Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
Cycles off and indicates high pressure limit - Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
    Problem Solver:
  • 12 Answers
It is eather the filter is dirty or the high limit pressure switch is out..Clean the filter if that doesnt work remove the front door and youl see a theromstat looking switch on the left side in the middle take the two wires off of the switch and jump with a wire and turn on the heater if it fires and runs replace switch..........problem solved
Posted on Oct 08, 2009
What is causing the P0300 random misfire code on my 2001 Mitsubishi montero limited (not sport)?
misfires are for faulty electrics ---plugs, HT leads, distributor coils ECM but they are also from low fuel pressure , faulty injectors, faulty injector wiring
now you say at 5300 rpms is at the top end range so items to check are the fuel pressure ( should be at around 55-65 psi constant) fuel flow (filters , EVAP venting problem
Plugs with excessive gap, Low quality HT leads or faulty leads --excessive resistance is stopping spark at high pulses
ignition control module --failing at high cycles and coil or coils not good enough to handle the high cycles
If you have a distributor , then it may be worn bushes in the distributor that is initiating the misfire by not running true in the housing causing the rotor button to be missing spark for certain leads
May 12, 2016 | Cars & Trucks
I am getting the following codes on my 2002 Nissan Altima v6 3.5 liter P1430, P1420, P1805, P1152, P1102, P1011, P1021 & P1335 I'm going crazy here. Please help!
Definition of Diagnostic Trouble Code P1430 Ford: Electric Air Pump Secondary Lincoln: Electric Air Pump Secondary Mazda: Electric Air Pump Secondary Mercury: Electric Air Pump Secondary Toyota: Intake Constrictor CTRL Circuit Open or Short
Definition of Diagnostic Trouble Code P1420 Audi: Second Air Injection Valve Circ Electrical Malfunction BMW: Secondary Air Valve Control Circuit Electrical Buick: Intake Air Low Pressure Switch Circuit Low Voltage Cadillac: Intake Air Low Pressure Switch Circuit Low Voltage Chevrolet: Intake Air Low Pressure Switch Circuit Low Voltage Chrysler: Register Resonant Charging 1 (RRC1) Dodge: Register Resonant Charging 1 (RRC1) Ford: Catalyst Temperature Sensor GMC: Intake Air Low Pressure Switch Circuit Low Voltage Honda: Nox Adsorptive Catalyst System Efficiency Below Threshold Catalytic converter Jeep: Register Resonant Charging 1 (RRC1) Lincoln: Catalyst Temperature Sensor Mazda: Catalyst system efficiency below threshold (bank 1) Mercedes: AIR Pump Switch over Valve Mercury: Catalyst Temperature Sensor Oldsmobile: Intake Air Low Pressure Switch Circuit Low Voltage Pontiac: Intake Air Low Pressure Switch Circuit Low Voltage Saturn: Intake Air Low Pressure Switch Circuit Low Voltage Subaru: EVAP Purge Control Solenoid Circuit High Input Toyota: SCV Control Circuit Malfunction Volkswagen: Second Air Injection Valve Circ Electrical Malfunction
Definition of Diagnostic Trouble Code P1805 Ford: Four wheel drive high indicator circuit failure Lincoln: Four wheel drive high indicator circuit failure Mazda: (4WD) High Indicator Open Circuit Mercury: Four wheel drive high indicator circuit failure Toyota: SB Solenoid Circuit Malfunction
Definition of Diagnostic Trouble Code P1152 Audi: Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded BMW: Oxygen Sensor Heater Circuit Low Voltage (Bank 2 Sensor 1) Ford: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Jaguar: Lack of H02S-21 switch, sensor indicates rich Land Rover: Oxygen sensor response time bank 2.Short circuit to ground Lincoln: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Mazda: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Mercury: Lack Of Heated Oxygen Sensor Bank 2 Sensor 1 Switches - Sensor Indicates Rich Subaru: Oxygen sensor range /performance problem (Low) Volkswagen: Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded Volvo: Oxygen Sensor Front, Bank 2
Definition of Diagnostic Trouble Code P1102 Acura: Mass Airflow (MAF) Sensor Lower Than Expected Comprehensive Audi: Oxygen Sensor Heating Circuit,Bank1-Sensor1 Short to B+ Chrysler: HEV Stop Request Performance Dodge: HEV Stop Request Performance Hyundai: MAP Sensor Circuit Low Input Jeep: HEV Stop Request Performance Kia: Heated Oxygen Sensor Bank 1 Sensor 1 Heater Circuit High Input Land Rover: Throttle to air flow plausibility not active.Last occurrence - minimum signal Mazda: Mass Air Flow Sensor In Range But Lower Than Expected Mitsubishi: Traction Control Ventilation Solenoid Circuit Porsche: Heated Oxygen Sensor 1 Ahead Of TWC Heater Short To B+ Saab: Front Heated Oxygen Sensor Bank 1, Control Module Input, Current in Pre-Heating Circuit Too High Subaru: Pressure Sources Switching Solenoid Valve Circuit Malfunction Volkswagen: Oxygen Sensor Heating Circuit,Bank1-Sensor1 Short to B+ Volvo: Power Stage Group B
Definition of Diagnostic Trouble Code P1011 Saab: Injector Cylinder 1 Shorting To Ground Toyota: OCV for VVTL Open Malfunction (Bank 1)
Definition of Diagnostic Trouble Code P1021 Honda: Valve Pause System Stuck On Comprehensive Mitsubishi: OCV OPN. Bank 1 Saab: Injector Cylinder 2 Shorting To Ground Toyota: OCV for VVTL Open Malfunction (Bank 2)
Definition of Diagnostic Trouble Code P1335 Audi: Engine Torque Monitoring 2 Control Limit Exceeded Buick: CKP Circuit Cadillac: CKP Circuit Chevrolet: CKP Circuit Ford: (EGR) Position Sensor Minimum Stop Performance GMC: CKP Circuit Infiniti: CKP Sensor (Ref) Jaguar: CKPS Circuit Malfunction Land Rover: Exhaust gas recirculation position sensor minimum stop performance. Lexus: Igniter Circuit Malfunction Bank 2 (During Engine Running) Lincoln: (EGR) Position Sensor Minimum Stop Performance Mazda: (EGR) Position Sensor Minimum Stop Performance Mercedes: CKP Sensor Circuit Malfunction, Bank 2 Mercury: (EGR) Position Sensor Minimum Stop Performance Oldsmobile: CKP Circuit Pontiac: CKP Circuit Saturn: CKP Circuit Toyota: No CKP Sensor Signal Engine Running Volkswagen: Engine Torque Monitoring 2 Control Limit Exceeded http://www.obd-codes.com/trouble_codes/nissan
Jun 29, 2015 | Nissan Cars & Trucks
What is means po961 exactly
PO961Is Pressure Control Solenoid A Control CKT Range/Perf.
Feb 25, 2015 | 2004 Chevrolet Monte Carlo
Drier not hot enough when i set temperature to high position
Replace the high limit thermostat located on the top of the heating element housing. Here is the part to order.
Nov 18, 2012 | Frigidaire GLER104FSS Gallery Series 27...
My ac unit will come on for a minute then turn off for a minute, it keeps repeating this action. What is the problem?
Check the refrigerant pressures. it may be turning off from low or high pressure limits with automatic resets. If you have a digital thermostat, there is a programming function in the installation instructions for setting the AC cycles per hour. If the AC is oversized, it will short cycle.
May 20, 2012 | Bryant Heating & Cooling
Does not heat as fast as it used to. Has to run for two cycles before it gets warm.
Check for a partially burnt heating element or a faulty high limit thermostat. The high limit thermostat is a round device mounted on a metal plate and is usually attached to the internal ductwork. Check the heating element for any sign of burning or broken wire. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a bad heating element. The high limit thermostat can be checked in the same manner. It should have no continuity. I will attach a photo of a thermal cutoff and high limit thermostat for reference. Hope this helped and best wishes.
Sep 07, 2009 | Dryers
HAYWARD POOL HEATER FIRES FOR 5 MIN. THEN GOES OUT
Sounds like it is cycling on high limit; causes are related to water flow through the heat exchanger or a faulty high limit(doubtful given the heater cycles back on). Check the internal bypass for obstructions; has anyone worked on it recently? There are usually two high limit switches with different trip temperatures; installing the wrong one could also be the culprit. Does the heater "bang" before it goes off (a sign that the water is boiling inside the tube bundle)?
Jun 27, 2009 | Hayward H Series Induced Draft Abg 100,000...
H250 cycles on and off pressure is fine. system normal light on. new sand and clear pool. would like to know how to fix problem myself.
I would probably look at your high limit switches first and then at the bypass assembly inside of the header. The bypass controls the heat rise inside the heater. If it is bad, it may heat up too quickly, opening up one of your high limits. That will shut down the heater, once it cools back down, it will start again, and so on and so on.
May 18, 2009 | Hayward 250kbtu Ng Pool Heater - Inground
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
357 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
