Question about Panasonic Microwave Ovens
On NN-K602/652 light needs replacing - Panasonic Microwave Ovens
How to replace light bulb in Panasonic microwave model NN-S446BA.
Here is the free online manual, but I did not see the light bulb change on my first look through: https://www.manualslib.com/manual/192230/Panasonic-Nn-S446ba.html?page=2#manual
There is a YouTube educational video that may help more: https://www.youtube.com/watch?v=sLidbz2LUtg
I hope this helps you out!
Apr 09, 2017 | Panasonic Microwave Ovens
Why it blows the light and control board damaged?
It will be best to repalce the board, as card basis, rather than try to make a "Surgery" to it. Gopakumar Gopalan Google
May 01, 2014 | Panasonic NN-H275SF Microwave Oven
Change light bulb panasonic inverter nn-h965bf
We recommend you have an authorized service center location replace the light bulb. Authorized service centers can be found in the below link.
www.panasonic.com/repair
Welcome to Panasonic Online Repair
Mar 23, 2014 | Panasonic NNH965BF Microwave Oven
Magic chef overthecounter microwave external light doesn't work
This microwave's replacement countertop light is F60305H00AP. This can be obtained by going to www.panasonic.com/parts.
The instructions for replacing the bulb can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/NNSD277SR.PDF#page=28
Mar 02, 2014 | Panasonic NN-SD277WR - NN-SD277WR...
My new panasonic microwave model NN ST 340w has the internal light on when I heat up food. However when I open the door to put food in or take it out, the internal light does not turn on. What can I do?...
Your oven light is busted or damaged. You can buy the replace at the any electronic shop. Just open the top cover then you will see the light you will going to replace
Aug 15, 2011 | Panasonic NN-H664 Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
My Panasonic nn-s262 fan and light not working. All other functions are operational. Is there a fuse in the microwave that needs replacement?
Hello, you will need to take the cover off the microwave and look for a fuse internally which should be mounted onto a pcb or electronic board.
NOTE: Be very careful if the microwave is stainless steel as they are very sharp.
Jun 18, 2009 | Panasonic NN-S262SF Microwave Oven
Replacement light bulb for Panasonic NN-9853 Microwave
Hello, I also have a Panasonic Microwave ( model NN-S 564 or 574 ?) They are very similar.
I have just removed the outer cover 5 screws ( unplug of course ) and have located the bulb holder which is a white plastic component with two clips holding the globe, pull it out and remove the two spade clips connected to the globe. The globe will come away attached to a black plastic mount. Next........do the run around to find someone who sells it.
Perth has an authorized distributer/repairer in Myaree whose details I got from Panasonic. He may sell them. otherwise I will try a couple of specialist light globe suppliers I know....PROLAMPS in Belmont and one in BALCATTA whose name escapes me but I have been there before...Hope this helps others.
Martin
May 10, 2009 | Panasonic NN-S540 Microwave Oven
Microwave Ovens Logo
101 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
