Question about Canon XL1S Mini DV Digital Camcorder
No picture in rec mode, cam switches off in 10sec
My Canon XL1S works well in VCR mode - playback is fine. But in CAM (or REC) mode no picture appears, the LCD of the VF starts to illuminate slightly (as in the VCR mode for 1sec before the blue screen appears) and in 10sec the camera turns off. To turn it on again the Standby button should be pressed or the mode selector should be turend OFF-ON. It does not start recording at all, it does not do anything, the LCD does not even show the CAM MENU. And as I said, after 10sec it turns off completely.
The problem started after a long time staying in a closet. Could it be that the CCD has gone bad, or some caps on its board? Or some ribbon cables don't get connectivity, or something else? Maybe as the main controller does not get a signal from the CCD unit, it doesn't start do anything and turns the cam of after a certain delay?
Could I buy the service and reopair manual for XL1S somewhere?
  • 1 more comment
  • Martell Dec 25, 2007
    Sorry, it's a XL1, NOT a XL1S!
  • Martell Jan 27, 2008
    The problem has been recently solved, it was an electronic issue!
  • kmsmedia Mar 12, 2008
    So what was the solution on this problem?
  • 3 Answers
You can get a canon xl1 service manual here:
Posted on Jul 01, 2011
  • 216 Answers
Try using the Dummie Battery and connect that end to charger.
This way you will know that you don't have battery problems.
Posted on Jan 24, 2008
Record button not workig
there is several reasons for not work the record function, first of all make sure that the cassette is good and the safety tab is in record position, then check the playback of the cam with a recorded cassette, if this tests passed, check the rec button for loose or it is sticky, if so please use contact cleaner in the switch.
still the problem persists there should be problem in the circuit board. open total camera put it in record mode then test the wave shapes in the record paths up to the video head
Feb 24, 2016 | JVC GR-D270 Mini DV Digital Camcorder
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
Need help with basic operation
very easy to use this, attach the power, put the rec media(MC) there is the power on switch, put it to cam position the screen will show the image from the cam.push the record button.
Dec 25, 2015 | Video Cameras
Need help set up and basic operation. allen
Trying to hook up older technics stereo dont know
Turntable leads go to Phono.
Turntable ground lead (thin black wire) goes to screw terminal next to 'Phono'
CD phono cables go (unsurprisingly) to the CD
Cassette deck "Play Out" cables go to 'Tape Playback' sockets.
Cassette deck "Rec In" cables go to 'Tape Rec Out' sockets.
EQ Line Out cables go to amp's VCR/EQ Playback
EQ Line In cables go to amp's VCR/EQ Record Out
Aug 30, 2014 | Audio Players & Recorders
Very little sound on cam recorder Canon Gl2
look at the area between the battery and lcd screen you will see a audio level move the dials all the way up
Jun 27, 2013 | Canon GL2 Mini DV Digital Camcorder
How do i turn the flash off on the canon powershot s 30 digital camera?
The buttons directly to the left of the optical viewfinder control (i.e above the LCD) you can find :
  • Flash [record mode] / Thumbnail mode [playback]
  • Macro [rec] / Jump [playback]
Dec 05, 2010 | Canon PowerShot S30 Digital Camera
Sony dcr-trv350 tape wont close
there is a risk of hardware damage.make sure you dont force the tape into the cassette compartment to avoid damage to the unit or's what you can do.
1.remove the tape from the compartment.
2.ensure proper type and size of tape is used.
3.ensure no packaging material or foreign material inside the compartment.
4.if attempting to record, make sure cassette tape rec/save switch is set to rec position.
5.reinsert the tape, make sure it's properly inserted.
6.if still won't close or tape ejected again,remove tape.
7.reinsert a diff tape.
8.attempt to close compartment.
9.if issue unresolved, press the tiny reset button while cam is powered on (located in the panel where the lcd screen goes to,just below all the other buttons). you may also do a power reset procedure: remove batt, remove ac adaptor,set power switch to vcr, leave the cam without power for at least a minute, switch power back to off, reinsert ac adaptor/batt and turn cam on, attempt to close tape compartment.
if issue persists, service would be needed. hope this helps.thanks:)
Mar 26, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
Language change from japanese to english
Slide the [REC]/[PLAYBACK] switch to the REC position (camera icon). Set the mode dial to AUTO (green camera). Press MENU/SET to display the menu. Select LANGUAGE (head with speech bubble). Pick your language from there.
Jan 25, 2009 | Panasonic DMC-FX37 Digital Camera
Recording from a vcr
check a/v imput on camera settings, make shure that u have audio alsso conected, tried to use diferent output (DVD), make shure is playing .,
Feb 03, 2008 | Sony Handycam DCR-TRV250 Digital Camcorder
Canon XL1S Mini DV Digital Camcorder Logo
170 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
