Question about Car Audio & Video
How many different ways can you wire a 12 memphis subwoofer
12 memphis subwoofer keeps shutting off amp with too much volume
  • 33 Answers
You need conneciton to amp streit from battery terminal but make sure you put an inline fuse in the main wire first for safty
Posted on Oct 07, 2009
I hv a Memphis 1100 watt mono block n a kicker 12" l7 try to get rid of the flutter or hum at low volume tried just about everything suggestions plzzz
I once got a hum from running the rca and power wires side by side, separated em and problem was solved. Could also be something shorting to the frame, bad ground,cracked insulation on rca wires, the gain might be set to high or maybe the amps dying. It could take over a year for an amp to completely die. But you can always pick up an electronic noise eliminator from radio shack for like ten to twenty bucks
Nov 05, 2014 | Car Audio & Video
What would the best way hooking up a 15" memphis dual voice coil sub ran with a 1000 watt memphis d amplifier??
If the amp is a 2 channel I would hook up each voice coil to a different channel. Also, make sure you hook your amp up as close to the sub as possible. With a sub that size you need to eliminate any delay in signal transfer because the sub is so larg.
May 02, 2011 | Car Audio & Video
How do i wire 12"
it depends on the equipment you have and what your trying to do. what are the ohms rating of the speakers- are they dual or single voice coils? what kind of amp are you using? 2-channell 4- channell- or a mono ? if its a mono or a 2-channell what impedence are they stable down to?(ohms)
Dec 11, 2010 | Car Audio & Video
MY amp is going into clip mode. what is clip mode on an infinity car audio amp?
either your pushing your subs to hard and its creating a backsurge of resistance, or the spider wires are touching the frame causing them to foul out. It honestly sounds like you are trying to run too low of an impedance subwoofer, and your amp infinitys clip to keep from distorting, distortion played through a subwoofer at high volumes is damaging to the subwoofer and the amplifier. reduce your gain, and check your wires, the clipping should stop, a good rule of thumb always have an amplifer that will do rms what your speakers can do peak, so that way you can keep the amp turned up only 1/4 of the way and be pushing your subs at a decent rms volume with 0 distortion.
Aug 09, 2010 | Car Audio & Video
I have hooked up my subwoofer and amp to my factory stereo in a 2011 camry. My power wire is hooked directly up to my battery, my ground to the chassis and my remote to my fuse. I have my RCA wires (RCA on...
Rewire your stereo cables as such:
Red- positive - battery
Black - ground - chassis
Remote (Yellow) - ignition switch
The "LINE OUT" should go to your SUB-WOOFER.
The while-lined wires paired with the solid colored wires are either your Front LR and/or Rear L/R.
Jun 14, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
Amp is on, but sub wont produce any bass
Make sure the subwoofer is set to low frequency, make sure subwoofer and bass are enabled on the headdeck. Make sure the gain is turned up on the amp, make sure the rcas haven't come out of the back of the head deck.
Aug 04, 2009 | JBL GTO14001 Car Amp
My amp shuts off with my 12in w6's when i turn up the volume
oh no you need a more powerfull amp i recommend selling the one you have and upgrade to a bigger amp ive had the same problem or if not unbridge your amp so it dosent work the amp to much
Mar 16, 2009 | Jl Audio 12W6 Car Subwoofer
Car Audio & Video Logo
194 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
