Question about Sanyo VPC-S880 Digital Camera
When a picture is taken the side turn red, it didn't fall or anything, what could be wrong?
My samsung ES10 was experiencing blurring of picture?
this is either a slow shutter speed because of lack of light and you didn't have the flash turned on or a dirty lens can cause it.. if there is anything in focus it is just it grabbed the wrong thing ti focus on and the bad thing would be a bad lens... one of these is whats up
Nov 12, 2012 | Samsung Es17 Sl30 Es10 Es15
My Olympus Stylus 6000 has a red flash indicator blinking when turn on. When try to take picture, it sounds two beeps but no picture will be taken. What seems to be the problem?
Just to let you know I have got the same problem and I didn't find the answer. May be the flash light bulb is broken after an impact or so. Only thing I can think of...good luck! Sx
Jul 21, 2011 | Olympus Stylus Tough6000 Protective Clear...
A red lightning arrow keeps flashing on the screen and the camera isn't doin anything,what can the problem be?
Hi.
A red flashing lightening bolt can mean different things on different camera's. The most common are that you are too far away from the object you want to take a picture of. That the flash on the camera needs to be turned off and that the flash itself is charging up and won't allow a picture to be taken.
Try turning the flash off and see if it will let you take a picture.
Regards.
May 01, 2011 | Cameras
Apex DT250 wont turn from standby (red light) to On (green light)
The DT250 has one or more bad 470uf 25v capacitors. You should replace all four. Look at some of these youtube videos for how do do the replacement.
http://www.youtube.com/watch?v=on_2CP52cW4
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1
Order 4 new 470uf 25v capacitors from digikey.com P/N P10274-ND
Use first class mail as your shipping method. Will be under 10 dollars total.
Sep 24, 2009 | Apex Digital HT-150 System
My screen shows a blurry picture and it takes a blurry picture. it didnt used to. what is wrong? how do i fix it?
I have the exact same problem. When I was in NY last fall, suddenly my camera would only take blurry pictures. I hadn't changed any settings or anything. I can get halfway decent pictures in Auto mode, but any of the other settings only take blurry pictures. Apparently a lot of people have this problem, but no one knows how to solve it...
Feb 28, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Blurry pictures
Adobe photoshop might help.
Apr 06, 2008 | Casio Exilim EX-S600 Digital Camera
Slr camera's lcd screen only says i have taken 3 pictures, and keeps sayin ERROR, what could be wrong? I tried replacing the batteries and the camera still says ive only take 3 pictures, even when i out...
Try resetting the counter by pushing and holding the two rewind buttons simultaneously ( red symbols ), one on each side of the top cover. Then open and close the film door.
Sep 23, 2006 | Nikon N65 QD 35mm SLR Camera
Sanyo VPC-S880 Digital Camera Logo
12 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
