Question about Saws
Band saw runs in surges
Band saw runs in quick surges, cutting at normal speed than slower, normal, slower etc
  • jordanhelges Oct 07, 2009
    no the motor sounds fine with no odor. When the blade is off the motor sounds like it is running at the correct, constant speed. When the blade is put on and tensioned, you hear a ticking sound and it cuts through the wood in small surges. I have made sure the wheels are coplanar and had to shim the top wheel to achieve the correct alignment.
  • Johnny
    Johnny May 11, 2010
    sounds like the motor is frying up.. does it sound normal? any burning odor?
    Problem Solver:
  • 8 Answers
LA SIERRA CIRCULAR NORMALMENTE SE DEBE DE REGULAR LA VELOCIDAD CUANDO INICIAS EL CORTE DESPUES DE ENTRAR EN LA MADERA SE DEBE DE TRABAJAR AL 100% DE SU VELOCIDAD PARA OBTENER UN CORTE MAS FINO DEBES DE CAMBBIAR EL DISCO A MAYOR CANTIDAD DE DIENTES ESMAS FINO EL CORTE BUEN DIA
Posted on Oct 07, 2009
  • 136 Answers
Check your power source , make sure nothing is preventing the wheels from turning freely that the bandsaw blade rides on, maybe some lubrication somewhere
New blade tares threw the wood. its hard to push the wood threw the blade
Are you using a new band saw blade? Are you running on a correct speed. I suggest to change the blade. I got 201 Carbon blade from http://sawblade.com/ . Also, make sure you're in right speed so that the blade will make the cut. Don't feed it so hard, let the blade do the work.
Jan 27, 2014 | Ryobi 9" Band Saw Model Bs903
Cant see m to cut in a straight line. when cutting a wine bottle the top it cutting straight but the bottom it not.
Cutting a glass on band saw is like cutting a metal. You have to make sure that you set up the band saw correctly, get a good quality blade, run on right speed, enough coolant and feed the material nicely.
Oct 21, 2013 | Saws
How do you align the wheels
I don't own a speed band saw. But recently, I fixed my band saw due to wheel alignment issue. I just read this blog .
Jan 24, 2013 | Dewalt D28770 Hd Deep Cut Variable Speed...
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
What can be done with a scoll saw, table legs?, what uses is the scroll saw for
Scroll saws use a small thin blade that runs up and down very fast. It is used to cut curved designs out of flat wood. Table legs are made on a lathe, it spins a square or round piece of wood to make legs, baseball bats.
Mar 01, 2011 | Garden
I bought an older used 6225 milwaukee bandsaw, it worked alright for a little while then it started runing slower & slower till it hardly turns now. Would it need an armature?
Hi Joe,
While that is a possibility, I usually start with blowing it out with compressed air, then inspecting the brushes. They're usually the first thing that wears out (down).
Best regards
Mike
Mar 31, 2010 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Blade guide bushes melt/wear with hard wood
If these bushings are getting that hot, then you may have the wrong speed or a non-optimum blade. The blade pitch (number of teeth per inch) must be lower the thicker the wood is. If there are too many teeth trying to cut at the same time you have to push harder to get enough pressure to cut and that puts more force on the guide bushings. There are a variety of pitches available even for the narrower scrolling blades. If you have to move up to a wider blade, there is a little trick to help you cut a slightly smaller scroll radius - round off the back side of the blade with a sharpening stone.
Also, with oak, you may need to use a slower speed to keep the blade from heating up - although a hot blade will show up as more of a problem with the lower guide bushings only. Your saw might have multiple steps on the pulleys, allowing you to move the belt to a slower speed.
I hope this helps. Thanks for using Fixya. Good luck!
Al K
Mar 21, 2010 | Saws
When cutting wood with band saw saw will cease up
This could have many causes...depending on the model of saw, the wood being cut, the blade you're using, etc. etc.
Check that the blade is correctly installed, up to tension, and sharp. Make sure the wheels run smoothly on their on, and under power. Check the horsepower of the motor, and make sure to keep the feed rate down within the motor's capacity. Finally, don't twist the work being cut to a smaller radius than the size blade will handle, or you will bind the blade in the cut.
If you are cutting wood with pitch or grain that is likely to be under tension, perhaps you need to insert a wedge into the cut to prevent the work from pinching the blade as it continues the cut.
I hope that leads to a solution. Sometimes all you can do is feed slowly and be patient...
Jan 25, 2010 | Saws
I just purchased the ryobi 9 inch bandsaw, used it once or twice and have noticed that the teeth on the blade are crooked. is that a typical problem, is it a problem at all?
If you mean that the teeth alternate sides in which they point, this is normal. This aids in the blade clearing cut material from the path of the blade making sure it does not clog. Almost all saws for wood have this tooth pattern. If you have doubts look at a new replacement blade for the saw.
Jan 19, 2010 | Ryobi 9 in. Benchtop Band Saw
Blade Types
remember to match the blade width to the type of cutting you are doing. Also keep in mind: * Narrow Blades can make much tighter radius cuts, but tend to twist and wander when making long straight cuts. * Wide Blades can't make the tight turns that narrow ones can, but they hold a straighter line than their narrow counterparts. * The tpi determines the speed with which the blade cuts through stock. Blades with high tpi cut slower but leave a very smooth edge. They are best for detail work on thin stock. Blades with low tpi cut quickly and leave a slightly rough edge. They are great for resawing or long rip cuts. * Steel Blades are inexpensive and work well for cutting softwood. Steel blades, however, dull quickly in hardwood. * Bimetal Blades are made of high-speed steel and can cut thin metal or wood. * Carbide Blades are for wood cutting only. They are more expensive than other blades but stay sharper longer than steel or high-speed steel.
Aug 27, 2008 | Dewalt Variable Speed Deep Cut Band Saw...
Saws Logo
111 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
