Question about Garden
My murray riding lawnmower has completely locked up and i need to know where to add the oil and how to grease the locked up parts
  • thunderalley
    thunderalley May 11, 2010
    engine lockup or suspension parts???
  • 437 Answers
If it is the engine that is locked up, it is better to look for a replacement engine instead of trying to rebuild that one.
Good day.
Posted on Oct 07, 2009
Murray riding lawnmower #309029X92 can't turn shaft, Won't even start,
Karen, try to spin the top of the engine by hand. it should rotate, if it don't check to see if the starter has locked into the flywheel. make sure the blades are disengaged the brake pedal is pushed in and you are sitting on the seat.
May 30, 2016 | Murray Garden
Where can I find a Murray 12 HP 38 " lawnmower model 38608X92C manuel?
Murray can send you one some mower shops maybe able to print you one or part of it
Jul 26, 2014 | Murray Garden
I am looking for manual on Murray ride-on lawnmower, model no.42587X50C.
Murray is made by MTD on the site you can get the PDF of the manual for download. I have it
Apr 19, 2013 | Murray Garden
Hi, I have an older Murray ride on mower, small
Sounds like you have some sort of seize up problem in your deck assembly. Have someone help you with this check, start your engine, engage the blade or blades, and have someone watch the shoot from a distance to see if blade or blades turn. if not then your problem is in the area of top pulley and blade or blades. You may need to replace or loosen the pulley to blade shaft. Sometimes this part is repairable where you can replace bearings or bushings and sometimes the whole unit needs to be replaced. Look to see if there are grease fittings on this unit. Try oil anywhere it will flow down in between areas that may be seized and work on loosening up the pulley blade assembly.
If this doesn't help, go to some of your local mower repair shops, they may be able to sell you a used part. Remember to bring mower information with you so they can help you with the correct part.
I hope this has been helpful to you. GOOD LUCK.
Jul 19, 2011 | Briggs & Stratton Briggs Stratton...
Murray 42'' riding lawnmower owners manual
www.murray.com
Locate the tag with your model and serial number on the tractor. Be sure you get the number EXACT or it won't work.
Go to Murray's website and download it. They usually have parts listings at the back of the Owner's Manual
Oct 04, 2009 | Garden
I need a part no for a murray lawnmower model no.7-39004
The belt number is 37x26. As for a diagram, I have it on micro fiche, but can't find it online. I wouldn't want to try to put that one on. lol I'll see if I can get a copy and e-mail it to you. I have the belt if you can't find it locally.
Jun 26, 2009 | Garden
I have a murray lawn tractor (2000) model no 38502x98c. One of the mandrels or blade bosses is completly broken into pieces. Can you tell me where to source a replacement part. The part number is "Mandrel...
That 'Mandrel Housing' # has been changed to 492574. It should be available at just about any lawnmower shop, probably even at Wal-Mart.
Jun 10, 2009 | Garden
I have just purchased a house that comes complete with a Murray ride on mower model no 312000x98a. We do not have any operating/maintenance manuals. We have also had the front wheel fall off today and need...
Unfortunately murray.com does not have any documents available on their website for that model, but the way the wheel is held on is very simple.
The wheel has bearing in it that slide over the axle shaft, then a washer goes on the shaft and the assembly is held on with a cotter pin that goes through a small hole near the end of the shaft.
If you need information about the engine, Look up the information from the engine manufacturer. Be sure to insert grease into all of the grease (zerk) fittings on the various moving parts on the tractor, keep the oil clean (SAE30) and drain all fuel before winter storage or else use STA-BIL. Also, since lead-acid batteries lose 1% of their charge per day, keep a smart trickle charger on it during storage.
May 03, 2009 | Garden
Garden Logo
174 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
