Question about GE Dryers
GE dryer won't heat, Has 240 volts at dryer plug and the heating coils have continuity.
  • GE Master
  • 7,482 Answers
You need to check the thermistor/thermostats...that may be your problem.
When they go bad, the will not let the heating element heat up to proper temp.
Good Luck,
Hope this Helps
Posted on Oct 07, 2009
On my Sears Kenmore dryer, all sensors have continuity, heating element not broken, but won't heat?
if your machine has a timer the timer could be bad or it's the motor,these are the last two things that could stop your dryer from having no heat,next time send the model number,also did you check where the plug connects to the dryer to make sure you have 240 volts going into the dryer,that's the first thing to check,but to answer your question you get 120 volts from the timer or board and the other 120 comes from the motor,you need 240 volts down to heater to have heat.
Jan 31, 2018 | Kenmore Dryers
My Kenmore 400 turns on, tumbles but does not heat up. What could be the problem
I am assuming this is an electric only (not gas) dryer, as I cannot find any tech data on your specific model. This is a general troubleshooting guide for heat issues with electric dryers, going from the most common to least common solutions:
**Standard disclaimer--voltages in a dryer (or any AC connected appliance) are high enough to kill you. If you don't know what you are doing, or have any difficulty understanding what I am saying....STOP and call a professional.
With that being said....
1. Test the power supply feeding the dryer and make sure that both 120 volt legs are getting power in reference to the neutral wire. Check between them (red wire to black wire) and check for 240 volt power. A bad breaker or partially failed 240 volt circuit may still provide power for the motor (which only uses one 120 volt leg) but not the heating element, which uses both 120 volt legs to make 240 volts for the heating element. Be sure to check both the receptacle and the terminals where the cord attaches to the dryer.
2. With the dryer unplugged, and the heating element disconnected, check for continuity between the heating element terminals. You may also be able to visualize the heating element coils if you remove it from the dryer. Most elements are held in place by one small sheet metal type screw, in case you need to remove it.
3. Check for continuity on the thermostat and thermal cutoff switch on the dryer. These parts usually are about 1.5" across and are screwed into the metal housing for the heating element. When the dryer is cool, both of these parts should have continuity. Remember to remove the wires from at least one of the terminals before checking continuity. These parts may look similar. If you have a defective one, google the part number stamped into the side of the part to determine which one is which. They are NOT interchangeable.
4. If all of this checks out ok, you will need to check for power coming from the timer to the heating assembly with the power on. The thermostat, thermal cutoff and heating element are typically wired in series. The two wires coming from the timer area down to the heater assembly should have 240 volts between them when the dryer is powered on and in a heating cycle. Once again BE CAREFUL IF YOU DECIDE TO DO THIS. IF IN DOUBT, READ THE WARNING ABOVE.
Your dryer may also have a switch to control the heat intensity, independent of the timer. If it does, check that as well.
Good luck, and I hope this helps!
Feb 21, 2012 | Kenmore 400 6942 Dryer
Our dryer won't heat and i have continuity through heating element i also checked and made sure that there is 240 going to the dryer and there is
check your heat or thermal disks. These are about the diameter of a quarter and sense the temperature. If faulty they may send signal to the element not to work. I think they are a normally closed device and bimetallically operate to open position when temp is high(regulate temp) Yes there should be 240 volts...120 for motor..120 for heating coils.
Feb 21, 2010 | Dryers
Dryer work's but no heat
If it is 240 volt which it should be make sure the plug is pushed all the way. If not it will run and not heat. If the plug is in all the way then check heat coil if bad then replace.
Feb 21, 2010 | Whirlpool Dryers
I HAVE A GE DRYER THAT WAS WORKING FINE ONE LOAD THEN STOPPED HEATING UP ON THE NEXT LOAS.IT TURNS FINE BUT NO HEAT
either your heating element,cycling heat switch,hi-limit switch,or thermistor are defective also check power input for 240 volts,if one leg 120 volts is missing it won't correctly
Oct 31, 2009 | GE DVL223EBWW Electric Dryer
I changed the heating coil on my 80 series kenmore dryer and changed the Hi thermostat. When I try to turn on the dryer it won't do anything, and I noticed as soon as I plug the Dryer in the heating coil...
chances are that the heating coil is touching ground some place it must be suspended completely and where it passes through the steel it must have an insulator (Caution this is a fire hazzard ) what's happening (if you care) is that the heating element is 240 volts in our electrical system either one of the wires that makes up that 240 volts to ground will give you 120 volts so at some point your element is grounded giving it 120 volts more than enough to make it glow red.... for some reason beyond my comprehension our electrical safety authority has decided that in a residential dryer only one live wire needs to be interupted leaving the other wire live Good luck ...sorry about the rant I,ve seen this exact problem about a dozen times
Oct 23, 2009 | Dryers
How do you check voltage to dryer?
The first thing you should check on a electric dryer when it does not heat or run is the voltage at the cord.
If you do not have the correct voltage your dryer will not heat and may not even start.
The dryer needs 240 volts for the heater to work. It gets 240 volts by using two 120 volt lines. If one of these 120 volt lines is dead it will not heat. It may or may not still run as the dryer only needs 120 volts for the motor to run.
If you have one 120 volt line missing power and it is the same 120 volt line that runs to the motor then the dryer will not run or heat.
May 30, 2009 | Dryers
My maytag electric dryer will not heat up. it's a de107
Have someone check to be sure you have 240 volts to the plug. The dryer will run on 120 volts but must have 240 volts to the heating unit. If you 240 volts you probably need a heating element or control.
Apr 06, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Ler662
CHECK FOR 240 VOLTS AT DRYER ELEMENT WITH DRYER
RUNNING IN HEAT CYCLE. IF NO VOLTAGE, CHECK WALL
OUTLET FOR 240 VOLTS BETWEEN LEFT AND RIGHT SLOTS IN RECEPTACLE. A DRYER WILL RUN ON 120 VOLTS TO
GROUND BUT WILL NOT HEAT IF 240 VOLTS IS NOT PRESENT. IF THERE IS 240 AT THE OUTLET, START TRACING THROUGH THE HEATER CIRCUIT. LOOK FOR A FAILED THERMOSTAT OR THERMAL FUSE NEAR THE HEATER OR EXHAUST OUTLET. CHECK THEM WITH A CONTINUITY TEST WITH DRYER UNPLUGGED, OR A VOLTAGE CHECK WITH A HOT CIRCUIT.
Jul 28, 2008 | Whirlpool LER5636P Electric Dryer
GE dryer DHDSR46
check to see if you have 240 volts at the dryer
Jul 12, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
57 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
