Question about Compaq Computers & Internet
I have a hp compaq presario 4410us. It only
I have a hp compaq presario 4410us. It only starts up when I connect the power cord and then turns off after about 5 sec. The computer will not start or turn off with the front panel power on push button. Again it will only start if I unplug and replug the power cable and then turns off. I thank you and appriciate that I can ask for your help. I hope you can help us!
    Sniper:
  • 77 Answers
If the machine is still under warranty, have HP do the deed; If not, it would appear from your description that your power supply is toast. You can pick one up from any neighbourhood computer store for $15 and up, and if you're even half-handy with a screwdriver you can replace this part in about 10 minutes.
Just make sure you get a supply that's putting out enough power to run your machine reliably; For your machine a 250 watt supply is the minimum required. Going to a higher-output supply is not an issue, but anything lower than 250w will cause your machine to not function.
A sidenote: Using your front panel power button to shut down your machine will probably work fine after your replace the power supply- Most computer BIOS settings are set so that you have to press and hold the power button for 5 seconds before it'll shut down.
Posted on Oct 07, 2009
  • Christopher Boivin
    Christopher Boivin Oct 14, 2009
    Techy...Riddle me this- If his power supply won't run long enough for his machine to post, should he purchase a new motherboard? I could send you 4 supplies right this second that exibit the same symptoms, and I haven't had to replace a board yet! The machines they came out of are all fully functional after replacing the supplies, however.
  • Compaq Master
  • 2,072 Answers
As for it powering off after about 5 seconds could be caused by a couple of things IF THE COMPUTER PASSES a POST test (BIOS, computer should beep once) check the following, if it does not POST (gets past BIOS) its almost assuredly the motherboard that has failed
1. Make sure there is not a build up of dust and dirt inside the tower. (To clean use canned air or a vacuum specially designed for computers(Anti-Static) don't use a regular household vacuum, this will ruin your computer 2. A failing CPU fan can cause a computer to power off on its own. Have your case open and watch the fan if its not spinning its probably bad and needs to be replaced (Costs about $10), you could also try and reset the fan cable(unplug and plug back in) 3.Examine your power switch on the front, see if it is getting stuck when you press it in. If it is you could try and remove and clean, their not really meant to be repaired but you might be able to jimmy rig it to work. If you suspect the power switch to be getting stuck you could follow the cable from the switch unplug it and touch a screw driver to just those two pins, this will power on your PC. (****NOTE***** I am not liable if you accidentally connect more than the 2 pins together SO BE CAREFUL IF YOU ATTEMPT THIS)
IF you have tried all above steps, then you probably need to have the PSU(power supply) replaced about $50
Absolutely no power on presario 4410
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
You are experiencing what referred to in the computer world as a dead computer system.
You either have a dead power supply or a dead computer mainboard or a dead Processor.
However it may also be a short circuit some where in your computer system.
However see my published guide entitled,
My Computer is not turning on!!! Is it dead!!! No POST!!!
Thanks
damnor01
Feb 16, 2011 | Compaq Presario 4410US (470027-053) PC...
Persario will not power up with switch, I unplug the power cord from the wall. wait about 5 mins, then plug the power cord back into the wall. the computer powers up without the power switch then shuts off...
IS THAT A Relic CRT monitors/?? wow.
NOW THE FULL STORY. (GOT TIME NOW, IM IN MEX,GULF ON A BOAT,WITH SLOW WIFI OR NEAR DEAD.)
the PSU is dead if the power button acts dead
no fans right ? no sounds, the 2 or 3 fans do not spin and blow
1: bad PSU
2: or objects plugged into the mobo are shorted,
3: mobo dead (Motherboard)
do the jump test?
here
http://www.pcdied.com/power.html#Jumper
Jan 24, 2018 | Compaq Presario 4410US (470027-053) PC...
My Compaq Presario F756nr will not turn on. The b...
Having the same issue. Did you find a solution yet?
May 20, 2010 | HP Compaq Presario F756NR Notebook
My compaq presarrio 41Ous will not turn on. I
remove the motherboard from Cabinet and check only M/B and SMPS see if restart ..? 2. Check any components it's burned.
Feb 07, 2010 | Compaq Presario 4410US (470027-053) PC...
COMPAQ 4410us desk top pc will not connect to internet. I have internet signal as I am now on it. I have tried with wireless and wired directly. I have reconfigured twice thinking that it would go...
this happened to me alot when i would get a virus.......usually bad news.....i had to reinstall windows everytime. but first i would check to make sure the network drivers are the most recent versions.
Oct 07, 2009 | Compaq Presario 4410US (470027-053) PC...
My laptop (Compaq Presario v2000) won't seem to boot up
Remove the battery. Plug power cord in. Turn on machine. Does it boot? Replace battery.
gurutim
Mar 17, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 battery
if the computer will turn on with it plugged into ac power than it is most likely the battery. batteries on these machines are cheap. Mine died after a year
Jan 18, 2009 | HP Compaq Presario V2000 Notebook
Turned off compaq presario desktop and now it wont turn back on. I used the start menu to shut down. Everytime I press the power button a light flashes over a symbol that looks like a lightbulb. Help
Try the following:
1. If connected to surge protector, make sure it's on. If it is, then...
2. Try plugging computer directly into wall and turn on...if no then...
3. Unplug and plug the power cord back in and then try to turn on...if nogo then...
4. If there's a switch on the back of your pc that has 120/240. Switch it back and forth back from 240 back to 120, turn on again...if no go then...
5. Unplug everything from the back of your pc except power cord, keyboard, mouse, and monitor. Try again. If it still doesn't turn on.. let me know. By chance, has any power outage occured or any change been done to pc since it was last turned on?
Dman
Jan 08, 2009 | HP Compaq Presario SR1123WM PC Desktop
Computers & Internet Logo
175 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
