Question about Hoover Tempo Widepath Upright Vacuum - Blue
My Hoover doesn't roll
My Hoover widepath tempo still sucks (in a good way), but the brush roller doesn't roll, doesn't pick up debris on carpet as good as it used to, and it's harder to push. Any ideas?
    Problem Solver:
  • 18 Answers
You need to replace the belt. Part number 40201160
Posted on Oct 08, 2009
How do I fix my hoover that is not sucking up anything?
With your model tempo, the hose needs to be connected to the tube in the back (should have a door cover that flips open). Also check the suction path and change the bags or filters if needed
Aug 31, 2014 | Hoover Tempo Widepath Upright Vacuum -...
If belt is stretched do i have to replace it
If the brush is not turning when on carpet, then yes. The beater brush will turn if the belt is touching it, so looknig at it when the brush is not hitting the carpet is not a way to see if the belt still functions. There should be a window where you can see the brush turning. If the brush does not turn while on carpet, replace the belt.
Nov 24, 2012 | Hoover Tempo Widepath Upright Vacuum -...
Brush is not engaging when vacuuming. If lifted
therre are usually aprings that hold the brush in position or a spacer thaqt turns when you adjust the height. turn the vacuum over and remove the plate covering verything. make sure your unplugged first. it usually takes about 5-6 phillips head screws. look for loose ,broken or missing parts. make the the roller is taken out and is carefully cleaned of all hair etc esp that just at the edge of the roller where it meets the monting devices. the hair and debris often gets stuck there and once removed works much better. also make sure the belt is not stretched and is slipping on the brush. if it is replace it. good luck.carefully reassemle the parts you removed being very aware of what postiotn everything was in when you took it apart. make sure everything has proper clearance and then test your vacuum. if you find broken or missing parts replace them first ofcoarse.
May 14, 2010 | Hoover Tempo Widepath Upright Vacuum -...
Hoover Tempo Widepath - propellor not working
If you are refering to the roller underneath, the belt nees to be replaced. Simply remove 4 bottom screws and then the roller, Place new belt on roller and thenon motor shaft, pull belt with the roller to install in position and install bottom plate.
May 02, 2010 | Hoover Tempo Widepath Upright Vacuum -...
My hoover has no suction at the nozzle, though it has strong suction at the hose. This problem started after I replaced the vacuum bag for the first time.
there is a blockage behind the roller brush remove the roller plate and the roller and check the inlet hose for a blockage also remove the bag and chek the inlet to the bag for some type of obstruction. Don the Vacuum Doctor Alb, N.M.
Nov 01, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Change belt on a hoover tempo
Remove the cover that covers the roller brush, (four screws) and remove
the roller brush and replace belt, it goes between the motor shaft and the roller brush. Replace the cover and that should do it.
Tom
Aug 04, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Tempo Widepath Blows Dirt Out Back on Hard Surfaces
lots of times switching to hard surface floors you need to slow down because the air flow that does the actual picking up of the dirt can't work as fast as the spinning brush so the brush is throwing the dirt out the back before the suction can pick it up. Try slowing down
Jun 11, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Hoover tempo
sounds like a blockage or belt off in the foot of the vacuum. there is no reset button on this model.
Mar 20, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Self propel feature broke on Hoover Tempo Widepath
Sounds like the tie has loosened the belt off. You may have to check under neath the sole plate by removing screws and having a look. If the belt is broken it will have to be replaced. If its not broken check that it hasn't moved within the gear assembly of the self propel mechanism. Fit everything back together and it should work after that.
Feb 20, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Hoover Tempo Widepath Upright Vacuum - Blue Logo
254 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
