Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Email result EA3227
When trying to scan to email it fails with a result error EA3227.
What is EA3227
  • Konica Minolta Expert
  • 158 Answers
IP Scanner operations
Error Code Cause Remedy
EAXXXX ImageReceiver was not started.
Start ImageReceiver.
The IP address of the recipient
is not specified correctly in the
dialog box that appears after
clicking “Receive Settings”,
then “Connection Filter”.
Click “Receive Settings”, then “Connection
Filter”, specify the correct IP
address, and then restart ImageReceiver.
ImageReceiver is not operating
correctly.
Restart the computer.
Re-install IP Scanner.
Check the TCP/IP settings on the computer.
The LAN cable is not connected.
Check that the LAN cable is correctly
connected.
The network settings on the
computer are not specified
correctly.
The network load on the recipient’s
computer is too high.
Check that large e-mail messages are
not being received at the recipient’s
computer and that large files are not
being downloaded from the Web.
Too much data is being sent. If a high scanning resolution has been
specified, reduce the resolution or decrease
the number of pages scanned
at one time, and then scan the document
again.
Access is blocked by the setting
specified for the computer’s
firewall (Windows
firewall) for the Internet connection.
Change the setting specified for the
computer’s firewall (Windows firewall)
for the Internet connection according
to the instructions from your network
administrator.
Posted on Oct 24, 2009
Job failed because scan name is invalid
Hi Anonymous / Kenneth,
I assume you must have this problem sorted by now. ( 2012.)
Perhaps there's a firmware up grade you could look into?
Perhaps you must have to check this problem with your Xerox Concessionaire.
Good luck.
May 14, 2012 | Xerox Phaser 3635MFP/X Multifunction...
On C35 bizhun get error when scan to email SCAN TX FAILED JOB CANCELLED any help?
your email settings got messed up... you need to go to pagescope (web interface) by typing the ip address in your webbrouser that is connected to the network and check the scan settings to see if mybe you missed something or if something has changed....
Oct 07, 2011 | Konica Minolta Konica Bizhub C353 Drum...
Server connection error when scanning
have you set up your scan Email account with you page Scope disk with the copier. is the server set up for scan to email. Also check the konicaminolta web site for scan operator manual. Down load the scan programs
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 24, 2010 | Konica Minolta Bizhub c203 Copier
Unable to scan to email after switch to Exchange 2007
check the server settings, maybe user authentication is needed, check from server side, what the printer is trying to do and where it fails. check printer e-mail settings, try these setting in computer.
Oct 05, 2009 | Konica Minolta bizhub C250 All-In-One...
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
HP 4215v cartridge error message
Hi Jeff,
First of all, did you read the web page at the link I previously provided? Print cartridge errors will cause you to have problems both with printing and copying. There are a number of troubleshooting tasks on the page I provided that you'll need to go through to see if you can correct the cartridge error. Give them a shot and post back your results.
The scan issue is a tad more tricky. Actually, if you computer's operating system is Windows Vista, then it is a known issue and HP.com has a "workaround" for the problem:
Scan Button Doesn't Work with Windows Vista
While the scan button "should" work with Windows XP, it still may have issues. I have an Officejet 6110 and have never been able to get it to scan just by pressing the Scan button on the printer's control panel. I use the program on my computer and since it works, I don't fuss about it (the printer has otherwise met all my needs for years, so I'm OK with it).
When you press the Scan button on your printer, do you get any error messages, either on the printer's control panel or on the computer? If you do, that'll at least provide some clue as to the issue. If not, it will be hard to diagnose. Sometimes HP scanners don't work and play well with Apple OS computers, but other than that, HP.com doesn't provide any other solutions.
Try going through the troubleshooting steps for the print cartridge, then try to print, copy, and scan and see what happens. Post back your results.
Oh...I noticed you posted your email address. Just to let you know, there are automated programs on the Internet called "spiders" or "bots" that crawl public forums and "harvest" email addresses for spammers. I don't think you can edit your posts (I can't edit mine at any rate) but in the future, try not to post your email address in a public area on the Internet. You may notice an increase of spam hitting your email in the near future (though I hope not).
Good luck with the printer.
-Trip
Sep 12, 2008 | HP OfficeJet 4215 All-In-One InkJet...
The scan failed because of a scanner hardware error. Feeder may be jammed. Please correct the error and scan again."
Yep. I also can't scan using the Samsung SCX-4200, which results in that error
''The scan failed because of a scanner hardware error. Feeder may be jammed. Please correct the error and scan again.''
Richard Betambeau,
Reading, UK
May 20, 2008 | Office Equipment & Supplies
Ricoh Aficio 1075 - SMTP error message
To use the scan to email function on your copier you need some settings from your internet provider (email setting specifically). Go into Outlook options and get your SMTP server, user name and password.
On your copier you need to change under User tools, system setting and file transfer and put these settings in. As long as your machine is set up for scan to folder thats all you should need.
Apr 18, 2008 | Ricoh Aficio 1013F Copier
Bizhub 250 scan to email error
Try re-entering user name and password or try a different user name and password for email account saved in the machine.
Jan 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
340 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
