Panasonic KX-T7453 Corded Phone Logo
Posted on Oct 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Check voicemail button won't work - Panasonic KX-T7453 Corded Phone
Carl Navarro
Level 3:
  • Panasonic Master 2,460 Answers
  • Posted on Oct 08, 2009
Carl Navarro
Panasonic Master
Level 3:
Answers
2460
Questions
Helped
1155796
Points
7314
A couple of reasons:
If you're using the MESSAGE button and you have no messages, the button won't dial anything.
You may have had a VOICE MAIL button and it became unprogrammed.
You have no voicemail system, or it became unlinked.
If your Panasonic brand voice message system is working, as in taking messages, but your phone is not able to get them, the default access code is 165. Try dialing that on the intercom and see if it goes to VM.
If you need to reprogram the button, try PROGRAM 99 press the button and dial 2165 STORE if the button has a light or just 165 STORE if it doesn't.
If you've unlinked your MESSAGE light, that's a different animal and you need to post back as a comment for a solution.
Carl
1helpful
Message light flashes all the time. Sometimes incoming calls won't work.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
As for incoming calls, are they possibly going to the aforementioned voicemail system?
1helpful
How do you check work voicemail from home
When your work phone answers, dial #6 * and your extension. It will be just as if you had pressed the MESSAGE button from your desk phone.
3helpful
My voicemail stopped working. The phone rings and rings but doesn't go to voicemail.
Press Speaker
Dial *6
Enter Voicemail # (will appear on screen if you hit your voicemail button)
Press Speaker again
2answers
How do you extend ring time on a mobile phone
you cant they are pre programmed to run long enough for the caller to hear 4-6 rings before going to voicemail
1helpful
My panasonic kx-t7431 message light won't light up, I have voicemails but it will not light up, please help!
With the headset off, push the intercomm button or SP-PHONE button, then once you hear the speaker is on do do this.
Push the STAR sign which is * and then number 700 and your four digit extension.
For example ( *7000422).
FSK Voicemail Indicator not working
When you press the voicemail button on your phone it is retrieving messages stored internally in your phone. Verizons Voicemail is a seperate entity where the message reside on the server. If you do not want to use the Verizon Voicemail, simply call the business office and ask them to remove voicemail completely from the account. That way your phones internal answerming machine whille then catch all the voicemails and you can go back to using your voicemail button to listen to them. Hope that helps you and everyone else out.
Tony T.
Cannot Transfer Voicemail
From the phone.
Feature 00
press the button
press Feature 14
feature 00
3helpful
3answers
Voicemail does not work
Had the same problemwith my iPhone 3G this is how I fixed it -
1) From the iPhone 3G, I called my own iPhone 3G number.
2) Went through the setup. After finishing the ssetup Hang off the iPhone 3G.
3) Then the voicemail button on the iPhone 3G worked - first time, there was a **** pause, it asked me to enter my voicemail password that I had set in step 2, and that's it.
Good luck.
Voicemail reset
Norstar Common Voicemail Features To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
took this from a guide i found, helped me out
2answers
Resetting company voicemail
4. Leave message
took this from a guide i have, might help you guys out
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
