Question about Casio Music
I have a Casiotone MT70 made in 1984. How do I check the polarity as I need to get an AC Adaptor and don't want to damage the keyboard?
  • Casio Master
  • 5,603 Answers
Here is how you might check the polarity of a 7.5 volt DC replacement adapter:
Put the 5 batteries into the unit and verify operation. NOW using a DC voltmeter measure the voltage from battery negative and meter negative connected and meter positive to the pin on the power jack. IF you see 7.5 volts positive, then the pin is the positive lead for the adapter.
If you see zero, then continue testing.
With the 5 batteries inserted, connect the positive meter lead to the positive of the stack of batteries. Now touch the negative meter lead to the pin.
If there is 7.5 volts there, then the pin is the negative lead for the adapter.
READ THESE INSTRUCTIONS CAREFULLY.
USUALLY the jack has a contact that disconnects the batteery when the plug with sleeve is inserted.. We are testing the jack without inserting a plug here so the plug should HAVE THE BATTERY VOLTAGE with correct polarity on the pin.
Posted on Oct 08, 2009
Testimonial: "Very clear explanation for a non-techie to understand. Many thanks."
Why doesn't the Yamaha psr-78 get any power using an adapter?
Check that the powr adapter is working and putting out the correct voltage.
Mar 22, 2015 | Yamaha Music
Got a used CTK 720 and it has no power. sugestions
try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
Feb 15, 2015 | Casio CTK-720 Electronic Keyboard with...
Power falier
Power failure?
First check the power supply / adaptor to ensure this is working correctly. Measure the voltage using a multimeter - if this is correct move on ( if not replace power supply )
Does the keyboard work if you hold the plug in the socket or move it slightly ? If so this is a common problem as the power socket on the pcb fails at the solder joint and will need to be repaired / replaced.
If this appears to be solid then you may have done some internal damage by either plugging in a power adaptor with a too high voltage or wrong polarity. If this is the case you may have blown some circuitry inside which controls voltage regulation.
Please report more if you have more information.
Jan 22, 2014 | Yamaha PSR-E223 keyboard
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Sep 12, 2013 | Casio Keyboard Power Adapter
No powerfrom the outlet source
The AC adaptor of my Casio Keyboard has reversed polarity from the Standard Power AV adaptor you get in the market. The center is NEGATIVE. When you try to use a new power supply that is NOT a CASIO original, you may need to reverse the polarity of the plug. Check that.
Jun 29, 2013 | Casio CTK810 61 Key Keyboard
The power on my banshee is coming on?
Check the polarity of the adapter, if it isn't the original one. Even if you have the right voltage, it still has to have the mA or higher but, most important is the polarity. Most guitar pedals are wired backward on the plug. The positive is on the outside ring of the plug and negative is in the middle. There should be a picture or diagram somewhere on the unit close to the plug to find out. If it is backwards, it could have damaged it, maybe not though. If it is ok, cut the plug off and switch the wires and check it. After all, it's not working now, it couldn't hurt.
Mar 15, 2013 | Rocktron Banshee Guitar Talk Box Talkbox...
Casiotone MT-220 keyboard power cord
I would inspect the unit for corrosion on battery terminals AND the power connector. The connector has a switch when a cord is plugged in, and if this switch doesn't work (they get bent) the unit will not work on batteries.
Best source of power adapters is often your local thrift store.
MATCH the voltage and whether it is AC or DC required AND the polarity if the pin is + or -.
Get one with enough current.
Apr 28, 2010 | Music
No instruction manual
Yes I have one which I can photocopy for you if you are still looking. I appear to have lost my Power Adaptor and would appreciate knowing any Name or reference on yours if you have one.
My e_mail address is duggie.dms@btopenworld.com if you care to contact me.
Thanks.
Duggie
Jun 25, 2009 | Casio LK30 Note Lighted Keyboard
Music Logo
753 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
