Question about Whirlpool LER5636P Electric Dryer
I took my dryer in for repair for not heating, upon return I got one load dry and now its not heating again. I checked vent from dryer to outside and all clear also.
    Novelist:
  • 121 Answers
If the servier u used replaced the heater t_stat . then possibly your vent is clogged . and it caused the thermostat to blow again. everyone always says vent clean. but it should be cleaned out proffesionally every year. i would take it back to them, also if your vent goues straight outside then that may not be the problem however if your vent goues up and out through the roof then im sure its the vent. take it back to them if it is the thermostat again, then defenitly have your vent cleaned out. hope this helps. sound like a thermostat or a heating element problem.
Posted on Oct 07, 2009
  • Whirlpool Master
  • 7,482 Answers
Call the repairman that did the repairs, I am sure he will stand behind his service.
Good Luck,
I hope this helped
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
Too long to dry my clothes
HI,
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Jul 01, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool dryer, it takes 2 or 3 cycles to dry a full load, the clothes are warm and when I disconnect the rear exhaust and turn it on it blows pretty good, it never took so long to dry the clothes
check the vent hose to the outside,especially if there's been siding installed on the house and the vent has one of those plastic guards by the outside exhaust,for keeping birds out,this can plug around the vent and build up with wet lint,run it without the hose on and see if drying time comes down to normal again,then you know the outside vent is the problem
Jan 26, 2010 | Dryers
Our model medt5870tw0 maytag dryer does not dry properly
First , remove the vent hose from the dryer to see if good air flow is coming out the dryer vent . If not , could have a bad blower wheel . If so , then check the vent hose AND vent to outside to see if blocked . A dryer will either heat or not heat . Since your dryer heats , try drying a load without the vent hose connected to the dryer and see if it heats fine (telling you , a vent problem is apparent . Sometimes a dryer is pushed too far back , kinking the vent hose also .
Aug 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer is not drying clothes as quickly
Hello. I will briefly state all of the possible reasons why your dryer is slow but I will first say that the common reason under the circumstances you state is that the vent pipe is either partially clogged with lint, or partially blocked, or it has more bends and turns in it than you had in your previous residence. I would begin by pulling the dryer out, removing the vent pipe and checking inside the back of the dryer and in the vent pipe all the way to outdoors.
Vent
Heating element
Internal ductwork
Cycling thermostat
May 31, 2009 | Dryers
THE DRYER TAKES TWO TO THREE HOURS TO DRY ONE LOAD
Vent
Heating element
Internal ductwork
Cycling thermostat
May 20, 2009 | Dryers
Will not dry clothes fully. the machine heats fine but it takes two or more cycles to fully dry a little load. someone told me about a part that may need repaced around the lint trap.. Any ideas?
Your lint exhaust is blocking the heat flow.
Remove the vent from the rear of the dryer and run a timed cycle load for 40 minutes.
If laundry is dry, repair the outside vent.
If not dry,open the dryer cabinet and clean the inside lint and heat vent.
Mar 05, 2009 | Kenmore Dryers
Frigidaire dryer heats but clothes not drying
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
Nov 23, 2008 | Frigidaire GLER642A Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Oct 22, 2007 | Dryers
Whirlpool LER5636P Electric Dryer Logo
61 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
