Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
I cannot get our air conditioner to stop running. It is on the 'off' setting and the monitor shows that it should be off, but it keeps running and won't stop!
  • Johnny
    Johnny May 11, 2010
    is the fan set on auto or on? how old is the thermostat?
  • 89 Answers
Sounds like you have a short in your low voltage (t-stat) wire.( Two or more wires touching somewhere)
Posted on Oct 08, 2009
When the air condition reaches the set temperature to cut off the blower motor keeps running and i have the thermostat set to auto on the settings.
check the operators manual but you will probably find that the fan will keep running so that the air in the room is circulated past the thermostat so that the temperature can be monitored and the compressor switched on when the temp reaches the upper limit
May 30, 2016 | Heating & Cooling
My Carrier Central Air unit is not working and shows Code: 24 VAC power
Will the indoor unit run with the Thermostat fan switch set on auto?
I need to confirm that the indoor unit runs first.
Jun 03, 2014 | Carrier 38CKC036 Air Conditioner
I have a Haier air/heating unit. The heat has stopped working.
Keep heating mode and temp setting at minimum 3 to 4 degree C* between room and required temp.
If still not working, replace the heating sensor.
Tnx
Nov 13, 2013 | Honeywell ER150B Air Conditioner
Carrier holiday elite 12
I believe this means you need to empty the water catch tray. Normally a pull out tray at the rear with a float arm in it. It will keep happening as the water is condensed out of the air during the dehumidification. Empty it out and start again, it will need regularly emptying.
Jun 02, 2013 | Heating & Cooling
Unable to reset monitor to put time in, it just keep showing 88:88 flashing
There should be a button or slide switch to put the Monitor heater in the clock set mode. Once you get it in the clock set mode, use the up and down buttons to set the hour (up) and minutes (down). Let me know what model the heater is and I can tell you definitely how to set the time. nitensheaterservice@earthlink.net
Nov 07, 2010 | Heating & Cooling
I cannot get my wintair room air conditioner to stay on! It keeps cutting on and off, going from fan to air conditioning. Need help!!
It sounds like your air conditioner is doing what it is supposed to do. The compressor kicking in and out is an energy saving method of using the ac. When the thermostat (ball attached to evaporator coil) registers the set temperature the compressor kicks off.
Jun 28, 2010 | Heating & Cooling
My air stops running inside before it get to the temp. Its set for but the outside unit keeps running and after a minute or two the air will start blowing inside again but the outside unit never turns off...
you have a possible thermal overload problem in your furnace blower motor dirt will cause this problem when it doesnt allow air across the windings of the blower motor if not dirt the motors going bad and getting hot use a shop vac and eliminate dirt keep your filter changed and your evaperator a coil may also need checked for cleanliness this will require cutting into plenum my advice someone qualified and remember dirt kills
Jun 18, 2010 | Goodman CKL36AR36 Air Conditioner
This goldstar air conditioner model is WG2405RY7 It has an energy saver, but the unit just keeps running and won't shut off, everything else works.
Doe's the temp reach the set point? If not then it will run until it doe's. If you set the stat warmer and the fan keeps running after compressor shuts off check to make sure it is in power saver mode. Most AC units keep more even temp when fan is left on.
Jun 29, 2009 | Goldstar M1003R Air Conditioner
Heating & Cooling Logo
37 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
