Question about Refrigerators
Maytag MSD2356AEW refrigerator freezing up
About 5 years ago the coil on my Maytag MSD2356AEW refrigerator was freezing up & I was told I needed a defrost board. I have been manually defrosting it with a hair dryer about once a year since. But in the past 3 months it has gotten very frequent & now it pretty much won't last more than a week. I think there are more issues now, like refrigerant or another part. I don't want to just start replacing parts though & I can't really afford a tech right now. What can I do or check?
  • tstillwater Oct 08, 2009
    Sorry. No we did not actually replace the board. So it obviously still needs to be done. I'm just thinking there is more to it than that now.
  • Refrigerators Master
  • 1,606 Answers
You did not clarify , if the board was changed or not . You only have 2 parts to the defrost system , as the defrost heater AND bimetal , come togather . I would start with the heater/bimetal part first .
Pt number 61006198 Heater and bimetal
Pt number 61005988 Adaptive defrost board
The bimetal , is the 1" cylinder , clipped to the top of the coils , and heater , at the bottom of the coils .
Posted on Oct 08, 2009
  • Mike Smith
    Mike Smith Oct 08, 2009
    If you manually defrosted only once a year , then that couldn't have been the problem in the first place . A refrig has to defrost at least once or twice a day or the evaporator will frost up , causing non- cooling in the refrig section . Minimum of once every 2 days . So , if you defrosted only 1 time a year , then , either one of the parts could be bad now .
Kenmore elite coldspot model 106.74219400 freezes in the fridge never gets above 5 or 10 degrees and it never shuts off.
there is a flap in the refrigerator side usually near or behind the light bulb the freezer side is thermostatically controlled with the compressor being controlled. On the refrigerator side the cold air comes from the freezer side. when this flap is open the refrigerator will cool continuously, Check the flap or the duct assembly
here is an illustration of the part
http://www.repairclinic.com/Kenmore-Refrigerator-Model-10674219400-ID-927868-Duct-Venting-Parts
Apr 14, 2013 | Kenmore Refrigerators
Maytag MZD2766geb not working.
HI.KATRINA.hummmmm.u mean EVAPORATOR frozen.well think your problem lies with the heater or t/stats.blow drying shouldnt affect it put ol board back and try.and check EVAPORATOR fan too.good luck ALI
Jun 24, 2012 | Maytag MZD2766GES Side by Side...
I bought a maytag side by side in 2002; model # MSD2454GRQ, SN 18157432AL, REV # 18. Ice is forming at the bottom of the maytag freezer department. Overnight ice will form at about 1/8 inch and left has...
Defrost problem: 3 components. Defrost Heater. Timer (circuit board or motorized) & Thermostat.
Remove cover on the inside back wall (usually 6 screws). Note frost pattern. (bottom of evaporator coil)
Put refrigerator into defrost cycle and note the defrost heater come on, or not. (careful heater can glow red hot)... Unplug Frige and test defrost components. Replace bad component... Refrigerator should defrost every 8 hours. when the cycle slows or quits the freezer will freeze over the evaporator coil and no air flow = no cold air...
Nov 15, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag msd2454gr side by side. The evaporator coils freeze up and the fridge gets warm. This happened about a year ago and I thawed it out and everything was fine. It happened again about a week ago so...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
My Maytag side by side refrigerator [mod. #MSD2656KES, Serial #50518503JL] is freezing everything on the frig side on the two top shelves. Coils have been cleaned. Temp set:Freez=3, Frig=2. One week ago...
I have this same refrigerator, also purchased in 2006. Same exact problem. Fridge freezes, starting actually in the water line, you will notice water on door does not work, then top two shelves start to freeze. Lasts for a few days, then prob does not happen again for 6 months almost to the day. I've had this problem for almost 3 years!!! My service tech said to buy another, glitch in this system he can't figure out. Replaced damper x2, control board, and thermostat x2. Not sure what else to do. I hate the thought of more food lost to spoilage!
Aug 09, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
I have a Maytag Side by side MSD2356AEW unit. Everything was OK for years till the maid cleaned it. Afterwards we noticed water under the bottom drawer on the refrigerator side. Slowly in the course of 2...
Do a manual defrost overnight by unplugging and leaving the doors open the opening should not be frozen. Alot of humidity or constantly opening the door sometimes causes the frostup.
Mar 13, 2010 | Maytag MSD2651 HE Side by Side...
Not cooling/freezing good
sounds like a defrost problem. defrost system consists of defrost timer or defrost control board,defrost heater,and defrost thermostat. most maytag sxs refrigerators have a circuit board in charge. part no.61005988 adc board.change the board and yer in business...
Jan 11, 2010 | Maytag Refrigerators
Maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
Apr 09, 2009 | Maytag MFI2568AE Side by Side French Door...
Refrigerators Logo
334 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
