Question about Kenmore Dryers
REPLACED MICROCOMPUTER, IT RAN FOR A FEW WEEKS AND THEN FABRIC CONTROL NEEDED REPLACING, NOW IT RUNS OCCASSIONALLY WITH HEAT AND THEN STOPS AGAIN. I did the tests required, it seems one part after another is going here?
Buy a new dryer it's cheaper. Get one with no wrinkle guard or signal switch.
Posted on Oct 09, 2009
Good morninng, My Goodman furnace inducer stops and starts at various intervals. At times it runs fine but starts the same issue. Everything starts up accordingly, runs and then the inducer stops for...
Replacing the board, flame sensor, and pressure switch, and cleaning out the induction motor was definitely a good start. Other things to check would be a blocked or restricted flue pipe, I have ran into a few bird nest before!, and you also want to check or replace the hose that runs from the inducer to the pressure switch if you haven't already. To be honest, most of the time I clear out the nipple on the inducer where the hose goes with a small piece of wire and it works. The last thing I would suggest is making sure the new pressure switch is rated for what you need. Alot of the revisions on furnaces actually call for less than the original pressure just for this problem. Hope this helps and good luck!
Feb 15, 2011 | Goodman GMS90703BXA Heater
Refrig and freezer working on and off for 2 weeks
have you gone here with the model # and cked out what the site says...
https://www.repairclinic.com/?clearLs=true
without a model # is hard to help.
Jan 01, 2018 | Frigidaire PLHS67EGSB Stainless Steel Side...
F28 code washer stops working. Reset will only
Error code F28 indicates that one of the below part is bad
  • Motor Control Unit (8540135)
  • Microcomputer Machine Control Unit (8540788)
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) you can fix it,
Here's the online repair manual for Whirlpool Duet Sport, but its identical to your HE2.
Refer page# 4-20 it describes how to get to MCU.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
May 04, 2010 | Kenmore HE2 Plus Front Load Washer
2005 Dodge Grand Caravan Will Not Start
I have had a few BCM(body control module) issues in the past. Have them check out the BCM. Good luck
Apr 25, 2009 | 2005 Dodge Caravan
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore Electric Dryer wont start or runs only occassionally
sound like you have a microcomputer problem / some calls it a even heat board ,,,, it will cause the problems your having / if need help on part contact me and i will see if i can help on part / larryyb
Dec 03, 2008 | Dryers
Dyson
the automatic cut out switch on the motor needs replacing when the motor gets hot this switch comes in and stops the motor from overheating when the motor cools down the cleaner will work again and cut out again when the motor gets hot if it is not replaced it will eventually burn the motor out after the switch has been replaced both the filter and cyclone need to be cleaned on a regular basis or the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dryers Logo
42 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
