Question about Maytag MER5775Q Electric Kitchen Range
What does the F1 error code mean? The stovetop works, but the overn and broiler do not.
    Genius:
  • 1,157 Answers
Hi mdecastr,
The F1 error code is about a defective touch pad or clock (ERC). Please follow the steps below to determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker. It is very important that the power to the range has been disconnected, so please double check before
continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back
7. Please replace the ERC, if F1 comes back. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 14, 2011
Maytag preforma range model # per5710baw. everytime i push the bake or broil it flashes lock. the stovetop still works but will not let me input a temp. keeps flashing locked. how do i unlock it? it...
Hi
Error code F1 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 25, 2011 | Kitchen Ranges
Have a F1-2 error for my maytag range.. the stovetop works fine but the ovens don't
F1
Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common
problem. Refer to F1 test at the top of this page for more
information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor
(RTD). Check sensor harness.
Jan 08, 2011 | Maytag MER6772 Gemini Electric Kitchen...
The oven on my magic chef range does not work..broiler and burners ok ,,,get a F1 code and beeping noise ...model number 3488VTV
Hi hockeyhoskin,
F1 error indicates a bad touch pad or clock (ERC). To fix this error code, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Dec 06, 2009 | Magic Chef 31000 Gas Kitchen Range
Kenmore electric oven will not heat, broiler and stove work fine
I also have the exact same problem, is ther a possible fix-it-yourself solution for this???????????? if not what should a repair cost?????
Sep 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
MY FRIDIGIDAIRE FEF336BC BOTTOM COLI NOT WORKING
F1 error is a bad control board. Replace the ERC, electronic range control.
Mar 24, 2009 | Frigidaire FEF336BC Electric Kitchen Range
I get an "F1" code on my Maytag range.
you need a new temperature probe. its usually located in the upper left hand corner in the rear of the oven.
Mar 19, 2009 | Maytag MES5570 Electric Kitchen Range
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven does not work
According to the manual, the self cleaning latch could be stuck.
If the oven door is open, press STOP/CLEAR to clear display, then depress and hold switch plunger for 6 seconds (Located in the upper right corner of the oven front) and the oven door will unlock.
If the oven door is locked, press STOP/CLEAR to clear the display then apply pressure to the upper right corner of the oven door and the door will unlock. If the "F" code reappears, contact a Sears trained repair specialist.
Sep 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
What does "F1" mean? The oven is out!
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
Sep 24, 2007 | Crosley CE35111AA Electric Kitchen Range
Roper Gas Range
F1 Error
My Roper gas range is sounding an alarm call with number F1 flashing. Can anyone reveal what the code means before I call service? Thanks!!
Mar 24, 2007 | Roper FGP305 Gas Kitchen Range
Maytag MER5775Q Electric Kitchen Range Logo
134 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
