Question about Samsung Digimax S700 Digital Camera
When i inserted new AA Battery after opening
My Digimax is 1 year old camera now when i inserted new AA Battery after opening camera few minutes after it is automatecally closed
SOURCE: The lense does not close in
Although your solution did not work, I got a tip from it that there is a catch holding the lense assembly. I removed all the six screws on the four sides of camera; then removed the rear frame. With frame removed, I inserted the batteries and switched on. Then switched off. And WOW, the lense retracted. Thanks again for the tip.
Posted on Sep 03, 2007
SOURCE: problem with startup
Now something that will actually help you.
1) the reason this is most likely happening is that the lens is blocked.
how i fixed this was (I'm not kidding) I hit mine against a card board box. and that dislodged the lens, now it works. you can also just try taking it apart and cleaning it. that gave me an electric shock so be careful.
hope I helped you.
PS "you might need an idiot to do this for you. no kidding."
Posted on Mar 08, 2008
fotobean
  • 103 Answers
SOURCE: digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Posted on Dec 10, 2008
  • 70 Answers
SOURCE: Camera shows low Battery and goes off even if u insert a new one
are you using NiMh rechargeable batteries?
If yes, check that they are fully charged. If that doesn't do the trick, sounds like it might be a power circuit issue. Samsung is in Secaucus, NJ
or SamsungUSA on the web
Posted on Apr 15, 2009
  • 125 Answers
SOURCE: Samsung Digimax D53
For digital cameras you should use either Rechargeable(whith high Ampere) or high performance alkaline batteries (ie. Lithium Duracel or Enegizer) normal alkaline batteries will not be able to charge the Flash. If you are useing high performance batteries then it is sadly your camera which is faulty. repairing it you could but it is cheaper to get a new camera.
/SciPhinx
Posted on Jul 22, 2009
My SB 700 shows temperature after few shuts and when it's twisted
From the SB 700 manual page b8:
v Notes on continuous fl ash photography • To prevent the SB-700 from overheating, allow it to cool down for at least 10 minutes after 15 times of continuous firing. • When continuous flash firing is repeated in quick succession, the internal safety function adjusts the recycling time by up to 15 seconds. If flash firing continues, the thermal cut-out indicator appears on the LCD and all operations are suspended. (0E-31) Allow it to cool down for several minutes to disable this function. • The conditions under which the internal safety function is activated differ depending on the temperature and the SB-700 flash output level. Operation B B-8 Slide the battery chamber cover open while pressing the battery chamber cover lock release. Insert the batteries following the [+] and [-] marks. Close the battery chamber cover. STEP 1 Inserting the batteries Operation B B-9 1.5 V alkaline AA battery 1.5 V lithium AA battery Rechargeable 1.2 V NiMH AA battery Suitable batteries When replacing batteries, use four fresh AA-type batteries of the same brand from any of the following types: • For minimum recycling time and number of flashes for each battery type, refer to "Specifications." (0H-27) • Alkaline battery performance may vary greatly depending on the manufacturer. • 1.5 V carbon-zinc AA batteries are not recommended. v Additional precautions regarding batteries • Read and follow battery warnings and cautions (0A-19 - A-22). • Be sure to read and follow the warnings for the battery on the section, "Notes on Batteries" (0H-9), before using the battery. • The recycling time can be longer when lithium AA batteries are used because they incorporate a function that suppresses the output current when heat is generated in the batteries.
Nov 26, 2015 | Cameras
I can't switch on my camera so can you tell me what i have to do please.
The manual says: if the camera does not turn on after you have inserted battery, lease check whether the battery are inserted with correct polarity (+/-)
Never use unnecessary force to put the battery in the chamber.
If you are not sure the battery is still ok, try two other batteries type AA. The camera will work with non rechargeable alkaline batteries and will work with rechargeable Ni-MH batteries.
When the battery chamber is open, please check if the metal connection point are not corroded and clean.
You still can find the manual online and the thing I describe here is on page 8
Oct 28, 2013 | Samsung Digimax A503 Digital Camera
Hello there,........i have a samsung digimax s500cyber530 that i bought appox: 4 years ago?,.....and we just several days ago replaced an 8 year old gateway "windows" computer w/a brand new HP...
Once you get the camera working again by the "shuffling technique", don't connect it to the computer again. Instead, purchase an inexpensive card reader and use it to download pictures from now on. typrice_31.jpg
Nov 17, 2010 | Samsung Digimax 530 Digital Camera
Camera will not turn on,tried new batteries still nothing.camera is kodak c813
1. Remove the batteries from the camera and then clean the battery contacts
2. Remove the memory card
3. Verify the batteries your using
Recomended batteries are
- oxy-alkaline digital camera batteries AA
- Ni-MH rechargeable digital camera batteries AA
- alkaline batteries AA
- lithium batteries AA
4. Make sure to use a brand new batteries or fully charge batteries
5. inserted the battery correctly
6. Place the camera in Auto Mode [it's the green camera on the dial mode.]
7. Turn on the camera
if issue was not resolved contact Kodak support line at 1 800 235 6325 (23KODAK) or visit the website www.kodak.com/go/stepbystep
Nov 17, 2009 | Kodak Easyshare C813 Digital Camera
Canon A710IS Battery Drains Quickly
I have this issue as well, the camera seems to drain the batteries even when it is not on.
Oct 07, 2009 | Canon PowerShot A710 IS Digital Camera
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
Power supply
You can download the manual from the link below: http://downloadcenter.samsung.com/content/UM/200703/20070330162556328_DigimaxS500_S600_ENG.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 16, 2007 | Samsung Digimax S630 Digital Camera
Camera turns off even with new batteries in it. help pls.
Hi gras, [Samsung Digimax 301] My camera also went dead on me, just can not turn it on. Please help with instruction on how to open it. I have removed 10 screws but the camera can not open completly.
Aug 07, 2006 | Samsung Digimax 301 Digital Camera
Samsung Digimax V4 Power Consumption
I had similar symptoms as well until it finally died: 1) First started eating batteries like crazy, especially standard AA and rechargeables. The CRV3 seemed to work a bit longer. 2) One day out of nowhere the autofocus stopped working. I replaced the batteries and it worked again for 10 shots. Then the autofocus stopped working and battery died (with the lens stuck open). Pressing power, the LCD backlight flashes on, the LED in the view finder blinks, and the lens motor makes noise. Then nothing just stuck open. 3) Again new batteries and was able to close lens, take a few pictures and dead again with lens stuck open - same problem in 2. 4) Replaced the batteries a couple times and was able to get a shot or two off, and now its complete stuck open, even with brand new batteries - with same problem in 2 it just won't turn on. I finally sent it to Samsung the week of Christmas. I called Friday 1/7/05 to check and had to leave a voicemail. They called back Monday 1/10/05 to let me know they recieved it and that I should call back Thursday to check its status.
Sep 12, 2005 | Samsung Digimax V4 Digital Camera
Samsung Digimax S700 Digital Camera Logo
29 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
