Question about IBM NetVista PC Desktop
IBM ( Old ) NETVISTA DESKTOP PC No display
The system worked fine , i rebooted and there is no display on the monitor .
The CPU Fan is spinning , There is a Orange / Red Light on the M/B but there is Northing on the Screen .
- Removed Memory and tried Different DIMM - No Go .
- Re-seated the CPU - No Go
- Removed the M/B Battery - No Go
- Reseated Jumper to factory setup - No Go
How Do i Fix this ????
  • 149 Answers
Hi there, try to remove the video card and put it back again, turn it on and try to hear beeping sound or see if it is ok. if still same problem, identify if your monitor works or not and proceed to the system unit, may be the main board is mulfunctioning. do some test. ty
Posted on Dec 24, 2007
IBM Netvista A30 8315-61U Windows startup Problem
IBM Netvista A30 8315-61U what does IBM have to do with DELL?
huh?
that is now Lenova , IBM sold PCs div, to Lenova long ago.
so ill move you to lenovo
my guess the post should read
old Pentium 4 PC from Lenovo per above
I can not install and OS
NO OS stated, windows sure... but...
NO version OS stated XP, vista,w7,8,8,1.w10
no media you are using to install it.
the cure is easy , re-Install windows fresh
all data and your apps will be gone, we backup first.
if that fails the HDD is bad, run HDD test.s
run crystaldiskinfo on it if smart param, C6 is wrong, the drive is toasted.
Mar 04, 2018 | Dell Dimension 4600 PC Desktop
I have a refurbished ibm netvista. when i turn it on, the cpu fan will start to spin for a few seconds, then i'll hear a weak beep, then the fan will stop spinning (power off), then the fan will...
Remove the hard drive and RAM. See what it does. It should go into BIOS and complain. If it doesn't you have a motherboard issue as it won't POST.
Dec 24, 2010 | IBM NetVista PC Desktop
When i start up my computer...the CPU fan having noisy..and my computer doesn't start up..
first check if any wire touch in the fan then set the wire in the proper way.if again it's making noise then change your cpu fan.
Jul 15, 2010 | IBM NetVista PC Desktop
Monitor losing brightness
Well it does sound like your monitor is going to die soon. You'll just need to replace it, trying to fix a 7yr old monitor is exactly worth it. Fixing it would be costly so you may as well buy a new one.not sure what you mean by integrated with drive unit. some elaborating would help :D
May 06, 2010 | IBM NetVista PC Desktop
Trying to upgrade cpu.
Here's a direct link to the service manual of the NetVista 8303-21A:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/netvista_pdf/24p2969.pdf
On page 13 of this manual:
Microprocessor (varies by model type): Intel® Pentium® 4 processor with 256 KB or 512 KB of internal L2 cache memory and Intel NetBurst™ micro-architecture.
It seems that the computer's motherboard does not support Intel P4 processors with more than 512 KB of internal L2 cache. That's why your P4 2.8GHz/1M/533 Prescott processor did not work.
You will have to either buy another processor with 512 KB L2 cache, or replace your motherboard with one which supports the new processor.
Dec 19, 2009 | IBM NetVista PC Desktop
Last Night I use my PC for 4 hours but after that i turn off properly but when in the morning i try to on my PC it didn't turn on when i press the power button nothing displaying for me only one light is...
First of all when you switchon your PC, checkout whether your processor Fan is running. Because problem might be because of SMTP failure [Power Supply in your CPU] if its working fine and you are able to see LED glowing in *********** board, might be loose connection in your Hard disk cable.
Let me know this didn't help you out or if you need more info.
Mar 13, 2009 | IBM NetVista PC Desktop
IBM NetVista 6578-RBG Windows XP hanging
It seems, that you should replace motherboard, I've seen this kind of problems in my office, after year or two you won't be able to turn it on at all. In my opinion, it's bad quality capacitor on motherboard.
Any way there is little chance that it cold be bad PSU, but it's really small chance.
Feb 03, 2009 | IBM NetVista PC Desktop
Ca't get any display
Check the cable fro monitor what is going in PC check the litle tiny pins inside on the plug
May 26, 2008 | IBM NetVista PC Desktop
Screen does not light up
hey u r in deep trouble u have messed up the o.s now u have to reload the o.s from a recovery c.d....
Mar 17, 2008 | IBM NetVista PC Desktop
IBM NetVista PC Desktop Logo
189 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
