Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Iphone call problem
duns on Dec 24, 2007
Hi, I can make and receive calls but i can hardly hear the person on the other end. Even when the volume is full or on speaker it sounds like they're miles away but they can hear me. Also it always says call forwarding active and i can tap dismiss. What can I do so I can hear clearly?
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Mar 30, 2009
-   i can make and receive calls but I cant hear them but they can hear me. And even if I press the key pad speakerphone I still cant hear Please Help me -   bytchImda1
Feb 15, 2009
-   I have, more or less the same problem, didnt find any solution on the internet... Add me to the list... -   oxident
Feb 04, 2009
-   hi, i'm having problems with my iphone. everything works fine but i can't seem to dial an out going calls. my keypad just freezes when it comes to the dialing key pad. i can receive calls and make calls off my contact list but no dialing out. please help. thank you -   Guest
Jan 13, 2009
-   same problem, phone screen not functioning and going back to the main screen after few seconds. help me please !-   darulredzuan
Dec 07, 2008
i have the same problem as mantell1 !
my dialing pad doesnt respond and it crashes back to the main screen !!!
help !!!-   tt4422
Best Solution
posted on Feb 08, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
hi all, when iám making a call it says call failed , how can i slove this problem, i tried all the possibilities but nothing works till now, plz if anyone knows the answer email me:albert_mashraky@hotmail.com
Solution #2
posted on Jan 15, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hello. I have the same problem, I can't hear who I'm calling unless I put it on speaker phone. this is so funny, after a restore, the phone is working normal again, but after a few days, same problem again. Please help...
Solution #3
posted on Jan 07, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I'm having the same problem. I can't hear who I'm calling or who's calling me unless I put it on speaker phone. If you find a solution, please let me know.
Solution #4
posted on Feb 11, 2008
Helpful)
justpassing
Rank: Apprentice
Rating: 90%, 3 votes
May sound incredibly obvious for which I apologise but you have taken off the protective plastic covering that comes with the iPhone? It covers the earpiece.
Was this helpful?
Yes
No
Solution #5
posted on Jan 11, 2008
Somewhat Helpful)
applgeek
Rank: Wiz  Apple ExpertApple Expert
Rating: 88%, 49 votes
First, try restoring it. Plug it in to the computer and Click Restore When it pops up in itunes. Please note that this will destroy all data on the phone.
If that doesnt work, call apple.
Was this helpful?
Yes
No
Solution #6
posted on Feb 22, 2009
Very Helpful)
glbrooks
Rank: Apprentice
Rating: 100%, 1 votes
My Iphone was doing the same thing. I had just ordered a new headphone jack to replace the one in the phone. However, I saw a post where someone had cut the tip of a qtip of, leaving just enough of the cotton on the end. They then used the qtip to clean out the headphone jack. I tried this but it didnt work. However, I had accidentally pressed the volume button during one of the cleanings, and I noticed that it would change from headphones to regular ringer settings as I was cleaning the jack. I used the qtip to move around in the jack while the volume display was up. I eventually got the display to change to regular ringer volume, and now my Iphone works like it always has. I guess there is something in the jack that was "switched" that made it think the phone had headphone connected.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #7
posted on May 13, 2009
Not Rated)
uerym
Rank: Master
Rating: 80%, 39 votes
FIND YOUR SOLUTION FROM APLLE.
HERE IS YOUR SOLUTION
www.apple.com/iphone/prob237ji32/solution
Was this helpful?
Yes
No
Solution #8
Not Rated)
eyumr
Rank: Master
Rating: 81%, 27 votes
Problem with Apple iPhone? Most of the iPhone problem is Unlocking problem.
If you want to unlock your iPhone now you must Click Here.
If you have any other problem with your iPhone you can try the site by Click Here. May the site can help you.
Was this helpful?
Yes
No
Solution #9
posted on Jun 08, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I used to kind of have this problem, but i just delt with it. Then my phone actually broke (i have the warranty), they replaced it and no more problem.
Solution #10
posted on Feb 26, 2008
Not Rated)
ahmadalg
Rank: Apprentice
Rating: 0%, 0 votes
yeh i hav the same problem and i restored it and it still doznt work. plzz help
Was this helpful?
Yes
No
Related Problems
bluetooth to other mobiles
It was in a case and worked for an hour after being dropped,...
Can you Help with these PDA problems?
iphone problems
Solve
How do you reset your iphone?
apple iphone screen blocked on text...
Solve
Stuck on text message screen and not able to go forward or backward
SCREEN MAGNIFIED BY ITSELF
Solve
the home screen magnified by itself, now i can't enter the unlock code because the screen is so... (More)
11 Other Users Have The Same Problem - Continued
Comment by mantell1, posted on Dec 03, 2008
my problem is when I 'm trying to make a phone call, by touching the key pad
the digits don't appear on the screen, so I cannot call a new number.
I can still make calls with my contact list!
Could some please help. Geoff
Comment by snz1, posted on Nov 24, 2008
Guys, I'm having the same problem. I can't hear the incoming conversation but they can hear me. When I put it on speaker phone, then it was fine. Reset many times, still persists.
Comment by mickeyfins, posted on Oct 01, 2008
I can't hear anyone unless the iphone is on speaker mode or has the headphones plugged in. I've restarted it and reset it from the settings function but it's still not working...
Comment by sameerl, posted on Aug 11, 2008
I don't know but once a drop of tea, though not hot fell on my iphone and as soon as it dropped I cleaned it with tissue paper and since it was sticky, i put a drop of water and tried to clean it but looks like since that day 3 days back, I can't hear people on the other line when I talk to them so not sure what's the problem... I can hear only when I put on speakers or use my headphones.
Someone pls pls help me and in dire need of a solution.
pls email me at sameer.ib@gmail.com
Many thanks guys,
Sam
Comment by schndy, posted on Jun 21, 2008
can't hear the voice of the person on the other end
Comment by el bann, posted on Feb 13, 2008
plz i did jailbreak my iphone 1.1.2 and i can make a phone calls but i cant receive any of them and i cant get into my recents or even send a msg but it showed me that i get a msg but i cant see it
plz what shoul i do if anyone can help me plz send me a email on firas_bann@hotmail.com i really sad about it i waited for this long to get a iphone and when i had it i get this problems !!!! thanks
best regards
firas bann
Sponsored Links
Describe your PDA problem:
Top PDA Experts
Rank: Guru Guru
Solutions: 702
Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician
Ask Me
Find more PDA Experts
Top Computers & Laptop Repair
(601) 918-0222
I will connect to your Computer and repair the...
(330) 502-6853
Instead of lugging your computer into a shop and...
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
