Question about GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
How change the water hose on the door - GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
    President:
  • 1,304 Answers
Unfortunately the water line is poured into the door to change that you will need a new door
Posted on Oct 08, 2009
Blend door actuator on ford f150 need to change it think that's my problem why heater is warm and not hot
Some of those you can watch actuate near the hump in the floorboard,back underneath. If it moves all the way when you switch from cold to hot,it's not the blend door. CAN be a partially clogged heater radiator.
IF you can get the hoses identified, you can take a water hose and backflush thru the hose that returns to the water pump.
This will blow debris out the heater hose which comes from the thermostat area, in reverse of its usual flow. don-ohio (:^)
Nov 25, 2016 | Ford F-150 Cars & Trucks
I have water coming out of my door at the bottom hinge when I try to dispense water e war ter
sound like you have a bad hose on it , change the hose make sure it is connected to in and out good , could have a pin hole in it easy to change
Jan 09, 2015 | Refrigerators
Ge referigerators
check water hose for a kink in hose
Aug 27, 2012 | Refrigerators
Ice maker not making ice, but water dispenser working, just changed filter
If you changed the filter than water may not have made it to the icemaker yet. If you have givin it 24hrs than check these.
There are only 3 things that will prevent an icemaker from not making ice.
1) Temperature in freezer. Most icemakers require that the temp in the freezer is at a minium of 6 degrees. If the thermostat in the icemaker is not reading this temp or below it will not let the icemaker call for water to make ice.
2) Icemaker. Is the arm on the icemaker in the correct position. Most models the arm should be down to operate and up to be off. Faulty icemaker. The internal components of the icemaker may have went out.
3) Water inlet valve. If the silinoid for the icemaker on the inlet valve is stuck it will not allow water to the icemaker. Over time inlet valves wear out.
Troubleshooting- Check the temp in freezer. If not 6 degrees or below you have another problem with your freezer. If at 6 degrees or below and you have ice and water through door unplug fridge, switch the two hoses from the inlet valve (NOT Possible on all inlets so check to make sure you can remove the hoses by pushing in on the cylinder that hose feeds into and pulling hose out) Switch the hoses than press the water through door feature. If you get water inlet valve is good. If you dont have ice and water though door than have your inlet valve tested. If inlet is good and temp is good replace icemaker. If you have any questions or need further assistance please respond. Thank you
Aug 01, 2011 | Whirlpool Refrigerators
Washer is displaying no error code however the cycle stopped in the middle. I tried to rerun the load. The dorr locked but it will only buzz. Now the door will not unlock and nothing will male it run. I...
You may have a water valve issue. (leaking water past valve, allowing water to fill to higher than normal level) To unlock, try opening the access door at the bottom left on front of machine and using small hose there, drain water out of machine. If hose is plugged, you may have to unscrew big knob (with filter attached) to drain. When the water level lowers, door should unlock. (if washer is plugged in)
Apr 12, 2011 | LG WM0642H
Water pressure is very low, takes a minute to fill a glass. Its not the filter that has been changed
IT MAY BE A CLOGGE IN THE WATER HOSE. GO BEHIND THE REFRIDG CLOSE THE MAIN WATER LINE VALVE. PULL OUT THE HOSE SEE IF ANY WATER COME OUT FROM THE HOSE.
AND USE A SMALL BOKETT SO YOU CAN TEST THE REFIDG WATER VALVE CONTROLLER. PLUG BACK THE POWER SUPPLY AND FACE THE HOSE IN THE BOKETT AND DEPRESS THE WATER SWITCH AT THE DOOR AND SEE HOW THE WATER WILL COME OUT BUT THE MAIN WATER VALVE MUST BE OPEN. IF NO WATER COME OUT OR IT CAME WITH LOW PRESSURE. TAKE THE VALVE OUT AND CLEAN IT. MASKE SURE THE MAIN WATER SUPPLY WORKS GOOD.AFTER ALL IF YOU GOT POWER AT THE WATER VALVE WHILE YOU DEPRESSED THE SWITCH AND WATER STILL NOT COMING OUT SO, THEN IT GE TO BE THE REFRIDG WATER VALVE.GO AN A CHANGE THE WATER VALVE
Oct 24, 2010 | Whirlpool GD2SHGX Refrigerator
CHANGED INLET VALVE ON SIDE BY SIDE WITH WATER AND ICE IN DOOR. NOT SURE IF HOSES ARE GOING TO CORRECT PLACES
Open the refrigerator door.  Hold the switch so the refrigerator thinks the door is closed.  If water comes out by the ice maker when you press the water button the lines are swapped.
Oct 25, 2009 | Frigidaire FRS26H5AS Side by Side...
After 3 years we have ice but no water from the dispenser
Remove the bottom kickplate and the hose at the bottom of the door goes underneath the refrig about 3 inches , to a hose connector . Push in on the end of the connector and pull out the hose . Close the freezer door and press water . If water comes sprays out from hose under frig , then your door is frozen internally .If no water sprays out of hose , then your watervalve is bad . One coil is for ice and the other is for water but they come togather as one.
Jul 18, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Instaled new water value no water toice maker or water
Remove the bottom kickplate and find the hose coupling . Push in on 1 end and slide hose out . Then close the door and push for water . If water comes out the hose in steady spray , then your complaint would be door is frozen .
Jul 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
2002 dodge neon only blows cold air
you may have a cable or rod disconnected or broken under the dash which connects the hot cold switch to the air diverter door. the door may be in the cold position and with the cable broken it can not change its position. make sure this door is operating first.
if it is then your problem is more then likely with the heater core you can try flushing the heater core by disconnecting the hoses going to the heater core from the engine side of the hoses and putting a funnel in the hose so that you can pour water through the core if the water flows freely then this is not your problem. reconnect the hoses.
Mar 27, 2009 | 2002 Dodge Neon
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
50 people viewed this question
Top GALAXY Microsystems Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a GALAXY Microsystems Refrigerator Expert? Answer questions, earn points and help others
