Question about HP PSC 2210 All-In-One InkJet Printer
HP Psc 2210 powers up for around 5 secs then switches off
Starts up with a self-test and then cuts our after a few seconds, if I hold the # and 6 keys while powering up I get a message saying the button is pressed, this message can stay on for ages, so I'm sure the transformer is not fried, not sure what else to try, any suggestions?
Unplug both ends of the power cord and count for about 60 seconds. Then plug back in. See if that works. That's what HP told me when I called customer service.
Posted on Oct 08, 2009
SCANNER FAILURE
The issue is with hardware of the printer.
Scan feature is most expensive and sensitive part of the printer.
I suggest you to contact HP support. If the printer is under warranty you may get a replacement printer or else they may give you a better option.
If not on warranty you may try this workaround:
  1. With unit off, press the 'Cancel' (pink button) and 'Color' (green button).
  2. This will start the printer in a diagnostic mode. Press '1' to run the diagnostics.
  3. Press 'Enter' or other keys as directed by the display prompts. When you don't know what to press, the 'Enter' key usually works. Some of the keys called for (for example 'Plus' and 'Minus') are not on every psc 2210 keyboard. They are mapped to one of the "directional" keys just above the numeric keypad area next to the 'Enter' key. Keep trying keys till one works.
  4. After all the diagnostics, the display will either go blank or display 'Initializing...' . Wait 10-20 seconds to make sure it isn't doing anything else then press the 'On' key.
The printer should start without the scanner error and the grinding/chattering noise.
Leave the printer on because the next power cycle brings the chattering noise back.
But, when it does, the procedure above seems to fix it every time.
PSC 2210 scanner failure HP Enterprise Business Community
Feb 18, 2014 | HP PSC 2210 All-In-One InkJet Printer
Hp psc 2210 printer starts but locks up at the beginning of the print cycle and issues a open top and press enter message this does nothing but start the process over
Perform a reset on the printer.
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Jun 21, 2010 | HP PSC 2210 All-In-One InkJet Printer
Self test flashes for a few seconds comes when power is connected and then power is lost
check us power cable that is ok? and also check ur usb cable which is connected with the pc. if power cable is ok then i think its ur hp power button fault. then repair ur power button. then it become ok
Aug 03, 2009 | HP PSC 2210 All-In-One InkJet Printer
Self-test issue with HP psc 2210 all-in-one
No fix, a new scanner will cost as much as a new machine IF you could find a new scanner assy
Feb 20, 2009 | HP PSC 2210 All-In-One InkJet Printer
Stuck in warming mode.
Re-initialize the HP all-in-one
Force the HP all-in-one to reinitialize by following the steps below:
1. Turn the unit off by pressing the ON button.
2. Disconnect the power cord.
3. Wait five seconds, then reconnect the power cord.
4. but before plugging the unit back in, press and hold the # and 6 keys on the HP all-in-one numeric keypad. Continue to hold these keys down for a few seconds after plugging the unit back in to reset it. Once the all-in-one re-establishes communication with the computer, reset the language and country.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 08, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer stops in the middle of a printing and shuts down
Thanks, Joe
Jan 07, 2009 | HP PSC 2210 All-In-One InkJet Printer
Double lines of print (same words)
You may just need to align the cartridges??
  1. Press Setup on the top control panel.
  2. Press 5 to select Maintenance , then 2 to select Align Print Cartridges .
or clean them:
  1. Make sure the printer is loaded with plain, white paper. Remove any special or colored paper.
  2. Press Setup on the top control panel.
  3. Press 5 to select Maintenance , then 1 to select Clean Print Cartridges . The procedure takes about a minute and produces a printout, which may be discarded.
You may also have to reset the printer:
Force the HP All-in-One to reinitialize by following the steps below:
  4. If necessary, turn the unit back on and try printing again.
  5. If the unit fails to read the card again, reset the All-in-One. Repeat Steps 1 – 4, but before plugging the unit back in, press and hold the # and 6 keys on the HP All-in-One numeric keypad. Continue to hold these keys down for a few seconds after plugging the unit back in to reset it. Once the All-in-One reestablishes communication with the computer, reset the language and country/region.
Jan 17, 2008 | HP PSC 2210 All-In-One InkJet Printer
Problems on paper jam (just after the selftest)mode switches blinking
You may have to reset the printer. I believe these are the directions to follow:
Re-initialize the HP All-in-One Force the HP All-in-One to reinitialize by following the steps below:
  4. If necessary, turn the unit back on and try reading the photo card again.
Oct 25, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
67 people viewed this question
Seeker5211
Seeker5211
