Question about Maytag Dryers
Dryer turns but no heat Maytag about 5 years old - changed heating element switched coils /wires etc. cleaned vent - dont have the schmatic or manual for it - (not mine a friends)
  • Maytag Master
  • 7,482 Answers
Try this place for a manual.
Good Luck,
I hope this helps
http://laundry.manualsonline.com/manuals/device/clothes_dryer.html?
Posted on Oct 07, 2009
Dryer wont heat. we have cleaned out all the lint, replaced the top thermostat and are frustrated. seems like it heats for a couple minutes then nothing.
Sounds like a bad heating element . Many dryers use a dual coil setup ( one coil for low to med, both for high heat). Also check your dryer discharge vent. A blocked vent will not allow the humidity to escape, which will result in your clothes not drying or taking multiple cycles to dry. Turn the dryer on, and find the vent discharge on the outside of your home and just hold your hand there. If you do not feel substantial airflow you have a blocked vent or blocked discharge tube. But from what you described, I would bet on either a bad heating element or failed heating element relay.
Sep 12, 2013 | Maytag Dryers
Trying to repair my maytag mde4000ayw dryer. This is the 3rd time in 5 years that the dryer has stopped heating. The last 2 times, we ordered and put on a new heating element and it worked. This time, we...
Hi
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Jul 28, 2011 | Maytag Dryers
The dryer is 5 years old and does not seem "heat"
werrw
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens. If the problem does not inprove, you may have a defective heat coils
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 80 series dryer approx 7 years old not heating anymore. Cleaned the vent pipe using semi-rigid vent tube only three feet to outdoors. Vent on exterior blowing cool air forcefully. It is an...
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.
Here is a link to a video that will help you.
Nov 26, 2010 | Dryers
No heat on any setting
if the dryer hasn't had a cleanout yes this can happen,but it might not be the element.you might have popped the high limit thermostat on the heater box,the dryer is running to hot from the air not moving correctly,a blocked vent line or the duct that the lint filter slides into is clogged with lint.unplug the dryer and with a meter check the thermostats and the heating element.pull at least one of the wires off the part you're going to check and clean out the dryer and vent line
May 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune dryer is not heating up. we
You should have your owner's manual on hand to locate specific parts and understand how to disassemble the dryer. Also make sure that the power is disconnected from the appliance before making any repairs.
1)Check the fuses near the heating element. Inspect them for breaks inside the fuse. Replace them if necessary.
2)Test the temperature switch with a volt-ohm meter. Set the meter to RX1 and zero it out. Touch the meter probes to each terminal on the switch. The reading should be zero. Next turn the switch on and test it again. Now the reading should show infinity. If the switch fails either test replace it with a new one.
3)Check the heating coil to see if it is bad. Use the volt-ohm meter and touch the probes to each of the heating coil terminals. If it reads zero, the heating coil needs to be replaced.
May 07, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag PYE3300AYW Elec Dryer Runs, But No Heat
hello kellygubser,
If you are sure the thermal switch is ok.. have you checked the high temp ( bi metal snap switch) too? Here is a link to the wiring diagram of your dryer. You can see that there are a few other temp switches in circuit of the heating element that would disble it.. Hope this helps
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Dryer runs, tumbles clothes, but does not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Aug 09, 2008 | Maytag SDG4606A Gas Dryer
Maytag neptune breakdown
Warning! Shock Hazard! Disconnect dryer from power source before servicing.
I assume you repaired a wire that attaches to a white ceramic insulator terminal? If you have a volt-ohm meter, you can check continuity of the element and hi-limit thermostat and overtemp.fuse located on the element shroud. If you ddon't have access to a meter then visually inspect the element for a break in the coil. The fuse and hi-limit can be temporarily bypassed 1 at a time to eliminate 1 or the other being faulty. Also double check your heat temperature settings on the control panel to make sure it did not become de-selected. There are also temperature control thermostats attached to the blower housing in lower left corner of the dryer that can be temporarily bypassed to test for failure. Tip: Clean lint filter after each load. Clean vent to outside,(check every 3-6 months), and refrain from overloading dryer. This will help extend the life span of the element and the dryer itself.
Hope this helps!
May 26, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
62 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
