Question about Amana Freezers
Ice build up on the top and door of full size freezer
We have a full size freezer that has started forming a great deal of ice on the top of the freezer and mostly along where the light bulb is. It exends to the top part of the door and it makes large icicles that freeze down the door. We have defrosted it already but it just continues. No matter how much we scrape it, it comes right back even worse if we don't scrape it off. This is an Imperial UL4000ECW3 made by Amana
the dr
  • 447 Answers
SOURCE: Up right Amana Deep Freezer
Try taking a small piece of solid copper wire strand, loop over defrost heater and extend into drain hole, this is a trick we use to help with this issue by bringing a little heat around the hole. The freezer may be manufactured by Woods Inc, a canadian appliance builder. These did have lots of problems with the water building up between the inner and outer liners, Not much you can do with these either to totally resolve this issue. Make sure the water is going into the drain pan when you pour the hot water.
Posted on Jan 01, 2008
  • 1314 Answers
SOURCE: running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Posted on Feb 20, 2008
SOURCE: Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Posted on Jul 21, 2008
  • 86 Answers
SOURCE: frosting & water dripping from freezer in Frost free freezer
Hi, You will find that your problem relates to the defrost heater in the freezer. You will need to take the drawers out and remove the back panel to access the evaporator. There is a foil heater that lays underneath the evaporator and it will need to be changed. Along with the klixon that controls it. This will ensure that both parts are good. Your problem will then be fixed no more water!
Good luck................
Posted on Jan 02, 2009
jumptrout51
  • 3361 Answers
SOURCE: Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Posted on Mar 27, 2009
Why is the top of freezer frosting up
The door gasket is leaking around the top of the door. Air getting in past the gasket condenses in the freezer causing the ice build-up.
Sep 07, 2014 | Freezers
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Model No.ERF415M 13CT. I have ice forming underneath the bottom freezer draw, when I open the door it melts and runs out as water under the appliance.
drain is plugged up were it is normally drain to defrost the freezer completely find a place to store food in freezer for a few ours leave door of freezer open pull out all shelfs and lay a few tools down at bottom of freezer were you seen the ice build up after you have done that pull ref away from wall take back of bottom look fro drain pan with a turkey baster send water thru back of freezer inside if water still flows back out into freezer drain tube is still clogged use warm water when doing this if you see drain pan full of water use a shop vac that can deal with water suck out water send water again water should go strait to drain pan if still flows out may have to remove drain tube
Aug 23, 2011 | Daewoo Freezers
I have severe ice forming in my freezer.
On this unit the shelves are the cooling coils and carry the refrigerant (freon) through the system. They will attract the warm moist air by design, so if you have an air leak in the door or elsewhere it will tend to build up there first.
This being said you need to check something else first. Make sure the other shelves are cold. If they are frosted and cold like normal then you most likely have a door that is not closing all the way or a bad seal. If the lower shelves are not cold then you have a system problem, typically a refrigerant (freon) leak that is causing the top shelf to absorb most of the work and not enough refrigerant to flow to the bottom shelves.
I hope this helps
May 06, 2010 | Frigidaire 16.7 cu. ft. / 473 liter...
Ice crystals forming on inside front freezer panel
Very possible the door seal is not properly sealed. Warm inflowing air onto a cold coil will cause ice build up at the lid.
Oct 08, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Frost forming on top of inside door by hinge
you probably have an air leak. if the gasket is bad it needs to be replaced. Air could also be coming in through the door flap if you have water and ice dispensor on door
Sep 17, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ice build-up on the inside top of of freezer door
yea def , not normal, nor an acceptable amount of ice forming there( good pic). heres what i have been told to try and with good results
first make sure the door gasket is sealing all the way,(small gaps in ht emagnets at extreme corners) is common but with a little amount of "mortite"or "permagum can sometimes be insterted behind the corner of gasket to assist filling the void.
second a small amound of a white/clear silicone be applied to the outer perimtere of gasket, to minmize air movemnt from between gasket and door panel.
lastley in oyour second pic i see "frost free" written on a plastic air deflector. you can remove that with 3-4 screws on backside of it, and then reinstall with a small spacer so as the baffle now with sit with a 3/8in. gap between it and the top of the freezer liner.( a brass ferrel from the compression fitting of a plumbing fitting is just the right size)..... the theory behind this is to prevent the air from gatting "trapped" in the void created when the door closes-- air can now pass back and forth freely.
I hope this gives you some satisfaction if not I would advise another tech be sent who is willing to call for factore tech support( ths is where i got my info from)
Jan 14, 2009 | Frigidaire 13.7 cu. ft. Upright Freezer...
Frigidaire frostlfree upright freezer ice forming top interior door
Not sealing. warm air hitting cold air causing frost. also, door frame heater may not be working. most frames are "warm" to the touch. normally called an "anti sweat" heater.
Jul 15, 2008 | Freezers
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
97 people viewed this question
Top Amana Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
Sal De
Are you an Amana Freezer Expert? Answer questions, earn points and help others
