially if it a couple years old, or you have not charged it up every couple of months to maintain the battery.
Posted on Sep 01, 2010
Samir3050
  • 70 Answers
SOURCE: We charged the battery on my daughter's gator but
The shifter switch has gone out, they go out alot. The price is not bad to replace it, and you can find it at mypegperegoparts.com . It is not the battery though.
Posted on Mar 08, 2011
THE 1995 CHEVY TAHOE WANT STAY STARTED.
Hi Dottie,remove battery,take to Walmart in the automotive,they will test for free,I get my batteries from there.Your battery is real week,mine was too,got it from Walmart,a 5 year warranty,it lasted 6 years and 3 months.Got another,called ever-start.
Nov 05, 2013 | Chevrolet Blazer Cars & Trucks
Piston Rings are Gone Cheaper to replace the mower.
Jul 15, 2013 | Garden
I am having trouble taking the old speed feeder head off the weed eater to replace it with a new one.
If you are trying to loosen the nut, the nuts are threaded to stay tight when running and may well be LEFT hand threaded, so you will need to turn to the right to loosen.
Jul 09, 2011 | Garden
We have been traveling for 7 hours today in our 2001 Ford Taurus. We had no problems; car did not run hot, got great gas mileage. We made it to our hotel and not the car will not start. It will crank but...
Sounds like the battery is old and got hot from all of the use and charging that was put on it. Next time you drive the car a bit, check the battery with your hand. Be careful it may be really hot. If it is too hot to touch, replace it.
Oct 09, 2010 | 2001 Ford Taurus
Timer will run when flipped on manually
THE YELLOW DIAL MOVES THE HAND STAYS IN THE SAME SPOT POINTED DOWN AND NEVER MOVES, THESE ARE A TUFF TIMER AND TO SET IT YOU MUST LIFT OUT ON THE YELLOW DIAL TO SET THE TIME AND THE DIAL SHOULD SPRING BACK TO THE GEAR TO RUN , MAKE SURE THE DIAL IS SET IN THE GEAR BY TURNING LIGHTLY LEFT AND RIGHT . LOOK ON THE BACK OF THE TIMER MOTOR AND MAKE SURE IT THE 208 - 277 VOLT . IF THATS THE VOLTAGE YOU ARE NEEDING FOR YOUR PUMP ONE MORE THING MAKE SURE THE GEAR FROM THE MOTOR IS MESHING WITH THE BIG GEAR THAT RUNS THE TIMER, THESE TIMERS GET RETURNED TO THE STORE WITH A BAD MOTOR IN THEM AND THEY JUST STICK THEM BACK ON THE SHELF.. IF YOU NEED A NEW TESTED ON I FOUND THEM HERE..YOU CAN LOOK THREW THE LITTLE WINDOW TO SEE THE GEARS TURNING ON THE CLOCK .. IF NOT ..Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIX ON EBAY TO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ. .. VOTE PLEASE THANKS... JAY
Jan 09, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Having trouble locating were the transmission
Looking at the car from the front, the dip stick for the transaxle is down very low at the left hand side of the engine, close to being under the battery. It is normally yellow. Follow the large water hose that runs down next to your battery. The yellow dip stick handle is right along side of that hose (to the right of it) down low. It will either pull out or unscrew.
Hope this helps you.
Nov 15, 2009 | 1993 Honda Accord
Panasonic 52LCX65\PT Green Spot
COLOR CONVERSION IN THE MENU ,,TRY THAT,,IF NOT A NEW CABLE,,CONVERSION REALIGNS THE COLOR
Apr 17, 2009 | Panasonic PT-52LCX65 44" HDTV
Synchronizing
This is user-correctable.
See manual page 4, titled "Synchronization".
1. Press T button
2. touch center until you see the 24h/units
3. hold down T for 5 seconds until you see "Synchro" in the LCD.
4. use the + button to move the long hand to 12 o'clock, use the - button to move the short hand to 12 o'clock
6. press T button to commit settings.
Hands will move to agree with the time in LCD.
Dec 06, 2008 | Tissot T-Touch T33759851
Wouldn't stay running when put in gear.
When you unplugged the Throttle Position Sensor you made the computer go into panic mode and try to compensate for the loss. The fan might be thinking your engine is idling so it needs more fan. Even after plugging it in it probably will ignore it. I would try removing, without zapping yourself, the positive cable off your battery and let it sit for a bit to reset it's internal memory. If that don't work you might need a dealer to do the reset or it means the sensor was going and is now gone. Hope that helps.
Nov 05, 2008 | 1997 Chevrolet Cavalier
Philips 300wn5 green stripe on screen
I have a similar problem, what is the fix?
Mar 23, 2008 | Televison & Video
Open Questions:
See all Peg Perego John Deere Gator HPX Ride on Toy Questions
Peg Perego John Deere Gator HPX Ride on Toy Logo
35 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
