Question about Philips Hopper XG20 Impact Multimedia Projector
I have a Philips Hopper XG20 and when i try to start it only the fans are running and nothing else works,,have cleaned the filter and all by the manual and still nothing accept running fans in the chassie,,
  • 70 Answers
No Light out? change projection bulb.
Posted on Oct 08, 2009
My trager grill is smoking a lot in the pellet hopper
That could mean that pellets in the augur have caught fire and it can work its way back to the hopper. Then you really have a problem. Are you sure the fan is running?
You should be able to hear it. The fan helps keep the heat from working its way into the augur. If it's not running, you should also be having trouble controlling the temperature.
Traeger has specific instructions on its website for testing various components including the fan and customer support can assist you with this problem.
Here's a link to the Traeger website: http://www.traegergrills.com/. I'd suggest you get in touch with them ASAP because you definitely don't want to deal with burning pellets in the hopper.
Jul 05, 2014 | Traeger Industries BBQ100 All-in-One Grill...
Ice Melting towards the front of the ice hopper
Check that the fan motor wiring has not been disturbed. If the freezer fan is not working, the fridge will generally start cooling but due to poor air circulation , it will stay colder at the back but will get warmer at the front hence causing the ice to melt. The usual temp for a food compartment is around 4 degrees. The freezer should be -18 degrees celcius.
Nov 25, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Sticky back card static causing them to stick togeather and not feed from the hopper
Hello Richard,
Sorry for the delay in replying to your request.
Feeding cards (especially self-adhesive types) from the rear hopper, can sometimes be frustrating. You have done the right thing by separating the cards (this applies to all cards - just fan down both sides like a dealer would with a pack of cards). This important.
Please try the following additional trick though;
Remove the rear hopper.
On the front panel, select Menu -> Test Card -> Yes (to confirm).
The rear hopper roller will start to rotate.
Take a fresh cleaning card (from the cleaning kit - 3633-0053) out of its wrapper. It MUST be damp.
Fold it into a loop and manually hold the cleaning card against the hopper roller as it turns (with gentle hand pressure). The idea of folding the cleaning card is to prevent it from being accidentally dragged into the rear of the printer.
After about 12 seconds, an Out of Cards 02:00 error will be displayed. Press Retry.
Turn the card over and repeat until there are no Black marks left of the cleaning card. Repeat as necessary moving to a fresh part of the cleaning card each time.
If the card should accidentally go too far into the printer, a Card Jam 06:05 error will be shown. Just open the lid, and close it again to clear the card jam error. The sequence will carry on from the previous stage (the hopper roller will start turning again shortly after closing the lid).
Once you are happy the roller is thoroughly clean, on the next Out of Cards error, press Cancel.
Discard the cleaning card which will probably have dried out by this point. Replace the rear hopper.
Card feeding should then be trouble-free.
If the problem should persist, contact your local Magicard support centre.
Kind Regards,
MC.
Nov 21, 2013 | Magicard Rio Pro Single Sided Photo ID...
Lights are flashing but nothing works
i had the exact same problem. when i spoke to a keurig rep, it was suggested that i open the kcup hopper and using a paperclip, clean the three holes in the upper needle. you have to straighten the paperclip so that it will reach about 1 1/2 inch into the hole.
there are three holes that need to clean and the back one, of course, is usually where the problem is. be aggressive! you need to twist/spin the paper clip as you push it in and out. after reaming all three, run a hopper of water through the system. i had to clean my pin three times before my brewer was working properly.
lots of luck.
Rob
Sep 21, 2012 | Keurig Elite B40 Coffee Maker
Need Philips tv code for dishnetwork remote
For the Hopper I have used code 0464, however, the ring around the OK does not seem to work using this code. I'm looking for one that will work everything as well.
Apr 25, 2012 | Philips Televison & Video
No power
If there is not power to the bulb and socket, check power coming from power supply with a voltmeter. You can remove the cover and see if the fuse is good. The fuse should have a little thin wire running all the way across it.
Aug 07, 2009 | Philips Hopper XG20 Impact Multimedia...
Philips Hopper SV20 Impact Multimedia Projector doesnt power up
hi the power supply of your unit is burnt refer service personnel
shyam
+919867355202
Feb 08, 2009 | Philips Hopper SV20 Impact Multimedia...
Pellet stove
The buzzing is possibly your exhaust/combustion blower. This blower is the fan sound you hear as the stove starts up. If you ARE hearing a NORMAL fan sound, then the buzzing could be the auger motor. Do you have a Foxfire with an igniter? This tells me the series of model you have and what control system it uses.
Feb 24, 2008 | Heating & Cooling
Ge Adora Front Loader
If you have not already done so, clean the filter behind the panel in the front bottom of the washer. Remove the three philips head screws to get the panel off. Unscrew the plastic filter on the right hand side (use a shallow cake pan to catch any water). Remove the filter and clean out the pens, pencils, change, lint, etc... and put back in. All should work well after this. Thanks, Greg
Dec 15, 2007 | GE Energy Star WCVH6260F Front Load Washer
Philips Hopper XG20 Impact Multimedia Projector Logo
200 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
